  3. Zway Bridge
  4. full devices reset
full devices reset
Zway Bridge
Help with Z-Way plugin
Zway Bridge
Zway Bridge
Zway Bridge
Renaming device name...
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Zway Bridge
Z-way token Expiration
Zway Bridge
Zway Bridge
XMLs & jsons without vera
P
Zway Bridge
Error after device delete
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Child device undo failure
Zway Bridge
K
Zway Bridge
Zway Bridge
z-way with home assistant
Zway Bridge
full devices reset
77 Posts 2 Posters 42.4k Views 2 Watching
    @DesT
    Could you run this code and let me know the result? I’m thinking there must be a version mismatch somewhere in your setup.
    local loader = require "openLuup.loader"
    local lfs = require "lfs"
    local ignore = {init=true, json=true}
    for a in lfs.dir "openLuup/" do
      local b = a: match "^(.-).lua$"
      if b and not ignore[b] then
        local x = loader.find_file(a)
        local y = require ("openLuup." .. b)
        if type(y) == "table" then
          local v = (y.ABOUT or {}) .VERSION or '----.--.--'
          print(v, x)
    • DesTD Offline
      DesTD Offline
      DesT
      ----.--.-- openLuup/api.lua
      2022.12.20 openLuup/historian.lua
      2019.07.19 openLuup/http.lua
        …is that ALL ??!
        • DesTD Offline
          DesTD Offline
          DesT
            Ah, same module as your original error.
              Sorry to be a pain, but what does this say…?
                if a: match "%.lua$" then
                  local f = io.open ("openLuup/" .. a)
                  if f then
                    local v = f:read "*a"
                    f: close()
                    print(v: match 'VERSION.-"([^"]+)', a)
              • DesTD Offline
                DesTD Offline
                DesT
                @akbooer no worries 😉
                2023.01.01 api.lua
                2024.02.23 init.lua
                2022.12.20 historian.lua
                2019.07.19 http.lua
                2023.02.18 panels.lua
                2023.03.04 console_util.lua
                2022.11.05 chdev.lua
                2021.05.08 gateway.lua
                2023.02.10 wsapi.lua
                2024.01.06 loader.lua
                2019.10.14 client.lua
                2024.02.09 mqtt.lua
                2020.03.30 L_AltAppStore.lua
                2024.05.01 scheduler.lua
                2024.02.11 L_ShellyBridge.lua
                2023.03.04 userdata.lua
                2018.07.28 backup.lua
                2021.03.05 shelly_cgi.lua
                2024.02.26 L_openLuup.lua
                2022.12.20 whisper.lua
                2018.04.23 pop3.lua
                2021.01.03 L_VeraBridge.lua
                2021.06.14 L_TasmotaBridge.lua
                2023.01.06 luup.lua
                2024.01.05 devices.lua
                2024.02.22 virtualfilesystem.lua
                2021.08.21 whisper-edit.lua
                2024.02.25 servertables.lua
                2018.07.28 sysinfo.lua
                2021.05.01 json.lua
                2018.03.25 logs.lua
                2024.02.12 timers.lua
                2021.02.20 requests.lua
                2022.12.11 L_Zigbee2MQTTBridge.lua
                2016.06.30 compression.lua
                2021.04.23 xml.lua
                2023.03.03 scenes.lua
                2018.01.27 hag.lua
                2021.03.25 http_async.lua
                2019.08.12 graphite_cgi.lua
                2024.01.03 tcp.lua
                2024.01.03 io.lua
                2024.01.03 server.lua
                2016.06.23 rooms.lua
                2018.04.12 smtp.lua
                2021.04.30 servlet.lua
                2024.02.26 console.lua
                  @DesT
                  I did find something amiss in one of the files, although I'm not convinced it's the problem.
                  Latest development (v240229 – the Leap Year edition) has a fix... I wonder if this gets us any further?
                  • DesTD Offline
                    DesTD Offline
                    DesT
                    yeah it's working 😉
                    • DesTD Offline
                      DesTD Offline
                      DesT
                      @akbooer about RulesEngine... I think I found something... if I modify a rule, it work except, the data is not saved. That mean, if I "edit" again, it's the old data and if I reload openLuup, of course it's again the old data.
                      The problem is the "save" function.
                        Excellent.
                        For the Rules Engine, I looked previously, and I think it’s a JavaScript issue, but I’ll try and take another look.
                          Yes, the code for saving rules is here…
                          ALTUI_RulesEngine1.js
                          In some cases, it should write error messages to the browser console…
                          • DesTD Offline
                            DesTD Offline
                            DesT
                            I just check again, and I'm never having any kind of error in the console, not even a warning.
                            • DesTD Offline
                              DesTD Offline
                              DesT
                              @akbooer just did a little test... and in the browser console, I can see in the network, that, when saving a rule... it call upload_upnp_file.sh
                              I just did some test again and the file C_RulesEngine_Rules.xml is modified properly...
                              Is it possible that's related to the issue with openLuup console ?
                                Oh, that’s interesting. There’s several versions of that file: @Vosmont wrote the original; I collaborated in making the CGI version of it, specifically for openLuup.
                                You’re saying this all works now?
                                • DesTD Offline
                                  DesTD Offline
                                  DesT
                                  yeah I made a couple of changes and save them, I confirm the file got updated too, I reloaded openLuup, still having my changes...
                                  The only little issue I have it's a cache issue, when I change a rule, save it, re-open it, sometime it's the old version BUT the file timestamp is newer and opening a new browser show me the right version.
                                  so there's something in your last openLuup version Feb 29 that fixed that too
                                    You only get that lucky once in every four years!
                                      132.1k
                                    • Logon screen timeout
