  3. Zway Bridge
  4. openLuup Z-Way bridge: Version Log
full devices reset
Zway Bridge
Help with Z-Way plugin
Zway Bridge
Zway Bridge
Zway Bridge
Renaming device name...
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Zway Bridge
Z-way token Expiration
Zway Bridge
Zway Bridge
XMLs & jsons without vera
P
Zway Bridge
Error after device delete
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Child device undo failure
Zway Bridge
K
Zway Bridge
Zway Bridge
z-way with home assistant
Zway Bridge
19 Posts 4 Posters 6.6k Views 4 Watching
      Development Branch: 2020 Release 5.12
      • don't disable devices in Room101 (thanks @kfxo)
      • add command class 1 updater (thanks @ArcherS)
        So am I correct in saying that this bridge allows the UZB to be accessed via Openluup as opposed to via Z-way software and front end?
        I guess we still need the software and licence 😄
          No, not quite. It uses the ZWay software via one of its three APIs to provide Vera-like presresentations of its ZWave devices.
          Yes, you still need the ZWave licence key and the software.
            @akbooer said in openLuup Z-Way bridge: Version Log:
            Cool, thanks!
              Development Branch: 2020 Release 7.12
              • add CC91, Central Scene (for Remotec ZRC90)
              • thanks @CatmanV2, @ArcherS
                Thanks, @akbooer !
                  Development Branch: 2020 Release 7.14
                  • correct CC91 variable: sl_CentralScene
                    Development Branch: 2020 Release 11.24
                    • add category_num to devices
                    If the device type is recognised, the category_num is set appropriately (subcategory_num is not currently set.)
                    • D Offline
                      D Offline
                      Donato
                      Hi akbooer,
                      have in your plans or request to develop for openluup a bridge to other z-wave stick (aeotec z-stick, vera atom ezlo v2) or rpi daughter cards (aeotec z.pi 7) ?
                      Is the actual z-way bridge stable as far as you konw ?
                      I'm looking for a stable zwave sw/hw solution on rpi/openluup.
                      tnks
                      donato
                        The ZWay stick (and Razberry board) and plug-in are the best I can offer so far, and pretty stable AFAIK. I definitely won’t be doing anything for Ezlo. The Aeotec stick API was a bit of a nightmare last time I looked, I don’t recall if anyone else did anything on that.
                        I wonder if anyone else has any thoughts?
                        • D Offline
                          D Offline
                          Donato
                          tnks akbooer,
                          I'll try the zway stick or board .
                          did you try the razberry board version 7 ?
                            The version I have is rather old, so I guess not. But the API should be the same.
                            The board should come with a licence, but the stick may require it as an additional purchase?
                              There is an additional license for the Z-Way software, but I would say it is well worth it. My experience is that it's extremely stable (haven't crashed once in the years i've had it), and the control of the network through the expert panel is probably the best you can find.
                              The "Smart Home" UI is not great, but it doesn't matter much if you're using openLuup. 🙂
                              • D Offline
                                D Offline
                                Donato
                                tnks PerH for your info.
                                I'll update you as soon as possible about version 7 (board and stick).
                                • D Offline
                                  D Offline
                                  Donato
                                  I've installed z-way UZB stick (most recent version) on rpi4 with bullseye os 32 bit and z-way controller (it doesn't run on 64 bit yet).
                                  It seems all ok. I've at moment added a fibaro switch and it's running ok.
                                  Just a question about the openluup device page : is the status of devices refreshed automatically after a command from the browser page (for example a click to turn on/off a switch) ? it seems not
                                    No, the devices page (or any other in the openLuup console, except the Lua Test pages) does not update, it has to be refreshed.
                                    This was an early decision that made the console much simpler, and went with the assumption that AltUI would be the de-facto interface. The console evolved over time to be much more complete and now it would benefit from a complete rewrite to make it update in real time. Not likely to happen in the near future. Is this a problem?
                                    • D Offline
                                      D Offline
                                      Donato
                                      no akbooer, no problem . I have to control the device via sw (lua).
                                      p.s. excuse if I use this post to ask another question about openluup console : can you confirm that isn't possible to define a device trigger variable through your console (trigger table -> create) ?
                                        Yes, that's true. Sadly, that page is only a stub at the moment (in fact it shows the session cookies, which isn't much help to you.)
                                        AltUI has its own device watch triggers, of course, and openLuup has its own (currently hidden) way of triggering from variable changes, which would make it possible to use even in the absence of AltUI, but the console pages to do this haven't yet been finished. There didn't seem to be much demand for this.
                                          164.5k
