  3. Zway Bridge
  4. Help with Z-Way plugin
full devices reset
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Renaming device name...
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Zway Bridge
Z-way token Expiration
Zway Bridge
Zway Bridge
XMLs & jsons without vera
P
Zway Bridge
Error after device delete
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Child device undo failure
Zway Bridge
K
Zway Bridge
Zway Bridge
z-way with home assistant
Zway Bridge
56 Posts 9 Posters 28.0k Views 10 Watching
  • J Offline
    J Offline
    JMK
    _John.
    • I Offline
      I Offline
      iRobot
      wrote on last edited by iRobot
      I'm expecting the experts will chime in soon.
      But to get you started, I will try to help with what I know.
      You need to "link" the Z-Way plugin to your Z-Way "server". Because both of them run on the same RPi you only need to enter the credentials you use to login to your Z-Way. This should be the message you see on the plugin in openLuup.
      Entering the credentials can be done in the plugin under actions. Enter your username and password and click on the login button.
      Hope this helps.
      • J JMK
        _John.
        @JMK
        Welcome!
        I think @iRobot said it all on the previous post. It sounds like you are almost there. You just need to set the bridge up to talk to the z-way-server on the pi.
        The only thing I would add is that you need to make sure of, is to enable the API on the z-way-server under the app/z-wave menu
          @JMK said in Help with Z-Way plugin:
          Definitely the right place!
          • propheadP Offline
            propheadP Offline
            prophead
            Is it best to have zway server on its own pi and run openluup on a second pi or both on the same pi? My lans fast and it seems like 2 pis will distribute load better. Will I have any issues running two different zwave networks in the same house as I make my slow transition? Can zway server work entirely locally with no internet? If I do start a zway only pi should I use their prepackaged os image or start from the Raspbian I know?
            TIA
              From the loading POV, it’s simply not an issue. My machine (RPi3) running openLuup, ZWay and a bridge to Vera runs at about 3% utilisation, on average. @rafale77 will no doubt mention that it is the peak, not the average which matters, but I still stick to the mantra that HA shouldn’t need vast amount of power. Only things like video and perhaps TTS, etc, but they’re generally done with quite different boxes. System management is easier with just one machine (I upgraded to Debian Buster.). Yes, it all works with no internet connection (after initial downloads!). I run two Zwave networks quite happily, albeit with a physical overlap only in the centre of the house.
              • propheadP Offline
                propheadP Offline
                prophead
                Again, thank you for your insight
                • J Offline
                  J Offline
                  JMK
                  @IRobot - If I go to the 'Actions' tab of the Z-Way plugin I cannot enter anything.
                  I'm still stumped - am I missing something basic here?
                  Regards, John.
                    Yup, wrong implementation file. How did you install it?
                    You need I_ZWay2.xml.
                    • J Offline
                      J Offline
                      JMK
                      From instructions in the Z-Way Essentials manual dated March 31st, 2020. Section 3.1 "wget -q -O - http://razberry.z-wave.me/install | sudo bash"
                      • J Offline
                        J Offline
                        JMK
                        Or did you mean openLuup: User Guide - version 2018.07.21, Section 1 and Section 2.
                          No, neither, I think. I am talking about the openLuup ZWay plugin device itself. The image you showed of the empty actions tag has the device attributes greyed out in the background. From there I see that you have I_ZWay.xml whereas it should be I_ZWay2.xml. So I am worried about the version of its other files too.
                          You can just manually change this attribute to the correct one and restart to see if that fixes things, but the problem may be deeper than that. What version does it say it is?
                          • J Offline
                            J Offline
                            JMK
                            Changed the implementation file..
                            9a688f53-f38e-4135-ba4a-e1a2dd21c728-image.png Here is the version...ba048e59-6aea-4282-9c00-12df850c802e-image.png
                            • J Offline
                              J Offline
                              JMK
                              I could not see any Z-Wave devices after changing the implementation file.
                                The version number is very old - totally the wrong thing. Go to the AltUI > More > App Store page, find the ZWay plugin there, and click on the Alt button to download the latest. It should be version 20.5.4b (GitHub.master).
                                • J Offline
                                  J Offline
                                  JMK
                                  Did as you said, now no version number...79c2a084-7096-480f-b78b-826e17fd55f4-image.png
                                  I can't help feeling there is something fundamentally wrong here but I have insufficient knowledge to identify what it is. 😕
                                    Did you you reload the luup engine after changing the implementation file to I_Zway2.xml?
                                    Did you check that the file exists in the /etc/cmh-ludl folder?
                                      I see this has a new device number, so if device #5 is still there, then delete it.
                                      I'd like to see the startup log and the openLuup console page Scheduler > Plugins
                                      It really, really, shouldn't be as much of a pain as this. I don't have a clear picture of quite how things went wrong in the first place.
                                        @rafale77 said in Help with Z-Way plugin:
                                        Actually, it won't be there. Only L_Zway2.lua is a physical file. All its other device files are part of openLuup's virtual storage system.
                                          Ohh yes you are right. Sorry about this. I was thinking of the lua file indeed.
                                            1.1k
                                            158.2k
