  3. Zway Bridge
  4. Help with Z-Way plugin
full devices reset
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Renaming device name...
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Zway Bridge
Z-way token Expiration
Zway Bridge
Zway Bridge
XMLs & jsons without vera
P
Zway Bridge
Error after device delete
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Child device undo failure
Zway Bridge
K
Zway Bridge
Zway Bridge
z-way with home assistant
Zway Bridge
56 Posts 9 Posters 27.6k Views 10 Watching
    #41
    zway username and password set in the plugin variables?
      Where?
      I used "Actions" - login, and set "no expire" on the emerging connection in z-way..?
      • PerHP PerH
        Where?
        @PerH
        Go to the openLuup console from your openLuup device you can see the access to the console interface:
        Then go into devices/z-way bridge and under actions, login
          Done, no difference..
          Same entrys in the startuplog as before.. ?
          Noticed that "file not found: cgi/zway_cgi.lua" comes up when i try the "Configure ZWay child devices" button, is that a clue of something?
            that's not good. You need that file. seems like your plugin is not completely installed.
            see that you have the files in this repo all installed:
            GitHub - akbooer/Z-Way: Zway plugin for openLuup
            Zway plugin for openLuup . Contribute to akbooer/Z-Way development by creating an account on GitHub.
            the cgi file under the /cgi folder needs to be in the /cgi folder in openLuup.
              Fixed. all files are in place, still no devices..
              This is all that shows up when i try the "Configure ZWay child devices" :
                do you see username/password/session id in the plugin device variables?
                  SessionID at the bottom there?
                    yes, looks like your plugin works and is communicating with z-way. Now in your z-way automation UI/API, you may not have completed interviews? Not sure. Would wait for @akbooer here. A bit surprising that you are not seeing any nodes.
                      All four connected devices have 100% interviews.
                      Thanks for helping so far.
                        Tried to delete the plugin and install it from appstore:
                        2020-11-04 20:28:49.866   luup_log:4: AltAppStore : downloading akbooer/Z-Way [master] to trash/AltAppStore/
                        2020-11-04 20:28:49.866   luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/akbooer/Z-Way/contents?ref=master
                        2020-11-04 20:28:49.875   luup_log:4: AltAppStore : error downloading: unknown error
                        Same issue with both master and dev branch, and any other way i try really, no idea why..
                        Same actually happens with all plugins now.. Great! leaving the computer for the evening.
                          #52
                          If you can, try installing the files from the github repo instead of going through the altappstore? It looks like you have some problems with it. Also from your previous screenshot, it doesn't look like your password and username are in your variables so you didn't succesfully connect to z-way. Is the IP address for z-way correct? You seem to be running both on the same machine?
                            Yes, same machine. 127.0.0.1 should work then?
                            There was an established connection i z-way though?
                            Anyway, the plugin is gone now, and i can't reinstall it.. the unknown error comes no matter what i do, and I have no idea where to look for errors..
                            How do I install it directly from github?
                            The files are in cmh-ludl, but i can't create a device without an implementation file right?
                              hmm.. tried to log on to z-way using the AltUI user i created for the bridge, and sees no apps or devices.. tried with the account as "local user" and "user", no difference.. mabye thats why it showed no devices?
                              • D Offline
                                D Offline
                                Donato
                                Hi akbooer,
                                I've defined in z-way controller a Virtual Device (a virtual binary switch) but I can't see it on openluup with z-way plugin installed while I can see a real switch.
                                Is it correct ? Are the z-way virtual device using different API not implemented in openluup ?
                                tnks
                                donato
                                  No, only physical Zwave devices are mapped by the bridge.
                                    152.9k
