  3. Zway Bridge
  4. Error after device delete
full devices reset
Zway Bridge
Help with Z-Way plugin
Zway Bridge
Zway Bridge
Zway Bridge
Renaming device name...
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Zway Bridge
Z-way token Expiration
Zway Bridge
Zway Bridge
XMLs & jsons without vera
P
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Child device undo failure
Zway Bridge
K
Zway Bridge
Zway Bridge
z-way with home assistant
Zway Bridge
4 Posts 2 Posters 1.4k Views 2 Watching
    wrote on last edited by PerH
    One of my wall plugs died yesterday, so i had to delete it without exclusion. When I did this, the openluup device switched to this:
    And some .js issues arrived at the bottom of the screen:
    What to do?
      This is an AltUI issue. Have you simply tried refreshing the browser?
        Hard refresh didn't work..
        You're right offcourse, everything is fine in the openluup devices list. I'll shoot a message to @amg0, as i doesn't seem to active in this forum.
          It may be that you have a variable watch (or scene trigger?) defined for one or more of that device's variables. You should be able to delete this reference manually, if that's so.
            154.4k
