  3. Zway Bridge
  4. full devices reset
full devices reset
Zway Bridge
Help with Z-Way plugin
Zway Bridge
Zway Bridge
Zway Bridge
Renaming device name...
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Zway Bridge
Z-way token Expiration
Zway Bridge
Zway Bridge
XMLs & jsons without vera
P
Zway Bridge
Error after device delete
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Child device undo failure
Zway Bridge
K
Zway Bridge
Zway Bridge
z-way with home assistant
Zway Bridge
full devices reset
77 Posts 2 Posters 46.0k Views 2 Watching
    Yes please. You have my email, I think?
    • DesTD Offline
      DesTD Offline
      DesT
      @akbooer You should have them in private message here
        This is slightly tricky, partly because it's at least three years since I looked at this, and also because some of the ZWay devices are subsumed into single Luup devices and others are split into separate children.
        My philosophy, currently, is not to change the plugin (since I can't easily test it) but to provide a script to run which will make the changes.
        You also have a ZWay "global room" which doesn't get uniquely mapped into any single openLuup room...
        • DesTD Offline
          DesTD Offline
          DesT
          That's fine if it's a script instead of having a new plugin version 😉
            • DesTD Offline
              DesTD Offline
              DesT
              Just for fun, am I able to execute the script myself when I'm doing changes ?
                #27
                Oh yes, it just runs in the openLuup LuaTest window.
                Before I let you loose on it, there are a couple of tweaks needed. I’ve used the ZWay devices file you sent, obviously, and put it into the cmh-ludl folder so that the script can find it. Is that a reasonable mode of working?
                Otherwise, I could get it to pick up the info from the bridge itself, but then I’d need to make some changes to that, and an update to openLuup too. Not a huge deal, I hope, but, again, I’m not able to test it.
                Either way, you’d need to ensure that you had a backup of your latest user_data.json, in case of emergencies.
                  OK, so I decided to update the bridge to make this a bit easier.
                  Please update to the latest development versions of both openLuup and ZWay.
                  Then I'll provide a test script to see if this pulls the relevant data correctly.
                  • DesTD Offline
                    DesTD Offline
                    DesT
                    Done. I'm not on both dev version 😉
                      OK, so running this in LuaTest should (if I modified the bridge correctly) provide the same listing as I sent previously. It should NOT make any changes to the system.
                      -- script to rename ZWay devices in openLuup
                      local json = require "openLuup.json"
                      local zway = luup.openLuup.find_device {device_type = "ZWay"}
                      local DEVS = luup.devices[zway].environment.DEVS
                      local Offset = luup.variable_get("urn:akbooer-com:serviceId:ZWay1", "Offset", zway)
                      -- lookup table for existing Luup rooms
                      local function room_index()
                        local idx = {}
                        for i,n in pairs(luup.rooms) do
                          idx[i] = n
                          idx[n] = i
                        return idx
                      -- Luup device numbers in running system, indexed by altid
                      local function luup_devNos(block)
                        block = tonumber(block)
                        local devs = {}
                        for i,d in pairs(luup.devices) do
                          if i > block then
                            local id = d.id
                            devs[id] = i
                        return devs
                      -- ZWay devices: ids, names, locations
                      local function zDevs(devices)
                        local devs = {}
                        for i, d in ipairs(devices) do
                          local id = d.id: match "ZWayVDev_zway_(.+)" or '?'
                          local shortId = id: match "^%d+%-%d+"
                          local shortId = id: match "^(%d+%-%d)%-%d+$"
                      --    print(id, shortId)
                          devs[i] = {id = id, shortId = shortId, roomName = d.locationName, name = d.metrics.title}
                        return devs
                      -- Start here
                      local D = DEVS
                      local rename = "[%d] %45s  ->  %-s"
                      local placename = "%s / '%s'"
                      local devNos = luup_devNos(Offset)
                      local zdevs = zDevs(D)
                      local rooms = room_index()
                      for i, d in ipairs(zdevs) do
                        local id = d.id
                        local name = d.name
                        local shortId = d.shortId
                        local roomName = d.roomName
                        local dno = devNos[shortId] or devNos[id]
                        if (dno) then
                          local dev = luup.devices[dno]
                          local oldName = dev.description
                          local oldRoom = rooms[tonumber(dev.attributes.room)]
                          roomName = rooms[roomName] and roomName or oldRoom    -- leave in place if new room not found
                          newRoom = roomName ~= oldRoom
                          newName = name ~= oldName
                          if newRoom or newName then
                            print(rename:format(dno or 0, placename:format(oldRoom, oldName) , placename:format(roomName, name)))
                      • DesTD Offline
                        DesTD Offline
                        DesT
                          OK, I thought we should probably build up slowly, but went for broke.
                          Try just this in the LuaTest:
                          print(pretty(DEVS))
                          • DesTD Offline
                            DesTD Offline
                            DesT
                              Ah, I feared that would be the case…
                              ..and ZWay is up and running OK?
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                yeah of course
                                  We could revert to reading the file, but if you’re not too much in a rush, then I’ll try to fix this.
                                  • DesTD Offline
                                    DesTD Offline
                                    DesT
                                    nah no worries, I can copy the file... zway and openLuup is on the same machine, so it's pretty easy to copy the file
                                    • DesTD Offline
                                      DesTD Offline
                                      DesT
                                      I can even make a symbolic link 😉
                                        OK, here the modified script.
                                        Change the file name and folder to your chosen place in line 3.
                                        Again, this should just produce the listing, not make changes.
                                        filename = "Des/DES_ZWay.json"  -- change this to the right place
                                        local function read_ZWay_data(filename)
                                          local f = io.open (filename)
                                          if not f then error "file not found" end
                                          local j = f: read "*a"
                                          f: close()
                                          local D = json.decode (j)
                                          return D.data.devices
                                          local idx = {}
                                            idx[i] = n
                                            idx[n] = i
                                          return idx
                                          local devs = {}
                                            if i > block then
                                              local id = d.id
                                              devs[id] = i
                                          return devs
                                          local devs = {}
                                          return devs
                                        -- Start here
                                        local D = read_ZWay_data (filename)
                                          local id = d.id
                                          local name = d.name
                                          if (dno) then
                                        • DesTD Offline
                                          DesTD Offline
                                          DesT
                                          it's working
                                            147.6k
