  2. Blogs
  3. Another transition from Vera to OpenLuup And now to HASS - PerH
Seeking Advice:
Blogs
L
Blogs
Blogs
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
118 Posts 9 Posters 88.6k Views 10 Watching
    So, the resolution to the recent errors was that the UZB Stick was set up with "Bridge" firmware! to fix, go to ExpertUI - Network - Control - Firmware - Switch to "Normal" Firmware.
    I may have been blinded by the "F**k, nothing i try works", but i think this detail could be more visible to beginners in some way, i.e. a small pop-up message when you try to add sensors in a-way (which requires normal mode FW).. I will pitch this to the z-way guys.
    Onwards!
      Rebooted the box, and now Openluup won't start. (this probably relates to my appstore-issues as well)
      The issue is the Libcurl.so.4.
      ● openluup.service - openLuup and AltUI Server for Vera 3
         Loaded: bad-setting (Reason: Unit openluup.service has a bad unit file setting.)
         Active: inactive (dead)
      Nov 05 10:26:21 Chromebox systemd[1]: /etc/systemd/system/openluup.service:9: Executable "curl" not found in path "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
      per@Chromebox:/etc/cmh-ludl$ curl
      curl: /lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_4' not found (required by curl)
      I'v done the stuff you need to get libcurl 3 going for z-way, and probably f**ked it up somehow.
      Can anyone help me reset this with some well chosen command line words?
        Did this:
        @rafale77 said in z-way-server ubuntu install:
        @PerH
        The problem is that libcurl3 is not in the standard repo you have listed.
        assuming you are on ubuntu download it from here:
        Ubuntu – Error
        You need to pick from the correct platform.
        wget --url you can paste from the link above--
        i.e
        wget http://no.archive.ubuntu.com/ubuntu/pool/universe/c/curl3/libcurl3_7.58.0-2ubuntu2_amd64.deb
        downloading from the norwegian mirror for x64
        Then run
        dpkg -i libcurl3_7.58.0-2ubuntu2_amd64.deb
        might need sudo authority to install.
        Edit: Another idiot way to do it is to not install libcurl3 at all and instead create a symbolic link for libcurl3 to call libcurl4 (That's how I am running mine 🤘 )
        sudo ln -s /usr/local/x86_64-linux-gnu/libcurl-gnutls.so.4 /usr/local/x86_64-linux-gnu/libcurl-gnutls.so.3
        sudo ln -s /usr/local/x86_64-linux-gnu/libcurl.so.4 /usr/local/x86_64-linux-gnu/libcurl.so.3
        Note that you will need to find where your libcurl library was installed. I just gave you the ubuntu location.
        and
        apt install curl
        systemctl disable openluup.service
        systemctl enable openluup.service
        systemctl start openluup.service
        up and running again. Now the appstore is OK too, commencing attempt 2 on z-way bridge.
          wrote on last edited by PerH
          #44
          Got some work done today too.
          Z-way Bridge is working well, logged in with the admin account for the moment, as the AltUI account I created shows no devices in z-way smarthome.. (this may be why i didnt get them in the last time)..
          InfluxDB is running on the chromebox, saving data to an external SSD.
          Decided to go for a slow migration stratergy - one by one, instead of cloning the Vera. It's about 25 units, but I figured this will be an easier transition to do while running the house..
          Next step is zigbee. As i've understood it, you need HASS installed to take these off the Vera? at least until Rafale77 &Co makes DeCONZ work with OpenLuup?
          Not very happy with vera's support on these either, there must be better alternatives. 🙂
            For zigbee, there are multiple options.
            I am personally using the zha component of home assistant and then synchronizing the ha device status and commands with openluup. It takes a bit of coding and is not a bridge per say. I have been considering moving the conbee to deconz and then write a bridge for it but never got into it due to these insane work hours I am facing now that we are working from home... I guess I should be grateful I still have a job. The way I am doing it is not very scalable but I only have 15 zigbee devices. If I had plans for more I would definitely be more motivated to create a proper bridge for either deconz or home-assistant but time... is what I am missing.
              Ok, think I'll hold a while on zigbee then.. mabye even just find an aqara hub in the mean time, I really like the aqara sensors..
              That thing called "work" takes way too much time over here too, considering the 10000 projects at home. 😉
              I Migrated 25 z-way units last night, and it became evident how superior Z-way is in device handling! All but one popped in at 100% interview at first attempt, only one old wall plug stopped at 92% (but it works)..
              One issue i'd like to sort out, I have a Heatit/namron/Sunricher Z-push 8 button that refuses to assiciate with Fibaro dimmer 2 and wall plug. I read somewhere that this may be because of what secure level they are included with?
              Z-Push:
              1de1cd0a-cf4f-4b54-97fc-2e20334c0c3b-image.png 34593184-06d4-4216-8940-37d4d8948038-image.png
              Dimmer 2:
              eef2fcd6-2059-45c2-8ce8-19ff84840082-image.png b9a7f334-66f5-41ee-826d-c8da781f6c87-image.png
              Wall Plug:
              99846e90-711b-4619-8a1b-78e4c7743768-image.png 4b9d8e49-2278-4888-8c2f-6b9ef82879e0-image.png
              • PerHP PerH
                Z-Push:
                Dimmer 2:
                Wall Plug:
                #47
                @PerH said in [Another transition from Vera to OpenLuup - PerH]
                That is very possible:
                1. Many Fibaro devices are notoriously not conformal and use some exotic zwave implementations. They are problematic in almost any controller but theirs. Don't worry about the interview not completing. You can check which command class failed to complete. I am fairly sure it is the version class which has no functional impact.
                2. You can see that the heatit device was included with S2 security while the fibaro devices included with S0 and no security from the little logo next to the name. S2 security, for as old as it is and all the improvements that it brings has only been supported by 2 controllers... z-way is one of them. No, vera is not... I have never looked at security within association groups but I suspect that it is the problem.
                  I've personally had only good experience with Fibaro, they have treated me well..
                  Solution was to include the switch and the dimmer "unsecure". all thats left in the interview are "security" and "security S2" interview..
                  Any issues to think of when using unsecure?
                  The heatit thing still shows as S2 in the Z-Way GUI though.. anyway, it works!
                  ..And how well it works! feels like a transition to from (a badly set up) apple device to a proper Android phone! 😎 So much more direct control and insight to the z-wave system!
                  All the reactors are transferred as well, and the chromebox is idling at a calm 6.7% CPU..
                  Regarding association in Z-way, the choice between Plain association, 0, 1 and 2 was a bit confusing, Plain was the one that worked. Anyone know what that is? This was a Fibaro Dimmer 2..
                    BTW: Any good way to mass-delete the "Room101" devices?
                    • PerHP PerH
                      @PerH
                      Well, yes.
                      The openLuup plugin has an action EmptyRoom101 which requires a ‘yes’ answer to the AreYouSure parameter (to avoid accidental deletion.)
                      Use it from the plugin’s Actions page.
                      • PerHP PerH
                        @PerH said in Another transition from Vera to OpenLuup - PerH:
                        Other than the fact that they are insercure, no...
                        Glad it's working for you and I agree with the feeling, not so much with the comparison. 😛 To me it rather be "feels like a transition to from properly setup Android device to an out of the box iphone!" No more random stuff all over the place with half of them not working as expected...
                          The reply is expected offcourse.. 🙂 My imression is probably from never actually getting a out-of-the-box apple device that just works.. My work pushes them on me, and i give them to my wife..
                          What's so unsecure about it? how could they be compromised? OK, i could just read up about it.. 😉
                            #53
                            Regarding security of zwave:
                            The issue with non secure zwave is that one could use a zniffer and figure out what your network homeid is and spoof a controller with that id and then take control of your device. This won't happen with a security encoding which requires a key exchange (and 4x the number of packets exchanged to execute the same command). I actually experimented with it, having discovered my neighbor's homeid. If it is a light switch, big deal... I don't care, if it is a lock or security sensor... that's a different story. S2 security improves both the encoding and streamlines the security key exchange making it much more efficient, effectively cutting the traffic by half... impactful when it is a battery operated device (battery life) and knowing how tight the zwave bandwidth is.
                              Thanks, I'll take my chances that noone with do a hostile takeover on my living room lights. 🙂
                              Noticed that i have some "system error" and "Heat alarms" that is triggered on some switches/dimmers, dimmers that are running 10 watts.. no visible problems with them, so i wonder why? When will they reset?
                              I'd like to decipher these to full sentences, as the codes' meaning are explained in the manual.. any way to give the code to i.e. Reactor?
                              • PerHP PerH
                                If they’re available to the API that the ZWay plugin uses, then this should be possible. There is already a module in openLuup which is used for fixed text lookups (mime types, HTTP error code, ....)
                                  Well done. Glad it's worked out for you!
                                    Anyone here using ZiGate USB? in my search for an easy way to a functioning zigbee system, that seems like a good solution?
                                    49 EUR
                                    ZiGate+ USB
                                    ZiGate+ USB
                                    ZiGate permet d'interfacer vos objets compatibles ZigBee® à votre ordinateur ou box domotique. FONCTIONS : Contrôleur Zigbee Supporte une large gamme de capteurs et d'actionneurs Ouverte, performante et évolutive Comparaison avec la ZiGate ancienne génération : Nouveau design et meilleure ergonomie...
                                      I have one and tested it. It's very immature and doesn't work well. There is even a zigate plugin on openLuup which... doesn't work. As French as I am and really wanted it to work... it was a disappointment.
                                        I went ahead and gave it a shot. Can't really see any better ways to zigbee in openluup right now.. Vera is hopeless, ezlo plus equally hopeless (probably for years), HASS has no real bridge for interaction.. Have you looked at domoticz? That at least has a bridge plugin available?
                                          domoticz is similar to home assistant on the zwave side since it uses the openzwave library as its zwave controller. It is not nearly as developed as Home Assistant though and yes I installed it to play with it at one point thinking about using the existing bridge but decided, given the fact that I have only a dozen devices to bridge over, to skip the bridge and just to call the Home Assistant API manually.
                                            148.2k
