  2. Blogs
  3. Another transition from Vera to OpenLuup And now to HASS - PerH
Seeking Advice:
Blogs
L
Blogs
Finally gave up on my Ezlo Plus
Blogs
PerHP
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
My migration from Vera, or what I did on my holidays
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
118 Posts 9 Posters 93.3k Views 10 Watching
    @PerH, Don't be too fast at resetting things. This is not a vera. It is possible that your device is not responding as expected. I often had to manually interview devices by calling the command classes one by one. Click on the "view interview result" and you should see the list of command classes. You can then see which ones are missing.
      Hehe, OK.
      I'm still finding it odd that my system says that the Z-Way controller is reported as "Dead" in the device list though, that makes me think that the device or communication is not going well..
      e29834c1-0ccf-48b0-a4bd-4d6c93a49cda-image.png Despite of this, i can actuate the switch even if the expert panel says i'm not.
      some strange callback errors in the log:
      [2020-11-03 14:47:06.133] [I] [z-way] Job 0x13 (SwitchBinary Get): Delivered
      [2020-11-03 14:47:06.133] [D] [z-way] SendData Response with callback 0x13 received: received by recipient
      [2020-11-03 14:47:06.133] [D] [z-way] SETDATA devices.6.data.lastSendInternal = **********
      [2020-11-03 14:47:06.133] [D] [z-way] SETDATA devices.6.data.lastSend = 389830 (0x0005f2c6)
      [2020-11-03 14:47:06.133] [D] [z-way] Job 0x13 (SwitchBinary Get): success
      [2020-11-03 14:47:06.133] [I] [z-way] Waiting for job reply: SwitchBinary Get
      [2020-11-03 14:47:06.153] [D] [z-way] RECEIVED: ( 01 0C 00 A8 00 01 06 03 25 03 00 00 C9 B0 )
      [2020-11-03 14:47:06.153] [D] [z-way] SENT ACK
      [2020-11-03 14:47:06.153] [W] [z-way] No job of class 0xa8 is waiting for callback 0x00
      [2020-11-03 14:47:06.153] [I] [z-way] Unhandled callback for function 0x00
      [2020-11-03 14:47:06.153] [I] [z-way] Removing job: Unknown function class
      So, before I look at the devices, i need to find out why the server and stick communication is throwing errors..
        One other thing, sometimes (i think on some reset of something), the port address to the stick changes from "ttyACM0" to "ttyACM1" for some anoying reason.. any ideas?
          Result in the log of trying the "basic set" interview manually:
          [2020-11-03 15:18:46.829] [I] [z-way] Adding job: Basic Get
          [2020-11-03 15:18:46.830] [D] [z-way] SENDING (cb 0x3c): ( 01 09 00 13 06 02 20 02 25 3C DA )
          [2020-11-03 15:18:46.832] [D] [z-way] RECEIVED ACK
          [2020-11-03 15:18:46.840] [D] [z-way] RECEIVED: ( 01 04 01 13 01 E8 )
          [2020-11-03 15:18:46.840] [D] [z-way] SENT ACK
          [2020-11-03 15:18:46.840] [D] [z-way] Delivered to Z-Wave stack
          [2020-11-03 15:18:46.860] [D] [z-way] RECEIVED: ( 01 05 00 13 3C 00 D5 )
          [2020-11-03 15:18:46.860] [D] [z-way] SENT ACK
          [2020-11-03 15:18:46.861] [I] [z-way] Job 0x13 (Basic Get): Delivered
          [2020-11-03 15:18:46.861] [D] [z-way] SendData Response with callback 0x3c received: received by recipient
          [2020-11-03 15:18:46.861] [D] [z-way] SETDATA devices.6.data.lastSendInternal = **********
          [2020-11-03 15:18:46.861] [D] [z-way] SETDATA devices.6.data.lastSend = 56446 (0x0000dc7e)
          [2020-11-03 15:18:46.861] [D] [z-way] Job 0x13 (Basic Get): success
          [2020-11-03 15:18:46.861] [I] [z-way] Waiting for job reply: Basic Get
          [2020-11-03 15:18:46.874] [D] [z-way] RECEIVED: ( 01 0C 00 A8 00 01 06 03 20 03 00 00 C7 BB )
          [2020-11-03 15:18:46.874] [D] [z-way] SENT ACK
          [2020-11-03 15:18:46.874] [W] [z-way] No job of class 0xa8 is waiting for callback 0x00
          [2020-11-03 15:18:46.874] [I] [z-way] Unhandled callback for function 0x00
          [2020-11-03 15:18:46.874] [I] [z-way] Removing job: Unknown function class
          [2020-11-03 15:18:48.987] [W] [z-way] Reply not received before timeout for job (Basic Get)
          To me, it looks like the unit is responding, and the server is having a "senior moment".. ?
            Hmm this is indeed a bit strange.
            On the port address changing... it is a common linux problem, widely reported for many devices.
            linux recreates and iterates another id for a usb device when it resets. I had this problem even with the vera when I ran it off of a usb dongle. The solution to this is to use another path to the port:
            run
            ls /dev/serial/by-id
            and find the id of the uzb. Mine looks like this:
            usb-0658_0200-if00 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2211489-if00
            I have both a uzb and a conbee stick plugged into my mini PC. You can then use this port /dev/serial/by-id/usb-xxxx_xxxx-xxxx
            instead of /dev/ttyACMn.
            For your other issue, you might be right. Maybe reset then as I am have never seen this behavior before.
              Thanks, I did that now, so one issue less i guess. 🙂
              One thing i've read is that z-way needs a "V8 engine" called libv8 (3.24.37). This is as far as i've found not native in Debian buster, can this be whats missing here?
                So, the resolution to the recent errors was that the UZB Stick was set up with "Bridge" firmware! to fix, go to ExpertUI - Network - Control - Firmware - Switch to "Normal" Firmware.
                I may have been blinded by the "F**k, nothing i try works", but i think this detail could be more visible to beginners in some way, i.e. a small pop-up message when you try to add sensors in a-way (which requires normal mode FW).. I will pitch this to the z-way guys.
                Onwards!
                  Rebooted the box, and now Openluup won't start. (this probably relates to my appstore-issues as well)
                  The issue is the Libcurl.so.4.
                  ● openluup.service - openLuup and AltUI Server for Vera 3
                     Loaded: bad-setting (Reason: Unit openluup.service has a bad unit file setting.)
                     Active: inactive (dead)
                  Nov 05 10:26:21 Chromebox systemd[1]: /etc/systemd/system/openluup.service:9: Executable "curl" not found in path "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
                  per@Chromebox:/etc/cmh-ludl$ curl
                  curl: /lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_4' not found (required by curl)
                  I'v done the stuff you need to get libcurl 3 going for z-way, and probably f**ked it up somehow.
                  Can anyone help me reset this with some well chosen command line words?
                    Did this:
                    @rafale77 said in z-way-server ubuntu install:
                    @PerH
                    The problem is that libcurl3 is not in the standard repo you have listed.
                    assuming you are on ubuntu download it from here:
                    Ubuntu – Error
                    You need to pick from the correct platform.
                    wget --url you can paste from the link above--
                    i.e
                    wget http://no.archive.ubuntu.com/ubuntu/pool/universe/c/curl3/libcurl3_7.58.0-2ubuntu2_amd64.deb
                    downloading from the norwegian mirror for x64
                    Then run
                    dpkg -i libcurl3_7.58.0-2ubuntu2_amd64.deb
                    might need sudo authority to install.
                    Edit: Another idiot way to do it is to not install libcurl3 at all and instead create a symbolic link for libcurl3 to call libcurl4 (That's how I am running mine 🤘 )
                    sudo ln -s /usr/local/x86_64-linux-gnu/libcurl-gnutls.so.4 /usr/local/x86_64-linux-gnu/libcurl-gnutls.so.3
                    sudo ln -s /usr/local/x86_64-linux-gnu/libcurl.so.4 /usr/local/x86_64-linux-gnu/libcurl.so.3
                    Note that you will need to find where your libcurl library was installed. I just gave you the ubuntu location.
                    and
                    apt install curl
                    systemctl disable openluup.service
                    systemctl enable openluup.service
                    systemctl start openluup.service
                    up and running again. Now the appstore is OK too, commencing attempt 2 on z-way bridge.
                      wrote on last edited by PerH
                      #44
                      Got some work done today too.
                      Z-way Bridge is working well, logged in with the admin account for the moment, as the AltUI account I created shows no devices in z-way smarthome.. (this may be why i didnt get them in the last time)..
                      InfluxDB is running on the chromebox, saving data to an external SSD.
                      Decided to go for a slow migration stratergy - one by one, instead of cloning the Vera. It's about 25 units, but I figured this will be an easier transition to do while running the house..
                      Next step is zigbee. As i've understood it, you need HASS installed to take these off the Vera? at least until Rafale77 &Co makes DeCONZ work with OpenLuup?
                      Not very happy with vera's support on these either, there must be better alternatives. 🙂
                        For zigbee, there are multiple options.
                        I am personally using the zha component of home assistant and then synchronizing the ha device status and commands with openluup. It takes a bit of coding and is not a bridge per say. I have been considering moving the conbee to deconz and then write a bridge for it but never got into it due to these insane work hours I am facing now that we are working from home... I guess I should be grateful I still have a job. The way I am doing it is not very scalable but I only have 15 zigbee devices. If I had plans for more I would definitely be more motivated to create a proper bridge for either deconz or home-assistant but time... is what I am missing.
                          Ok, think I'll hold a while on zigbee then.. mabye even just find an aqara hub in the mean time, I really like the aqara sensors..
                          That thing called "work" takes way too much time over here too, considering the 10000 projects at home. 😉
                          I Migrated 25 z-way units last night, and it became evident how superior Z-way is in device handling! All but one popped in at 100% interview at first attempt, only one old wall plug stopped at 92% (but it works)..
                          One issue i'd like to sort out, I have a Heatit/namron/Sunricher Z-push 8 button that refuses to assiciate with Fibaro dimmer 2 and wall plug. I read somewhere that this may be because of what secure level they are included with?
                          Z-Push:
                          1de1cd0a-cf4f-4b54-97fc-2e20334c0c3b-image.png 34593184-06d4-4216-8940-37d4d8948038-image.png
                          Dimmer 2:
                          eef2fcd6-2059-45c2-8ce8-19ff84840082-image.png b9a7f334-66f5-41ee-826d-c8da781f6c87-image.png
                          Wall Plug:
                          99846e90-711b-4619-8a1b-78e4c7743768-image.png 4b9d8e49-2278-4888-8c2f-6b9ef82879e0-image.png
                          • PerHP PerH
                            Z-Push:
                            Dimmer 2:
                            Wall Plug:
                            #47
                            @PerH said in [Another transition from Vera to OpenLuup - PerH]
                            That is very possible:
                            1. Many Fibaro devices are notoriously not conformal and use some exotic zwave implementations. They are problematic in almost any controller but theirs. Don't worry about the interview not completing. You can check which command class failed to complete. I am fairly sure it is the version class which has no functional impact.
                            2. You can see that the heatit device was included with S2 security while the fibaro devices included with S0 and no security from the little logo next to the name. S2 security, for as old as it is and all the improvements that it brings has only been supported by 2 controllers... z-way is one of them. No, vera is not... I have never looked at security within association groups but I suspect that it is the problem.
                              I've personally had only good experience with Fibaro, they have treated me well..
                              Solution was to include the switch and the dimmer "unsecure". all thats left in the interview are "security" and "security S2" interview..
                              Any issues to think of when using unsecure?
                              The heatit thing still shows as S2 in the Z-Way GUI though.. anyway, it works!
                              ..And how well it works! feels like a transition to from (a badly set up) apple device to a proper Android phone! 😎 So much more direct control and insight to the z-wave system!
                              All the reactors are transferred as well, and the chromebox is idling at a calm 6.7% CPU..
                              Regarding association in Z-way, the choice between Plain association, 0, 1 and 2 was a bit confusing, Plain was the one that worked. Anyone know what that is? This was a Fibaro Dimmer 2..
                                BTW: Any good way to mass-delete the "Room101" devices?
                                • PerHP PerH
                                  @PerH
                                  Well, yes.
                                  The openLuup plugin has an action EmptyRoom101 which requires a ‘yes’ answer to the AreYouSure parameter (to avoid accidental deletion.)
                                  Use it from the plugin’s Actions page.
                                  • PerHP PerH
                                    @PerH said in Another transition from Vera to OpenLuup - PerH:
                                    Other than the fact that they are insercure, no...
                                    Glad it's working for you and I agree with the feeling, not so much with the comparison. 😛 To me it rather be "feels like a transition to from properly setup Android device to an out of the box iphone!" No more random stuff all over the place with half of them not working as expected...
                                      The reply is expected offcourse.. 🙂 My imression is probably from never actually getting a out-of-the-box apple device that just works.. My work pushes them on me, and i give them to my wife..
                                      What's so unsecure about it? how could they be compromised? OK, i could just read up about it.. 😉
                                        #53
                                        Regarding security of zwave:
                                        The issue with non secure zwave is that one could use a zniffer and figure out what your network homeid is and spoof a controller with that id and then take control of your device. This won't happen with a security encoding which requires a key exchange (and 4x the number of packets exchanged to execute the same command). I actually experimented with it, having discovered my neighbor's homeid. If it is a light switch, big deal... I don't care, if it is a lock or security sensor... that's a different story. S2 security improves both the encoding and streamlines the security key exchange making it much more efficient, effectively cutting the traffic by half... impactful when it is a battery operated device (battery life) and knowing how tight the zwave bandwidth is.
                                          Thanks, I'll take my chances that noone with do a hostile takeover on my living room lights. 🙂
                                          Noticed that i have some "system error" and "Heat alarms" that is triggered on some switches/dimmers, dimmers that are running 10 watts.. no visible problems with them, so i wonder why? When will they reset?
                                          I'd like to decipher these to full sentences, as the codes' meaning are explained in the manual.. any way to give the code to i.e. Reactor?
                                            159.0k
