  2. Blogs
  3. Another transition from Vera to OpenLuup And now to HASS - PerH
Seeking Advice:
Blogs
L
Blogs
Blogs
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
118 Posts 9 Posters 93.0k Views 10 Watching
    By "daemonizing" I mean starting them as a daemon, which is in Unix parlance a console-less process that runs in the background (a service, if you will).
      The closest I have come to this has been running them as systemctl services. My single VM actually runs everything that way. I did so for MSR as well but no docker for me. You can put all of these command within the service file? I am actually autostarting all of my services in a sequence with dependencies: example: Do a socat reload before starting z-way. Then when z-way is up start openluup then start habridge then start homekitbridge... etc...
      PerHP 1 Reply Last reply
        wrote on last edited by PerH
        #103
        Well, as long as you state restart policy "restart: always" or "restart: unless stopped" in the docker-compose file, it will start that container on reboot as long as the docker daemon itself starts.. docker installed itself as a service, so i haven't thought about it really.
        Just to have it said; the docker-compose is just a script to rig up the containers with the correct settings. This is done once, after that the restart policy you set for the containers decides how they will live from there. you can set up as many containers as you like in one compose file.
          @rafale77
          Haven't thought about dependencies, all the stuff i'm linking together handles if one is missing.. you can set up Startup and shutdown order in the compose file, so i guess that is the docker way to handle it?
            I finally reached the finishline for the move-to-docker project! 🙂
            All applications are now inside dockers, communicating on the internal docker network.
            This makes updates easy - just update to a newer docker image. (or update in the app, in the openLuup case)
            Backup is done by copying the docker volumes to an SSD along with the indluxDB.
            Restore to any machine running docker is in principle just attaching the USB devices - install ser2net, and running one docker-compose file. Everything is set up and ready to go. Tested on an Ubuntu installed machine, and it works!
            This will offcourse take a bit more disk-space, havent summed it up yet.. But i have no plans on running this on machines with tiny storage anyway.
            One thing i'd like to improve is to get the UZB into Ser2net as well, with the advantage of accessing it from my test-system as well. Z-Way unfortunately can't take IP-serial without Socat? mabye in later updates.
            I made this sketch to keep track of the system in progress, it might be usefull to others?
              Really enlightening.
              BTW, Where do I go to find out more about “the internal Docker network”. I’m having no end of problems with openLuup not identifying incoming IPs correctly.
                I found my info here, and lookung at other docker-compose files. I've only set up a standard "bridge" network, theres more advanced methods available as well. I found that giving the containers static IP worked for me.
                You can do that in a run command, in compose or manually in portainer (but that will be gone in a reset of the setup). I'd recommend docker-compose!
                • PerHP PerH
                  @perh
                  I am using using my UZB over IP. You do need ser2net on the UZB host but you can then get anything, including socat, to pick up the socket.
                    But Z-Way needs an address to a device right? haven't looked into it.. tried to put in ip:port, didnt work..
                      Ohh I see what you mean... if using z-way then yeah I don't think it has direct socket access so you will need socat to move back from IP to a serial port.
                        #111
                        I left the system completely alone for a few weeks now, and as mentioned here, my disk filled up. A lot of strange things happens when there is no disk space, so i was suprised that it actually ran for the most part at all.
                        MSR started doing some - but not all tasks, seemed like it was when the que of actions was longer than a certain number, things got ignored. It may offcourse have been domoticz, openluup or z-way that didn't do its job, can't say for sure..
                        One lesson is - don't try to set up a container if there's not space for it! I tried installing the latest MSR while the disk was full, and ended up with corrupt files in persistent storage. I fortunately had a backup, so i'm up and running again. 🙂
                        One thing I'd like to have is a message if available disk space is under a certain level, any tips on how i can get MSR/openLuup to detect and alert me ? If there's a way to use the response from "df -h", mabye i could send a telegram msg from reactor?
                          You can get a piped response from any process you launch. I used to use df to check for mounted volumes.
                          See: https://www.lua.org/manual/5.1/manual.html#pdf-io.popen
                          • PerHP PerH
                            @perh this is the code I'm using to check for space on my Vera. Feel free to change it
                            local function getDiskSpace(path)
                                local function df()
                                    local format = "(%S+)%s+(%d+)%s+(%d+)%s+(%d+)[^/]+(/%S+)"
                                    local d = {}
                                    local p = io.popen "df"
                                    if p then
                                        local df = p:read "*a"
                                        p:close()
                                        local n = tonumber
                                        for f, b, u, a, m in df:gmatch(format) do
                                            d[#d + 1] = {file = f, blocks = n(b), used = n(u), available = n(a), mounted = m}
                                    return d
                                local dfinfo = {}
                                for _, d in ipairs(df()) do dfinfo[d.mounted] = d end
                                local x = dfinfo[path]
                                return {
                            		total = x.available + x.used,
                            		available = x.available,
                            		percentage = (x.available /(x.available + x.used) * 100)
                            local disk = getDiskSpace('/overlay') -- customize with what you want to monitor
                            luup.log("Total: " .. tostring(disk.total))
                            luup.log("Available: " .. tostring(disk.available))
                            luup.log("Percentage: " .. tostring(disk.percentage))
                            if (disk.percentage < 30) then -- alert under 30%
                                sendAlert("Overlay Partition at " .. tostring(round(d, 2)) .. "%")
                              #114
                              Nice, thanks.
                              What would be the fastest way to get that percentage value into a reactor that sends me a text?
                              I think i can wrap it into a plugin, mabye even hack it into the existing system monitor plugin?
                              If there's an even faster way to do it, chime in! 🙂
                              • PerHP PerH
                                Nice, thanks.
                                @perh said in Another transition from Vera to OpenLuup - PerH:
                                I've already done it in my own fork. The license around this plug-in is obscure, so I didn't wanted to mess with it publicly.
                                  #116
                                  Just updated Z-Way to 3.2.1 today.
                                  I had to build a new docker image for this, and pull down the container and replace it with the new image. All was done in about 10 minutes, and works well. 🙂 System-Down time was about 10 seconds..
                                  Setting up the docker system was a little work, but it is really easy to maintain once its up. 🙂
                                  Here's the docker image, there is a docker compose example in the description.
                                  There is some interesting updates in this version, MQTT client is one that may be interesting for openLuup users?
                                  Several fixes to z-wave communications as well, so it may be even more responsive now. we'll see!
                                  • PerHP PerH
                                    #117
                                    Definitely. I couldn't find a documentation about that feature, but it's doable and this could be easily directly supported under MSR as well (paging @toggledbits & @akbooer)
                                    EDIT: here's the source code of the module https://github.com/Z-Wave-Me/home-automation/blob/develop/modules/MQTTClient/index.js
                                      After about 7 years in the Vera/openLuup world i've now moved on to a home assistant installation. This was rather reluctantly, as openLuup has served me well with very few issues (other than ones I created myself off course!). A big thanks to @akbooer and all contributors for all the good work with this software!
                                      The main reason for jumping the fence to HASS was in short all the integrations and UI possibilities. The device handling for Zigbee and RFXtrx is also developing to be really good, and is still maintained.
                                      There is still plenty of annoying bugs/imperfections with HASS, but the maturity is at a level where most of what I need works well enough.
                                      My system is now:
                                      • HASS Container
                                        • Z-wave JS UI for z-wave (Still prefer Z-Way here, but the integration isn't good there yet)
                                        • ZHA for zigbee
                                        • RFXTRX plugin for 433
                                        • HASS Configurator for UI file editor for both HASS and MSR configuration files
                                      • MSR for all automations
                                      • Grafana and InfluxDB 1.8 (upgrading to 2.0 in a while)
                                      So far so good! 🙂
                                      • PerHP PerH referenced this topic on
                                        1.1k
                                        158.2k
