  2. Comments & Feedback
  3. Other Forum feedback
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
Removing Orange Notification
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
63 Posts 9 Posters 39.2k Views 8 Watching
    @DesT can we lose the spinner in the top right? Add nothing, IMHO
      Should say 'adds' not 'add' 😄
      • DesTD Offline
        DesTD Offline
        DesT
        The spinner at the top right it's about the connection to the forum. It should appear only one time and disappear after!
        • DesTD DesT
          @DesT it's not 🙂
          WiFi is maxing out at 70M on my 200M cable 🙂
          • HSD99H Offline
            HSD99H Offline
            HSD99
            Same here. The spinner is constant, and I'm on wireline at 150 Mb/s.
            • HSD99H Offline
              HSD99H Offline
              HSD99
              Something has changed. The spinner now spins for a fraction of a second during the update only, which is the desired behavior.
              DesTD 1 Reply Last reply
              • HSD99H HSD99
                DesTD Offline
                DesTD Offline
                DesT
                @HSD99 We just disable on plugin in the forum that got an update this morning causing this issue! We just send a note to the plugin's dev!
                HSD99H 1 Reply Last reply
                  Yeah it's not just the website that is fast... the response to feedback is too...
                  • DesTD DesT
                    HSD99H Offline
                    HSD99H Offline
                    HSD99
                    @DesT Thanks for the quick response!
                      Need to be able to upvote >1 😄
                      Next can we get rid of the auto insert emojies? After 20+ years of typing colon-uppercase-D to denote a smiling face, I find that I'm being told I actually want to send a dog.
                      What the duck? (autocorrect fail) 😉
                      • ElcidE Offline
                        ElcidE Offline
                        Elcid
                        When posting a reply the text input box does not clear its self after posting. Is this by design?
                        • ElcidE Elcid
                          DesTD Offline
                          DesTD Offline
                          DesT
                          @Elcid it's a bug in the forum. Need to check that too!
                            DesTD Offline
                            DesTD Offline
                            DesT
                            @CatmanV2 said in Other Forum feedback:
                            I don't mind disabling auto-emoji replacement!
                              Link on the dark them are too dark 🙂
                                #35
                                @DesT Dark Mode color scheme is work in progress: Here is a couple of things which may need some attention.
                                Either font or background color...
                                Ohh and do we need 2 search fields? There is already one in the menu bar at the top.
                                  Spinner is back and the 'not going to the first unread'
                                  • DesTD Offline
                                    DesTD Offline
                                    DesT
                                    @CatmanV2 the spinner is not back, we tested it! Can you try just to force a refresh on your browser tab.
                                    For the first "unread" I think it's an issue with the cookie/session. I would need to investigate a little bit more!
                                    • DesTD Offline
                                      DesTD Offline
                                      DesT
                                      @CatmanV2 we change the entire theme/css this morning while also upgrading the plugin that give you the spinner yesterday!
                                      • HSD99H Offline
                                        HSD99H Offline
                                        HSD99
                                        No spinner, but after a hard refresh dark mode is gone (back to light mode) and there's doesn't seem to be a way to get it back. Did I miss something?
                                          There is a new little light bulb icon in the top menu. Try it!
                                            152.6k
