  2. Comments & Feedback
  3. Other Forum feedback
Comments & Feedback
Chat seems broken (still)
Comments & Feedback
Dark mode
Comments & Feedback
Comments & Feedback
Attach Files in PM
Comments & Feedback
Site Bug?
Comments & Feedback
Comments & Feedback
Comments & Feedback
Comments & Feedback
Link to forum
ElcidE
Comments & Feedback
Removing Orange Notification
ElcidE
Comments & Feedback
Forum Settings
Comments & Feedback
Code example library
ElcidE
Comments & Feedback
Comments & Feedback
63 Posts 9 Posters 39.2k Views 8 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    • HSD99H Offline
      HSD99H Offline
      HSD99
      I've seen the light! Thanks!
        Hard refresh removes the spinner. But it did that yesterday as well....
        I shall report back
        And I have cleared all cookies and logged out to test the last read issue.
        • DesTD Offline
          DesTD Offline
          DesT
          The problem with the spinner is coming from the last update of the plugin that display the "recent card caroussel" et the top. And the DEV fixed it this morning!
            Just tried to post a couple of images and the forum throws an error
            Error
            Something went wrong while parsing server response
            This has worked before. It worked earlier today! Have I hit some sort of limit?
            • DesTD Offline
              DesTD Offline
              DesT
              • DesTD Offline
                DesTD Offline
                DesT
                @akbooer it's working...
                Are you using the "Quick reply" or the "Reply" button ?
                  Both, and drag and drop. As I say, it worked earlier! I’ll try again later.
                  Loved your cartoon!
                    C'est bon... images attaching to posts again.
                      Still don't get the last post 😞
                      • DesTD Offline
                        DesTD Offline
                        DesT
                        @CatmanV2 didn't have a chance to check that again, a little bit busy outside the forum 😞
                          De nada, chap
                          • DesTD Offline
                            DesTD Offline
                            DesT
                            Thanks to Google Translate 😉
                              Ca fait rien? 😉
                                "De rien!" is a better translation... 😛
                                  Tant pis??
                                    Tant pis??
                                    @akbooer Harsh, chap 😉
                                    • DesTD Offline
                                      DesTD Offline
                                      DesT
                                      yeah it's "De rien" or you can use "Ya pas de probleme"
                                      • DesTD DesT
                                        @DesT said in Other Forum feedback:
                                        But but but! You're Canadian, aren't you? 😄
                                        DesTD 1 Reply Last reply
                                          DesTD Offline
                                          DesTD Offline
                                          DesT
                                          @CatmanV2 said in Other Forum feedback:
                                          yeah... and ?
                                          Not sure to understand where you want to go with that 😉
                                          For sure "French Canadian" and "French" is not the same 😉
                                            152.7k
