  3. Plugins
  4. Vera-openLuup Ecobee Plugin
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
28 Posts 4 Posters 12.6k Views 4 Watching
    Latest Vera Ecobee Plugin:
    GitHub - rafale77/vera-ecobee: Vera Plugin for ecobee Thermostat
    Vera Plugin for ecobee Thermostat. Contribute to rafale77/vera-ecobee development by creating an account on GitHub.
      According to @prophead, there seem to be some issues with the ecobee plugging locking up openLuup likely because the ecobee cloud server is not responding. I will be looking at making the plugin poll asynchronously but it made me think of something I read on the home-assistant forum: Someone actually managed to control the thermostat locally by going through HomeKit. Home-Assistant has a component to bridge into homekit and control homekit devices.
      Apple's Homekit unlike Amazon and Google is processing automation and control locally through apple TV or maybe some other apple devices and is therefore does not rely on cloud to cloud communication, bypassing the ecobee cloud. It might be of interest to create a bridge for openLuup.
      • propheadP Offline
        propheadP Offline
        prophead
        wrote on last edited by prophead
        The older units do not have homeKit
          I had been exchanging messages with @prophead for over a month because of openLuup hanging. Several times I had asked for this to be discussed in open forum, but it did not happen. This is such a shame because
          1. It doesn’t leverage the collective power of the forum
          2. It makes it seem like there is less forum traffic
          3. It takes longer to surface any root cause
          I’m now switching to a policy of not discussing technical issues on an individual basis, unless, of course, there’s a good reason for it.
            Thanks @akbooer, I agree with you. Thus, me posting here.
            @prophead, you are correct that the first gen ecobees did not have HomeKit support. This was not a solution for you as I will still be making the change to an async in the next couple of days (sorry, I've been busy compiling some other things) but it was a more general idea for ecobee. I was one of the very early adopters and a strong advocate for them but eventually their cloud only API just killed it for them and I switched to a much cheaper and reliable solution with zwave but I thought the bypass through HomeKit interesting.
              @prophead
              Please try the github openLuup_test branch. There should be only the L_Ecobee1.lua file to replace. I have no way to test this but I think it should work.
              • propheadP Offline
                propheadP Offline
                prophead
                I just tried it, this is what I saw in the logs:
                2020-06-02 20:22:55.374 luup_log:13: ecobee: debug: Fetching revisions...
                2020-06-02 20:22:55.375 openLuup.context_switch:: ERROR: [dev #13] ./openLuup/http_async.lua:174: bad argument #1 to 'gsub' (string expected, got nil)
                  This is the line:
                          local host = string.gsub(reqt.authority, "^.-@", "")
                  so it looks like a miising authority field in the request headers?
                  • propheadP Offline
                    propheadP Offline
                    prophead
                    Do the PnP variables work on AltUI?
                      In what way, exactly?
                        Likely it is missing from the original plugin call. I will look at it and update. Sorry about this. I didn't know the async module required it and thank you @akbooer for pointing it out. I am a bit swamped with work but will get to it.
                        • propheadP Offline
                          propheadP Offline
                          prophead
                          Thanks guys
                            @prophead, I posted an updated version on GitHub. Please let me know if it works.
                            @akbooer, I was wondering if this header could be made optional. I looked at the API docs and it doesn't appear to me that they actually require this field in the header. They use a token for authorization using another field.
                            • propheadP Offline
                              propheadP Offline
                              prophead
                              I tried it, same result:
                              2020-06-05 20:31:47.669 luup_log:13: ecobee: debug: Fetching revisions...
                              2020-06-05 20:31:47.670 openLuup.context_switch:: ERROR: [dev #13] ./openLuup/http_async.lua:174: bad argument #1 to 'gsub' (string expected, got nil)
                              2020-06-05 20:31:47.670 luup.delay_callback:: function: 0x185ca10 ERROR: ./openLuup/http_async.lua:174: bad argument #1 to 'gsub' (string expected, got nil)
                                Ok try this again.
                                • propheadP Offline
                                  propheadP Offline
                                  prophead
                                  well a little different this time, but can't get PIN code:
                                  2020-06-06 12:11:22.004 luup_log:13: ecobee: debug: Attempting to getPin...
                                  2020-06-06 12:11:22.004 luup_log:13: ecobee: task: Trying to getPin
                                  2020-06-06 12:11:22.004 luup.task:: status=2 ecobee : Trying to getPin
                                  2020-06-06 12:11:22.004 luup.variable_set:: 13.urn:ecobee-com:serviceId:Ecobee1.TSK was: Error: nil: no valid JSON value (reached the end) now: Trying to getPin #hooks:0
                                  2020-06-06 12:11:22.042 luup_log:13: ecobee: Error: nil: no valid JSON value (reached the end)
                                  2020-06-06 12:11:22.042 luup_log:13: ecobee: task: Error: nil: no valid JSON value (reached the end)
                                  2020-06-06 12:11:22.042 luup.task:: status=2 ecobee : Error: nil: no valid JSON value (reached the end)
                                  2020-06-06 12:11:22.042 luup.variable_set:: 13.urn:ecobee-com:serviceId:Ecobee1.TSK was: Trying to getPin now: Error: nil: no valid JSON value (reached the end) #hooks:0
                                    Hmm this is a different problem indeed. I may need to move the authorization call to not be asynchronous. Sorry it is more complicated than I initially thought.
                                    • propheadP Offline
                                      propheadP Offline
                                      prophead
                                      Well the authorization is done attended so thats no big deal. I’m more concerned about it hanging when it’s unattended.
                                        I am somewhat biased towards trying to find a way to prevent openLuup from hanging on a socket wait rather than working plugins one by one to circumvent this. I just had an event today which I think was due to some network problems causing my pioneer plugin to wait for a response from the receiver. This plugin uses the io module and lua socket directly and is not an http request so the problem is definitely deep in the lua socket...
                                        • propheadP Offline
                                          propheadP Offline
                                          prophead
                                          Got sick of ecobee plugin hanging my openluup box so I built a new pi just for the ecobee plugin and a scene which pushes values onto my main openluup box.
                                            157.6k
