  3. Vera
  4. Sensative Strip showing two instances in Vera.
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
8 Posts 2 Posters 1.9k Views 2 Watching
    RogerO
    I have a Sensative strip that is in Vera twice. Each one has a different Device number and ID. Have tried to delete one and it will not go away. How can I remove one without loosing the other?
    • R RogerO
      @rogero
      This is what this device looks like on Z-way
      I have a handful of them and had great grief with how the vera zwave management wiped out its battery to 20-25% of its rated lifetime. Alright I digress.
      The inclusion process of this device was broken on later vera firmwares so I don't know whether you included it only recently. What broke is the fact that the firmware on these strips require for the controller to get out of inclusion mode and start a number of configuration steps for the device to save its new HomeID and DeviceID. The vera has just become too slow or is too busy having fun maintaining itself most of the time and fail the inclusion process even though it thinks it completed it. The strip will not have saved it's new network.
      To be sure, can you post the attribute screens of your 2 devices on the UI? This device only has one z-wave instance and therefore should not have any child devices.
        RogerO
        What info are you looking for? CW-KID is helping me on Ezlo forum. maybe I shouldn't have posted in both boards.
        BTW, this strip is my oldest one and has been in Vera for a few years, though I may have lost and re-added it last time I had to replace my Bricked Vera Plus. The rest of my Sensative produces ate showing 100% battery and only one instance of each device. This one is down to 75% so that is causing concern, otherwise I would just ignor the second instance.
          This is rather strange. Not sure why you would have 2 devices. Is the vera updating both when you trip/untrip the sensor?
          I am trying to see if one is a child of the other or if one is just a ghost device which is registered in the vera z-wave chip during a failed inclusion as I described above and the other came from a previous successful inclusion.
            RogerO
            Only the second device trips when the door is opened. The have separate ID's and both are children of the controller.
              ok so I think you should be able to delete the one which doesn't trip. It is likely a ghost device (make sure they have different altid) which is remaining on the z-wave chip from a failed inclusion.
                RogerO
                I have tried deleting the device and it will not go away. Doing it through the UI anyway.
                  It is a sign that the device record is in the vera's zwave chip and not only in the vera user-data file. Sorry it's been a while now since I've dealt with a vera UI but I thought there was a way to irreversibly delete a device. Maybe from the advanced/zwave menu?
                    160.0k
