  4. Integrate UPS with MSR
25 Posts 5 Posters 11.4k Views 5 Watching
    OK. I had to cobble-up some documentation, and I'm a bit swamped this week so forgive any spelling and grammar transgressions arising from my haste.
    NUTController build 22151 can now be downloaded from extras and the docs are here.
    K Offline
    K Offline
    kfxo
    wrote on last edited by kfxo
    Getting this error in the log when restarting Reactor after performing the installation steps for NUT controller. I am on Reactor 22149 installed on Ubuntu in Docker.
    [latest-22149]2022-06-01T16:54:36.344Z <Structure:INFO> Structure#1 loading controller interface nut (NUTController)
    [latest-22149]2022-06-01T16:54:36.345Z <Controller:CRIT> Controller: failed to load nut implementation /var/reactor/ext/NUTController/NUTController.js: [TypeError]TypeError: Incompatible base version; is 22125, requires at least 22145
    [latest-22149]2022-06-01T16:54:36.346Z <Controller:CRIT> TypeError: Incompatible base version; is 22125, requires at least 22145
        at Function.requires (/opt/reactor/server/lib/Controller.js:327:19)
        at Object.<anonymous> (/var/reactor/ext/NUTController/NUTController.js:9:53)
        at Module._compile (node:internal/modules/cjs/loader:1103:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
        at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:168:29)
        at ModuleJob.run (node:internal/modules/esm/module_job:197:25)
        at async Promise.all (index 0)
        at async ESMLoader.import (node:internal/modules/esm/loader:337:24)
    [latest-22149]2022-06-01T16:54:36.346Z <Structure:ERR> Structure#1 controller nut (NUT) skipped, implementation could not be loaded.
    edit: Fixed in build 22152. See below.
      Whoops! Sorry. I'm using a slightly newer version of some classes. Fixed now, 22152 build of NUTController available for download.
      K S 2 Replies Last reply
        K Offline
        K Offline
        kfxo
        @toggledbits said in Integrate UPS with MSR:
        Confirmed fixed. Thanks.
        • wmarcolinW Offline
          NUT installed and running, it was a long way, I had to install VirtualBox and create a Linux VM because I couldn't find anywhere how to have NUT for Windows.
          Now I see that to install NUTController you have to be Linux too? If your answer is yes, then I will have another huge journey, move the MSR from Windows bare-metal to this VM I created, and we will have to read a lot of manual, I know nothing of Linux.
            It should run fine under Windows. Just create an ext directory in your Reactor install directory, unzip the archive, and copy the NutController folder into ext. If you look at the install.sh script, all it does is install dependencies using npm, so instead of running the script, just run the npm command manually:
            npm i --no-save --omit dev
            Configuration steps are the same, but depending on how your VM is configured, you may need to do some network tricks in VirtualBox to make sure that NUTController can access the IP port of your NUT server in the VM. Can't help you there. VirtualBox is not my jam.
            wmarcolinW 1 Reply Last reply
              22152 build of NUTController available for download.<
              Thanks for publishing this. I am now using it on MSR Synology docker. Love it.
                Hi Patrick
                Well, I got all the installations done, and NUT is connected to the MSR.
                Looking at the Reactor log, no error:
                [latest-22149]2022-06-07T04:07:18.147Z <Structure:INFO> Structure#1 loading controller interface nut (NUTController)
                [latest-22149]2022-06-07T04:07:18.158Z <default:null> Module NUTController v22152
                [latest-22149]2022-06-07T04:07:18.272Z <Structure:INFO> Starting controller NUTController#nut
                [latest-22149]2022-06-07T04:07:18.276Z <NUTController:NOTICE> NUTController#nut connecting to NUT server at "192.168.33.25":3493
                [latest-22149]2022-06-07T04:07:18.278Z <NUTController:INFO> NUTController#nut started NUT client connection; waiting for ready
                [latest-22149]2022-06-07T04:07:19.258Z <NUTController:INFO> NUTController#nut connected and ready!
                [latest-22149]2022-06-07T04:07:19.260Z <NUTController:NOTICE> Controller NUTController#nut is now online.
                In the VM using the command: upsc smart1500lcd@192.168.33.25 shows all the UPS data.
                So, my difficulty as can be seen on the first screen, that I don't get the detailed UPS information in the MSR.
                  You are not searching correctly in the Entities list. Your UPS name does not have "nut" in it. Rather than seaching for entities containing the word "nut", clear all fields and select your NUTController instance in the controller filter field.
                    Perfect, and thanks again!!!
                      Hi!
                      A query, my NUT service stops working recurrently, and when I make the query upsc myups@localhost I get the message Error: Data stale.
                      To get it working again I have to run upsdrvctl start to restart.
                      Has anyone experienced this difficulty?
                        Okay, job done, UPS > NUT > MSR > HE 😁
                        The only thing that bothers me is that the UPS drive stops working without explanation, and I had to put a routine in crontab for it to restart every 10 minutes, I find this horrible but it was the only solution from everything I read, and I am not the only one to do it.
                          Does the NUTController's system entity show that the connection is down when that happens? If so, and NUT is running on the same host as MSR, it's probably pretty easy to just write a rule that restarts the NUT service when the controller has been marked down for X minutes (sustained for).
                            The NUT and MSR are in the same HW, but NUT is in a Linux VM, and MSR I run in Windows.
                            I was able to build a rule in MSR that analyzes 3 attributes of NUT, that if they stay without changing the content in 5 minutes gives me an alert of failure.
                            Strange, when I look at the service, it is all active, what crashes is the UPS driver, so I have to run
                            upsdrvctl stop
                            upsdrvctl start
                            Now, is it possible via Windows MSR to trigger a command in the Linux VM to do this restart? It would avoid having to crontab, only reboot in real failure conditions, and not every 10 minutes.
                              Andr
                              I rescued an Eaton Ellipse ups from work that come back to life with fresh batteries.👍
                              Thought it would be easy to get some kind of system status or notification (from Windows) that somehow could be picked up in Reactor or at least in HA. Oh my... what a horror 😱
                              After a long time following this guide I got NUT up and running on Windows @wmarcolin (Another VM is not a resonable option here)
                              Monitor a UPS attached to a Windows machine
                              Then I added the HA integration just to se if it worked and it actually did 😂
                              So now I want over the finish line, and install NUTController in Reactor.
                              It looked easy, but still, no luck.
                              This got me thinking on another possible solution. Reactor already monitors "System Memory" "Uptime" and so on, so maybe it also could monitor Powersource, Battery Level, Charging State? Then let Reactor react with its magic @toggledbits ?
                              For a Windows user that seems a lot easier and efficient as Windows just handle my UPS as the battery it actually is so it looked like "a laptop".
                              Anyway, here is were I got stuck. No clue what more to try since the Nutserver is up and running and speaks with HA.
                              reactor.log gives me two errors:
                              [latest-23196]2023-07-28T19:34:28.862Z <Structure:CRIT> TypeError: self.nut.setUsername is not a function [-]
                                  at NUTController.start_client (c:\reactor\ext\NUTController\NUTController.js:221:22)
                                  at NUTController.start (c:\reactor\ext\NUTController\NUTController.js:44:14)
                                  at Structure.start (c:\reactor\server\lib\Structure.js:362:56)
                              [latest-23196]2023-07-28T19:34:28.863Z <NUTController:CRIT> TypeError: Cannot read properties of undefined (reading 'end') [-]
                                  at Nut.close (c:\reactor\ext\NUTController\node_modules\node-nut\node-nut.js:65:15)
                                  at NUTController.stop (c:\reactor\ext\NUTController\NUTController.js:53:26)
                                  at c:\reactor\server\lib\Structure.js:366:48
                              [latest-23196]2023-07-28T19:34:28.864Z <Controller:NOTICE> NUTController#nut stopping
                              NUTController.js:221:22 looks like this
                              Structure.js:362:56
                              node-nut.js:65:15
                              Structure.js:366:48
                                Go into the extension directory (ext/NutController) and run npm list and post the output here.
                                Also you need to show your NutController config.
                                  Andr
                                  wrote on last edited by Andr
                                  #21
                                  So, back from vacation so time to take another shot at this 🙂
                                  npm list:
                                  C:\reactor\ext\NUTController>npm list
                                  npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
                                  reactor-nutcontroller@0.1.22305 C:\reactor\ext\NUTController
                                  `-- node-nut@1.0.3
                                    - id: nut
                                      implementation: NUTController
                                      enabled: true
                                      #name: Eddie UPS NUTController
                                        server: 22.33.44.11        # modify the IP address as needed
                                        port: 3493              # optional, default shown
                                        username: "***"      # optional, no user auth if not set
                                        password: "***"  # optional, must be specified if username is used
                                    Try commenting out the username from config. Authentication isn't needed for the queries being used.
                                      Andr
                                      Yep, that did it 😊
                                      Thanks once again @toggledbits
                                      Any thougts about getting more System Info into MSR by the way?
                                        Hmmm... are you (mis)understanding the way NUTController publishes its data? It publishes UPS info on an entity for each UPS that NUT reports. Here, for example, is the data for a test "dummy" UPS that one can configure in NUT:
                                        battery_maintenance.charging=false
                                        battery_maintenance.rechargeable=true
                                        battery_maintenance.replace=true
                                        battery_power.level=0.2
                                        battery_power.since=1692217178132
                                        power_source.source="battery"
                                        x_nut_ups.battery_charge="20"
                                        x_nut_ups.battery_charger.status="discharging"
                                        x_nut_ups.battery_date.maintenance="05/01/2022"
                                        x_nut_ups.device_mfr="Dummy Manufacturer"
                                        x_nut_ups.device_model="Dummy UPS"
                                        x_nut_ups.device_type="ups"
                                        x_nut_ups.driver_name="dummy-ups"
                                        x_nut_ups.driver_parameter.mode="dummy"
                                        x_nut_ups.driver_parameter.pollinterval="2"
                                        x_nut_ups.driver_parameter.port="/etc/nut/dummy.seq"
                                        x_nut_ups.driver_parameter.synchronous="no"
                                        x_nut_ups.driver_version="2.7.4"
                                        x_nut_ups.driver_version.internal="0.14"
                                        x_nut_ups.input_voltage=1580
                                        x_nut_ups.ups_mfr="Dummy Manufacturer"
                                        x_nut_ups.ups_model="Dummy UPS"
                                        x_nut_ups.ups_status="OB LB"
                                        So you can see it's reporting battery state, power level, current power source, etc.
                                        Or are you asking for something else and I'm not getting it?
                                          Andr
                                          #25
                                          No, I get how NutController works. So far at least...
                                          But when I got stuck several times trying to set up NUT I almost gave up. At the same time I remembered seeing some System Info in MSR and if could find data about battery level, charging and so on I would not even need the NUT Installation.
                                          And that would be a big bonus for me as I realize that when my NUT installation fails one day it would take me long time to figure it out and also one less process/config to handle.
                                          And from System Info I assume we could get info about temperatures, storage levels, fan speeds and so on?
                                          This could be used to send warning notifications from MSR.
                                          So yes, I was asking something else that come up in my head when I tried to find another way than using NUT. 🙂
                                            161.0k
