  2. Blogs
  3. My migration from Vera, or what I did on my holidays
Seeking Advice:
Blogs
L
Blogs
Finally gave up on my Ezlo Plus
Blogs
Another transition from Vera to OpenLuup And now to HASS - PerH
PerHP
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
105 Posts 6 Posters 78.0k Views 7 Watching
  • M mrFarmer
    Hi Catman,
    Things you may need to install as well: cjson, dkjson, bit,.... jeez, I wish i made notes the last time i installed openLuup 😮
    @mrFarmer said in My migration from Vera, or what I did on my holidays:
    There's nothing you need to install.
    dkjson is actually loaded by the openLuup_install script.
      @CatmanV2
      This is the moment to look at the logs:
      • Startup log
      • Standard log, at the the start of it, after a system startup.
      These most easily available from the openLuup console Logs menu, or directly from:
      http://IP:3480/openLuup?page=log
      and
      http://IP:3480/openLuup?page=startup_log
      ...I'm confused by the 'Vera is running but No Vera shown'.
        Thanks @akbooer
        Startup log and Lua log don't tell me anything that I find useful
        2020-06-19 15:57:41.027   :: openLuup STARTUP :: /etc/cmh-ludl
        2020-06-19 15:57:41.027   openLuup.init::        version 2020.05.01  @akbooer
        2020-06-19 15:57:41.041   openLuup.scheduler::   version 2020.01.25  @akbooer
        2020-06-19 15:57:41.051   openLuup.wsapi::       version 2019.08.12  @akbooer
        2020-06-19 15:57:41.051   openLuup.servlet::     version 2020.01.29  @akbooer
        2020-06-19 15:57:41.051   openLuup.client::      version 2019.10.14  @akbooer
        2020-06-19 15:57:41.052   openLuup.io::          version 2019.11.29  @akbooer
        2020-06-19 15:57:41.052   openLuup.server::      version 2020.03.20  @akbooer
        2020-06-19 15:57:41.055   openLuup.scenes::      version 2020.03.16  @akbooer
        2020-06-19 15:57:41.056   openLuup.chdev::       version 2020.03.07  @akbooer
        2020-06-19 15:57:41.056   openLuup.userdata::    version 2020.03.31  @akbooer
        2020-06-19 15:57:41.057   openLuup.requests::    version 2020.04.15  @akbooer
        2020-06-19 15:57:41.057   openLuup.gateway::     version 2020.03.08  @akbooer
        2020-06-19 15:57:41.058   openLuup.smtp::        version 2018.04.12  @akbooer
        2020-06-19 15:57:41.060   openLuup.historian::   version 2020.02.12  @akbooer
        2020-06-19 15:57:41.061   openLuup.luup::        version 2020.03.21  @akbooer
        2020-06-19 15:57:41.061   openLuup.pop3::        version 2018.04.23  @akbooer
        2020-06-19 15:57:41.062   openLuup.compression:: version 2016.06.30  @akbooer
        2020-06-19 15:57:41.062   openLuup.timers::      version 2019.05.03  @akbooer
        2020-06-19 15:57:41.062   openLuup.logs::        version 2018.03.25  @akbooer
        2020-06-19 15:57:41.062   openLuup.json::        version 2020.05.20  @akbooer
        2020-06-19 15:57:41.062   openLuup.init:: using Cjson 2.1.0 for fast decoding
        2020-06-19 15:57:41.062   luup.create_device:: [1] D_ZWaveNetwork.xml /  /    ()
        2020-06-19 15:57:41.062   openLuup.chdev:: ERROR: unable to read XML file I_ZWave.xml
        2020-06-19 15:57:41.068   luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json   (openLuup)
        2020-06-19 15:57:41.068   openLuup.init:: loading configuration user_data.json
        2020-06-19 15:57:41.068   openLuup.userdata:: loading user_data json...
        2020-06-19 15:57:41.072   luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0
        2020-06-19 15:57:41.072   openLuup.userdata:: loading rooms...
        2020-06-19 15:57:41.072   openLuup.userdata:: room#1 'MiOS-50103066'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#2 'Garden'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#3 'Driveway'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#4 'Hall'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#5 'Living Room'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#6 'Server Room'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#7 'Porch'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#8 'ReactorCore'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#9 'Garage'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#10 'Master Bedroom'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#11 'Media_Centre'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#12 'Office'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#13 'X-Lab'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#14 'Dining Room'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#15 'Greenhouse'
        2020-06-19 15:57:41.072   openLuup.userdata:: room#16 'Kitchen'
        2020-06-19 15:57:41.072   openLuup.userdata:: ...room loading completed
        2020-06-19 15:57:41.072   openLuup.userdata:: loading devices...
        2020-06-19 15:57:41.073   luup.create_device:: [1] D_ZWaveNetwork.xml / X /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
        2020-06-19 15:57:41.113   openLuup.scheduler.sandbox:: device 3 defined 'string.starts' (a function value)
        2020-06-19 15:57:41.113   openLuup.scheduler.sandbox:: device 3 defined 'string.altui_split' (a function value)
        2020-06-19 15:57:41.113   openLuup.scheduler.sandbox:: device 3 defined 'string.template' (a function value)
        2020-06-19 15:57:41.113   openLuup.scheduler.sandbox:: device 3 defined 'string.trim' (a function value)
        2020-06-19 15:57:41.113   luup.create_device:: [3] D_ALTUI.xml / I_ALTUI.xml / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
        2020-06-19 15:57:41.117   luup.create_device:: [4] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json   (urn:schemas-upnp-org:device:AltAppStore:1)
        2020-06-19 15:57:41.123   luup.create_device:: [7] D_VeraBridge.xml / I_VeraBridge.xml / D_VeraBridge.json   (VeraBridge)
        2020-06-19 15:57:41.123   luup.create_device:: [10002] D_ZigbeeNetwork.xml /  /    ()
        2020-06-19 15:57:41.123   openLuup.chdev:: ERROR: unable to read XML file D_ZigbeeNetwork.xml
        2020-06-19 15:57:41.123   luup.create_device:: [10003] D_BluetoothNetwork.xml /  /    ()
        2020-06-19 15:57:41.123   openLuup.chdev:: ERROR: unable to read XML file D_BluetoothNetwork.xml
        2020-06-19 15:57:41.123   luup.create_device:: [10004] D_SceneController1.xml /  /    ()
        2020-06-19 15:57:41.124   openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml
        2020-06-19 15:57:41.124   luup.create_device:: [10006] D_SceneController1.xml /  /    ()
        2020-06-19 15:57:41.125   luup.create_device:: [10007] D_SceneController1.xml /  /    ()
        2020-06-19 15:57:41.125   openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml
        2020-06-19 15:57:41.126   luup.create_device:: [10008] D_MotionSensor1.xml / X / D_MotionSensorWithTamper1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
        2020-06-19 15:57:41.127   luup.create_device:: [10009] D_TemperatureSensor1.xml /  /    ()
        2020-06-19 15:57:41.127   openLuup.chdev:: ERROR: unable to read XML file D_TemperatureSensor1.xml
        2020-06-19 15:57:41.127   luup.create_device:: [10010] D_LightSensor1.xml /  /    ()
        2020-06-19 15:57:41.127   openLuup.chdev:: ERROR: unable to read XML file D_LightSensor1.xml
        2020-06-19 15:57:41.130   luup.create_device:: [10011] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
        2020-06-19 15:57:41.131   luup.create_device:: [10015] D_DimmableLight1.xml /  /    ()
        2020-06-19 15:57:41.131   openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml
        2020-06-19 15:57:41.132   luup.create_device:: [10018] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
        2020-06-19 15:57:41.134   luup.create_device:: [10019] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
        2020-06-19 15:57:41.136   luup.create_device:: [10020] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
        2020-06-19 15:57:41.137   luup.create_device:: [10023] D_ALTUI.xml / X / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
        2020-06-19 15:57:41.138   luup.create_device:: [10026] D_DayTime.xml /  /    ()
        2020-06-19 15:57:41.138   openLuup.chdev:: ERROR: unable to read XML file D_DayTime.xml
        2020-06-19 15:57:41.138   luup.create_device:: [10027] D_HouseModes.xml /  /    ()
        2020-06-19 15:57:41.138   openLuup.chdev:: ERROR: unable to read XML file D_HouseModes.xml
        2020-06-19 15:57:41.138   luup.create_device:: [10031] D_DigitalSecurityCamera2.xml /  /    ()
        2020-06-19 15:57:41.138   openLuup.chdev:: ERROR: unable to read XML file D_DigitalSecurityCamera2.xml
        2020-06-19 15:57:41.138   luup.create_device:: [10033] D_DigitalSecurityCamera2.xml /  /    ()
        2020-06-19 15:57:41.140   luup.create_device:: [10037] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
        2020-06-19 15:57:41.141   luup.create_device:: [10041] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
        2020-06-19 15:57:41.143   luup.create_device:: [10057] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
        2020-06-19 15:57:41.144   luup.create_device:: [10061] D_DimmableLight1.xml /  /    ()
        2020-06-19 15:57:41.144   openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml
        2020-06-19 15:57:41.144   luup.create_device:: [10062] D_DimmableLight1.xml /  /    ()
        2020-06-19 15:57:41.144   luup.create_device:: [10079] D_Heater1.xml /  /    ()
        2020-06-19 15:57:41.144   openLuup.chdev:: ERROR: unable to read XML file D_Heater1.xml
        2020-06-19 15:57:41.145   openLuup.userdata:: loading scenes...
        2020-06-19 15:57:41.145   openLuup.userdata:: number of scenes = 0
        2020-06-19 15:57:41.145   openLuup.userdata:: ...scene loading completed
        2020-06-19 15:57:41.145   openLuup.userdata:: loading installed plugin info...
        2020-06-19 15:57:41.145   openLuup.userdata:: [openLuup] openLuup (20.5.22)
        2020-06-19 15:57:41.145   openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30)
        2020-06-19 15:57:41.145   openLuup.userdata:: [VeraBridge] VeraBridge (20.4.30)
        2020-06-19 15:57:41.145   openLuup.userdata:: [8246] Alternate UI (2.49b.)
        2020-06-19 15:57:41.145   openLuup.userdata:: [Z-Way] Z-Way (not.installed)
        2020-06-19 15:57:41.145   openLuup.userdata:: [Arduino] MySensors (not.installed)
        2020-06-19 15:57:41.145   openLuup.userdata:: ...user_data loading completed
        2020-06-19 15:57:41.145   openLuup.init:: running _openLuup_STARTUP_
        2020-06-19 15:57:41.145   luup_log:0: startup code completed
        2020-06-19 15:57:41.145   openLuup.init:: init phase completed
        2020-06-19 15:57:41.145   :: openLuup LOG ROTATION :: (runtime 0.0 days)
        Is the start up log. There are no immediate errrors in the Lua log, but happy to poke it.
        What I mean by 'No Vera shown' is that the VeraBridge insists that there no Vera on the ip address:
        I'd attach a screenshot but I can't see how!
          Thanks @akbooer
          @CatmanV2 said in My migration from Vera, or what I did on my holidays:
          It’s not errors that I’m specifically looking for just now, but startup sequences and versions. The first few hundred lines should suffice.
            OK, after getting the log requested above, can you just try updating openLuup from the Plugins page, by pressing the update button on the openLuup Console Plugins page.
              Whatever you say, boss. this was after a Luup reload.
              2020-06-20 20:40:04.474   :: openLuup LOG ROTATION :: (runtime 0.0 days)
              2020-06-20 20:40:04.474   openLuup.init:: init phase completed
              2020-06-20 20:40:04.474   openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x2683d34
              2020-06-20 20:40:04.474   openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x2685da4
              2020-06-20 20:40:04.474   openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x2688224
              2020-06-20 20:40:04.475   openLuup.historian:: starting data historian
              2020-06-20 20:40:04.475   openLuup.historian:: using memory cache size (per-variable): 1024
              2020-06-20 20:40:04.475   openLuup.scheduler:: starting
              2020-06-20 20:40:04.475   openLuup.scheduler:: [2]     openLuup device startup
              2020-06-20 20:40:04.475   luup_log:2: v20.5.22
              2020-06-20 20:40:04.475   luup_log:2: sync in 115.5 s
              2020-06-20 20:40:04.475   luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode
              2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local
              2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local
              2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local
              2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local
              2020-06-20 20:40:04.475   luup.chdev.append:: [AltAppStore] Alternate App Store
              2020-06-20 20:40:04.475   luup.chdev.sync:: [2]     openLuup, syncing children
              2020-06-20 20:40:04.476   luup_log:2: 3Mb, 0.1%cpu, 0.0days
              2020-06-20 20:40:04.476   openLuup.scheduler:: [2]     openLuup device startup completed: status=true, msg=sync in 115.5 s, name=L_openLuup
              2020-06-20 20:40:04.476   openLuup.scheduler:: [3] Alternate UI device startup
              2020-06-20 20:40:04.476   luup_log:3: ALTUI: initstatus(3) starting version: v2.49b
              2020-06-20 20:40:04.476   openLuup.scheduler:: [3] Alternate UI device startup completed: status=, msg=, name=
              2020-06-20 20:40:04.476   openLuup.scheduler:: [7] VeraBridge device startup
              2020-06-20 20:40:04.476   luup_log:7: VeraBridge
              2020-06-20 20:40:04.476   luup_log:7: 2020.04.30
              2020-06-20 20:40:04.476   luup_log:7: 192.168.70.6
              2020-06-20 20:40:04.476   luup_log:7: device clone numbering starts at 10000
              2020-06-20 20:40:04.476   luup_log:7: VeraBridge maps remote Zwave controller
              2020-06-20 20:40:04.476   luup_log:7: v20.4.30
              2020-06-20 20:40:04.644   luup_log:7: Vera info received!
              2020-06-20 20:40:04.644   luup_log:7: MiOS-50103066
              2020-06-20 20:40:04.644   luup_log:7: new room number: 1
              2020-06-20 20:40:04.644   luup_log:7: PK_AccessPoint = 50103066
              2020-06-20 20:40:04.644   luup_log:7: BuildVersion = *1.7.4833*
              2020-06-20 20:40:04.644   luup_log:7: number of remote devices = 117
              2020-06-20 20:40:04.644   luup.create_device:: [1] D_ZWaveNetwork.xml / X /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
              2020-06-20 20:40:04.645   luup.create_device:: [10002] D_ZigbeeNetwork.xml /  /    ()
              2020-06-20 20:40:04.645   openLuup.chdev:: ERROR: unable to read XML file D_ZigbeeNetwork.xml
              2020-06-20 20:40:04.645   luup.create_device:: [10003] D_BluetoothNetwork.xml /  /    ()
              2020-06-20 20:40:04.645   openLuup.chdev:: ERROR: unable to read XML file D_BluetoothNetwork.xml
              2020-06-20 20:40:04.645   luup.create_device:: [10004] D_SceneController1.xml /  /    ()
              2020-06-20 20:40:04.645   openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml
              2020-06-20 20:40:04.646   luup.create_device:: [10006] D_SceneController1.xml /  /    ()
              2020-06-20 20:40:04.646   openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml
              2020-06-20 20:40:04.646   luup.create_device:: [10007] D_SceneController1.xml /  /    ()
              2020-06-20 20:40:04.648   luup.create_device:: [10008] D_MotionSensor1.xml / X / D_MotionSensorWithTamper1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
              2020-06-20 20:40:04.648   luup.create_device:: [10009] D_TemperatureSensor1.xml /  /    ()
              2020-06-20 20:40:04.648   openLuup.chdev:: ERROR: unable to read XML file D_TemperatureSensor1.xml
              2020-06-20 20:40:04.649   luup.create_device:: [10010] D_LightSensor1.xml /  /    ()
              2020-06-20 20:40:04.649   openLuup.chdev:: ERROR: unable to read XML file D_LightSensor1.xml
              2020-06-20 20:40:04.650   luup.create_device:: [10011] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2020-06-20 20:40:04.650   luup.create_device:: [10015] D_DimmableLight1.xml /  /    ()
              2020-06-20 20:40:04.650   openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml
              2020-06-20 20:40:04.652   luup.create_device:: [10018] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2020-06-20 20:40:04.654   luup.create_device:: [10019] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2020-06-20 20:40:04.655   luup.create_device:: [10020] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2020-06-20 20:40:04.657   luup.create_device:: [10023] D_ALTUI.xml / X / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
              2020-06-20 20:40:04.657   luup.create_device:: [10026] D_DayTime.xml /  /    ()
              2020-06-20 20:40:04.657   openLuup.chdev:: ERROR: unable to read XML file D_DayTime.xml
              2020-06-20 20:40:04.657   luup.create_device:: [10027] D_HouseModes.xml /  /    ()
              2020-06-20 20:40:04.657   openLuup.chdev:: ERROR: unable to read XML file D_HouseModes.xml
              2020-06-20 20:40:04.657   luup.create_device:: [10031] D_DigitalSecurityCamera2.xml /  /    ()
              2020-06-20 20:40:04.657   openLuup.chdev:: ERROR: unable to read XML file D_DigitalSecurityCamera2.xml
              2020-06-20 20:40:04.658   luup.create_device:: [10033] D_DigitalSecurityCamera2.xml /  /    ()
              2020-06-20 20:40:04.658   openLuup.chdev:: ERROR: unable to read XML file D_DigitalSecurityCamera2.xml
              2020-06-20 20:40:04.659   luup.create_device:: [10037] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2020-06-20 20:40:04.661   luup.create_device:: [10041] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2020-06-20 20:40:04.662   luup.create_device:: [10057] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2020-06-20 20:40:04.663   luup.create_device:: [10061] D_DimmableLight1.xml /  /    ()
              2020-06-20 20:40:04.663   openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml
              2020-06-20 20:40:04.663   luup.create_device:: [10062] D_DimmableLight1.xml /  /    ()
              2020-06-20 20:40:04.663   luup.create_device:: [10079] D_Heater1.xml /  /    ()
              2020-06-20 20:40:04.663   openLuup.chdev:: ERROR: unable to read XML file D_Heater1.xml
              2020-06-20 20:40:04.664   luup.create_device:: [10080] D_Heater1.xml /  /    ()
              2020-06-20 20:40:04.664   openLuup.chdev:: ERROR: unable to read XML file D_Heater1.xml
              2020-06-20 20:40:04.664   openLuup.context_switch::  ERROR: [dev #7] ./openLuup/devices.lua:538: table index is nil
              2020-06-20 20:40:04.664   openLuup.scheduler:: job aborted : ./openLuup/devices.lua:538: table index is nil
              2020-06-20 20:40:04.664   openLuup.scheduler:: [4] Alternate App Store device startup
              2020-06-20 20:40:04.664   luup_log:4: AltAppStore : starting...
              2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: AltAppStore #hooks:0
              2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was:  now:  #hooks:0
              2020-06-20 20:40:04.664   luup_log:4: AltAppStore : v20.3.30
              2020-06-20 20:40:04.664   luup.set_failure:: status = 0
              2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
              2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
              2020-06-20 20:40:04.664   openLuup.scheduler:: [4] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore
              2020-06-20 20:40:05.372   openLuup.io.server:: HTTP:3480 connection from 192.168.70.251 tcp{client}: 0x27493a4
              2020-06-20 20:40:05.373   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=578672005&Timeout=60&MinimumDelay=1500&_=1592671339440 HTTP/1.1 tcp{client}: 0x27493a4
              2020-06-20 20:40:05.602   openLuup.server:: request completed (128491 bytes, 9 chunks, 228 ms) tcp{client}: 0x27493a4
              2020-06-20 20:40:05.602   luup_log:3: ALTUI: startupDeferred, called on behalf of device:3
              2020-06-20 20:40:05.606   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49b now: v2.49b #hooks:0
              2020-06-20 20:40:05.649   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"key":"nodeid","type":"number","default... #hooks:0
              2020-06-20 20:40:05.650   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"key":"nodeid","type":"number","default... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0
              2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0
              2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToSend was:  now:  #hooks:0
              2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.RemoteVariablesToWatch was:  now:  #hooks:0
              2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToWatch was:  now:  #hooks:0
              2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now: [] #hooks:0
              2020-06-20 20:40:05.651   luup_log:3: ALTUI: Wkflow - enableWorkflows(3,0,0)
              2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now:  #hooks:0
              2020-06-20 20:40:05.652   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.WorkflowsActiveState was: [] now:  #hooks:0
              2020-06-20 20:40:05.652   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.WorkflowsVariableBag was:  now:  #hooks:0
              2020-06-20 20:40:05.652   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.WorkflowsActiveState was:  now: [] #hooks:0
              2020-06-20 20:40:05.652   luup.register_handler:: global_function_name=myALTUI_Handler, request=ALTUI_Handler
              2020-06-20 20:40:05.654   luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.RunLua
              2020-06-20 20:40:05.654   luup.register_handler:: global_function_name=ALTUI_LuaRunHandler, request=ALTUI_LuaRunHandler
              2020-06-20 20:40:05.655   luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.RunLua
              2020-06-20 20:40:05.656   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was:  now: [] #hooks:0
              2020-06-20 20:40:05.656   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.PendingReset was: 0 now: 0 #hooks:0
              2020-06-20 20:40:05.662   luup.set_failure:: status = 0
              2020-06-20 20:40:05.662   luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
              2020-06-20 20:40:05.662   luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
              2020-06-20 20:40:05.662   luup_log:3: ALTUI: startup completed
              2020-06-20 20:40:05.669   openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=578663463&_=1592671339441 HTTP/1.1 tcp{client}: 0x27493a4
              2020-06-20 20:40:05.857   openLuup.server:: request completed (179603 bytes, 12 chunks, 187 ms) tcp{client}: 0x27493a4
              2020-06-20 20:40:07.905   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=682008955&Timeout=60&MinimumDelay=1500&_=1592671339442 HTTP/1.1 tcp{client}: 0x27493a4
              2020-06-20 20:40:08.014   openLuup.server:: request completed (20870 bytes, 2 chunks, 108 ms) tcp{client}: 0x27493a4
              2020-06-20 20:40:08.166   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=682008971&Timeout=60&MinimumDelay=1500&_=1592671339443 HTTP/1.1 tcp{client}: 0x27493a4
              2020-06-20 20:41:08.520   openLuup.server:: request completed (363 bytes, 1 chunks, 60353 ms) tcp{client}: 0x27493a4
              Hit update. Showing 2.4.30 No change in the devices (I don't have an update button on the console page, but I did it from AltUI)
                Can you update openLuup from the development branch, and try again?
                  Happy to, but, ummm, how?
                  Cheers
                    #24
                    Type development into the box on the openLuup line on the Plugins page (either in AltUI or openLuup console) and click the Update (recycle icon) button. Then wait for a reload (~15 seconds)
                      So Home>Plugins has 20.4.30 still
                      Need logs?
                      Cheers
                        Well, you’re doing something not right, because I’ve just followed that recipe and now I’m running v20.6.20.
                          Hmmm, not sure what to do then chap.
                          Open AltUI
                          More > Plugins
                          Type 'development' into the update box (is that case sensitive? I've tried both)
                          Hit the update button and wait. Refresh browser and it's still 2.4.30
                          Force a luup reload, and nothing changes 😞
                          Is there an manual install?
                          Cheers
                            #28
                            OK so Luser error. I was trying to update Verabridge, 😞
                            Now I have all my devices. Verabridge has the details for the Vera and looks like all my devices are in.
                            Everything looks like it should be OK, so more playing tonight. Thanks!
                              #29
                              So what are my next steps, gents?
                              I assume a UZB stick will need to be purchased and I can look at migrating some of the devices that are easy / non critical over.
                              Or perhaps a better direction would be to go for the HA Bridge plug in and then get Alexa skill working?
                              Thoughts?
                                Dived in to get HA-bridge up and running. Not too hard, but getting the config was a bit trickier. Using the base instructions here:
                                GitHub - bwssytems/ha-bridge: Home automation bridge that emulates a Philips Hue light system and can control other systems such as a Vera, Harmony Hub, Nest, MiLight bulbs or any other system that...
                                Home automation bridge that emulates a Philips Hue light system and can control other systems such as a Vera, Harmony Hub, Nest, MiLight bulbs or any other system that has an http/https/tcp/udp int...
                                I installed in my home directory on Debian so
                                mdkir /home/catman/ha-bridge
                                cd /home/catman/ha-bridge
                                wget https://github.com/bwssytems/ha-bridge/releases/download/v5.3.0/ha-bridge-5.3.0.jar
                                Creating the service file gave me a choice, I could either change the file or make symlink the folder referenced, which was what I actually went for
                                sudo mkdir /home/pi
                                chmod 555 /home/pi
                                cd /home/pi
                                sudo ln -s /home/catman/ha-bridge/ ha-bridge
                                The systemctl was all fine but it failed on start with the pretty obvious fact that java was missing!
                                sudo apt-get install default-jdk
                                Then it fired up fine, but going to my IP address gave me the Debian apache2 landing page. So that needed fixing. I decided to change the port number to 8080 using:
                                -Dserver.port=<port number>
                                So my service command is now:
                                ExecStart=/usr/bin/java -jar -Dserver.port=8080 -Dconfig.file=/home/pi/ha-bridge/data/habridge.config /home/pi/ha-bridge/ha-bridge-5.3.0.jar
                                Quick demon reload and ha-bridge reload and there it is on port 8080;
                                Excellent!
                                  Even better. Using HTTP to my vera IP I have successful voice control!
                                      They are at the right place. It's gotta be something else. Unless the device json file indicates a completely different path... Or altui can't read the json files?
                                        @rafale77 said in My migration from Vera, or what I did on my holidays:
                                        I don't know what it was. It all started working when I checked in another browser on another machine.
                                        FWIW some of the ones originally in 'icons' had had 0b file size. I supect there was an abortive copy at some point and then subsequent 'get Vera files' took a safe option. I manually scped them all over, but still didn't work when I posted that message.
                                        I guess some odd caching (even though I was very rigorous with my cmd-R
                                        So another challenge has reared its head.
                                        Tried to start migrating some of my Reactor sensors over per my other thread.
                                        Turns out that Vera Bridge seems to poll Vera every 80 seconds or so. That causes reactor to see an update sl_Central_Scene change and thus triggers. This took some time to work out! 😄
                                        This puts something of a crimp in my plans. My understanding is this:
                                        I can plug my (soon to arrive) UZB into my Vera and move all my devices on to it. Then plug it into the NUC and there they all all. That was the big bang I was rather hoping to avoid.
                                        What I suspect I can't do is plug the UZB into the NUC. Un pair the controllers from Vera, pair them to the NUC, confirm a stack of functionality and then plug the UZB into Vera.
                                        Or am I being too pessimistic?
                                        Dunno if this post needs to be moved?
                                        Cheers
                                          Cheers
                                          Not uncommon then. Glad you got over this. The icons do get aggressively cached by browsers and sometimes require some brute force "empty the browser cache"
                                          Hmm I don't remember it doing this. A number of people are running reactor through openLuup verabridge I believe and I have never heard of it. I don't use reactor myself though.
                                          This is my recommended migration method indeed.
                                          Not fully understanding this sentence. Unpair what controllers from vera?
                                            158.9k
