  2. Blogs
  3. My migration from Vera, or what I did on my holidays
Seeking Advice:
Blogs
L
Blogs
Finally gave up on my Ezlo Plus
Blogs
Another transition from Vera to OpenLuup And now to HASS - PerH
PerHP
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
105 Posts 6 Posters 78.0k Views 7 Watching
    I pretty much have 😉
    Just overwrite the lot on the new install, yes?
      @CatmanV2 said in My migration from Vera, or what I did on my holidays:
      Yes.
        Well that was fun 🙂
        Debian re-install. Restore of Openluup instant.
        Restore of HA Bridge not so much. Or in fact at all. But there we are . Not too much more to do 🙂
          Spoke too soon, but HA Bridge is finally back where it was. No idea why I was having so many issues, but I suspect there were overall Vera issues which shouldn't be a problem but....
          Anway.
          To get Z-wave running on Debian I followed the Z-wave manual and then @rafale77 's excellent tutorial on Debian install. It's up running and hooked into Openluup but tomorrow and the weekend are busy so I doubt I'll get much progress.
            It looks like tomorrow is the day....
              Hmmm
              So how long should a restore take? Mine seems to be stuck at 91% and none of my actual devices are visible in the dashboard. Z-wave network is not starting.
              Maybe I'm being too impatient
                Hmm total nightmare. Never gets past restoring to 91%. Won't start Z-wave. Wont' show my devices. dev/ttyACM0 keeps being replaced by tty/ACM1
                Might just burn it and start from scratch
                  OK that's looking better after a second restore. Lots of devices. All with dumb arse names, waiting for wakeup in many cases. Good
                    OK I think that's the important stuff working apart from a Fibaro dimmer in the kitchen. I can't get it beyond any kind of 85% on the interview.
                    Similarly my SRT321 in the hall claims it's a switch with is a little irritating
                    Any thoughts?
                      Have you other Fibaros which have interviewed OK?
                        Yes, although no other Fibaro dimmers. Only modules
                          In other news none of my devices turned up int the right rooms. I'm having some trouble getting some of them to show up in AltUI
                          Is there a way to force a refresh, other than the obvious reload Luup and hard refresh?
                          Cheers
                            OK beginning to get some kind of grip here.
                            The main thermostat has been created with D_ComboDevice1.xml which ain't gonna work 😄
                            Does anyone have copies or know where I can get the right xml and json files at all? There doesn't appear to be anything obviously suitable in my files folder, but if anyone knows what they should be, that would be lovely.
                              #68
                              don't worry about the interview percentage. That doesn't matter at all. I have devices at 50% and they all work fine. This is due to device makers using very weird implementations declaring command classes on their list which the device does not support so the device won't answer. Fibaro and aeotec are notorious for doing that which is why I avoid them as much as possible. What matters is not the percentage but what command classes are being interviewed.
                              It seems you are doing a lot of things at the same time. Let's take it step by step. Is your restore on the vera hanging at 85%?
                              Before starting on the bridge, I would recommend to get familiar with the z-way interface and get all your devices setup with names and rooms there. They will be imported by the bridge.
                                Sorry, chap 🙂
                                Way ahead of that. I have about 90% of my devices working.
                                Nearly all are in AltUI A-OK
                                Ones I have problems with, in order of importance:
                                SRT321 thermostat in the hall:
                                This has AltUI attributes of D_ComboDevice1.xml and json. Can be seen in elements of Z-way but cannot be controlled
                                Fibaro dimmer 2 in the kitchen:
                                This has AltUI attributes of D_PowerMeter1.xml and json. Not visible in the elements of Z-way
                                  #70
                                  The combodevice is normal. It is what the z-way bridge uses for... combo devices. The SRT from what I can see seems to be declared as a switch with a temperature sensor, so you should see child devices spawn from that combo device. For us to be helpful, we would need to know what command classes are showing in z-way which are not ported by the bridge but the first problem is to get them interviewed and show in the z-way home automation UI.
                                  The dimmer 2, if it has more than one functionality, likely also shows up as a combo device with child devices. Apparently it already has ported the power meter but not the dimmer command class? This is not like the vera... you don't need to go modify the xml and json and neither will it work. Each of these corresponds to an actual zwave command class and doesn't go through some vera guess work, often failing and spawning some random stuff which is why it doesn't have the vera's device specific support problems.
                                    Ahhhh OK. That gives me some interesting avenues to explore. I shall report back (undoubtedly with more questions!)
                                      OK looking at the lights Fibaro dimmer it hasn't appeared to create any devices in Z-way that are visible other than in the advanced view.
                                      Nothing in elements. The advanced view gives me access to all the parameters but nothing I can control it with, if that makes sense?
                                      Cheers
                                      rafale77R akbooerA 2 Replies Last reply
                                        SRT321 now accepts setpoint so that's great. Just curious how I would control it via AltUI?
                                        Cheers
                                          Cheers
                                          yep, that's where the problem lies and is why we have been talking about switching the API the bridge is talking to. The automation UI is really more of a demonstrator for what the lower API and library can do. It has some gaps unlike the lower level zwave API and even the JS API. I also have devices like these which we had to workaround by sending commands directly to the lower level API. Please provide the details: what command class that device has on the expert UI and which ones are missing. It is possible that a forced interview or a simple version edit can fix it too.
                                          Cheers
                                          This is a bridge problem then, because none of us had this device before. A screenshot of the cgi screen showing the details of this device (go to the zway bridge and click on configure child) could reveal what this device is publishing and we can make the bridge support it.
                                            159.0k
