  2. Hardware
  3. Vera
  4. Vera or not vera?
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
Vera or not vera?
104 Posts 10 Posters 63.6k Views 10 Watching
    I should also add that the Reactor plugin, of course, works on openLuup (indeed, it was developed there, IIRC.)
    • K Offline
      K Offline
      krisztianszabo
      Thank you for your comments and helpfulness!
      @AKbooer
      I think it seems so understandable, although I'm afraid the construction will be much larger in volume .... 🙂
      Before I start purchasing, I have a few questions:
      • "You will need another computer"
        What RPi should I take? 3's 4's? 2GB? 4GB?
      • "buy a UZB stick with ZWave license, and software (runs on RPi)"
        If I understand correctly, two softwares came up. The Homeseer and the z-way? How can I try these? Does that require any hardware?
      • My shutter control is not commonplace. I have 433Mhz radio frequency shutter motors. The shutter control interface is connected to the vera via a USB port. It is a 15-channel radio frequency shutter control module that uses port 3481 to communicate with the vera. It communicates with the shutters on RF433Mhz. (device type: urn: schemas-arduino-cc: device: arduino: 1)
        Will I be able to use this if I leave the vera completely?
      Krisz
      • Black CatB Offline
        Black CatB Offline
        Black Cat
        Homeseer has a 30 day free trial, it's available in both Windows (ideal for repurposing an old laptop) or run it on a Raspberry Pi.
        I do both flavours for testing but love the Pi.
        A UZB is essential for a Z-Wave network, HS is software not tied to a particular system, for instance apart from Z-Wave you can run Zigbee, KNX, Hue, Tuya... the list goes on.
        Your RF controller will work with it.
        It's free for 30 days, jump in and give it a try.
        aka Zedrally
          Whatever, if you replace the Vera, you will need a ZWave stick. If you buy a ZWave.me one (UZB) then you get the ZWay software.
            Black CatB Offline
            Black Cat
            The point I was trying to make is that you can trial HS software without a UZB, also there is other software than Z-Way.
            I'm hoping that the forum doesn't become Z-Way centric as there other good options available as well including Home Assistant.
            If you like the software then choices can be made for Z-Wave, Zigbee etc, if you have a TUYA device then it's all there for you without buying anything additional.
            aka Zedrally
              Without wanting to be z-way centric, HS is indeed a decent choice for zwave as a holistic controller, not needing anything else but... It is very very expensive. Its integrations are good but nowhere near as good as home assistant and again very expensive. And lastly it doesn't have any decent API for it to use as a device controller which would enable people to overcome its inconveniences which is cost and insufficient integrations. So no I don't really recommend homeseer. It is good if it fits exactly what you are seeking in terms of control and integration and are willing to pay the $$$. I downloaded it, used the free version for some time and though it is stable, it lacks the flexibility of openLuup in automation and the completeness and user friendliness of z-way in zwave command class level controls. Each has its pros and cons but homeseer has no good way to overcome its cons unlike others you can make work with others.
                @Black-Cat said in Vera or not vera?:
                100%.
                These are just opinions based on individual experience... what else could they be?
                If there was a ‘perfect’ answer, then we wouldn’t need a forum.
                Edit: I should back up this philosophy with the very practical note that I am not, in fact, now, even ZWave centric, abandoning it for almost everything (can’t find a good replacement yet for two pulse-counter meter readers or MiniMote four-button hand-held controllers.)
                I’ve surprised myself by being impressed with Shelly WiFi-based devices.
                  sender
                  Have a look at esphome.io
                  • S sender
                    @sender said in Vera or not vera?:
                    Yes, thanks. You (or someone else) May have pointed this out previously?
                    I have no problem building my own stuff (I used to use MySensor Arduino-based sensors) but have been trying to move towards more consumer-based hardware (Philips Hue, etc.) for easier maintenance in the future (possibly by others, rather than myself.)
                    It would seem that a natural response for a new owner acquiring a home-made smart home would be to rip it all out and start again, but an infrastructure of commercial, and documented, systems would, perhaps, be more likely to be retained?
                    A theme for a separate topic, perhaps.
                    • K Offline
                      K Offline
                      krisztianszabo
                      @akbooer
                      • If I connect a z-way or z wave stick later and leave the vera, will I still be able to run openluup? Will I keep all my devices, plugins, reactor scenes previously imported from vera?
                      • What is your opinion on the shutter issue I mentioned earlier? Will go? That would be important because I wouldn’t get rid of the shutter controller.
                      • Does zway also have a free trial?
                      • I downloaded the homeseer to watch for free on windows. It's completely empty now. Should I install the vera plugin? In principle, it writes $ 40. Or is it free for 30 days in the trial version?
                      Sorry if I asked something clear ....
                      Krisz
                        • openLuup has no dependency on Vera hardware at all. It is simply a reliable implementation of the Luup API.
                        • I don’t think ZWay has a free trial. In openLuup it is just used as middleware to connect to the ZWave stack.
                          Black CatB Offline
                          Black Cat
                          Homeseer software is free for 30 days, Plug Ins vary, some are free to trial some not.
                          The PI description will tell you the status.
                          aka Zedrally
                          • K Offline
                            K Offline
                            krisztianszabo
                            @akbooer
                            I bought the Pi! 🙂
                            I'm right there now
                            #wget https://github.com/akbooer/openLuup/raw/master/Utilities/openLuup_install.lua
                            For some reason he writes to me that:
                            openLuup_install.lus: permission denied.
                            What do I have to do now?
                            Krisz
                              mabye putting "sudo" in front of it? you may have to stand in the /Downloads folder as well, and then copy the downloaded file to /etc later..
                              • K Offline
                                K Offline
                                krisztianszabo
                                It was key !! 🙂
                                "saved"
                                I'm going on my way ... 🙂
                                Krisz
                                • K Offline
                                  K Offline
                                  krisztianszabo
                                  #27
                                  one more problem ...
                                  the installation stalled here.
                                  pi@raspberrypi:/etc/cmh-ludl $ sudo lua5.1 openLuup_install.lua
                                  openLuup_install   2019.02.15   @akbooer
                                  getting openLuup version tar file from GitHub branch master...
                                  un-zipping download files...
                                  mv: 'openLuup-master/openLuup/'-t can't remove here: './openLuup': The directory is not empty
                                  getting dkjson.lua...
                                  creating required files and folders
                                  initialising...
                                  downloading and installing AltUI...
                                    % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                  100 29170  100 29170    0     0  90309      0 --:--:-- --:--:-- --:--:-- 90309
                                  100  6570  100  6570    0     0  32364      0 --:--:-- --:--:-- --:--:-- 32364
                                  lua5.1: openLuup/init.lua:291: openLuup - is another copy already running?  Unable to start HTTP server on port 3480
                                  stack traceback:
                                  	[C]: in function 'error'
                                  	openLuup/init.lua:291: in main chunk
                                  	[C]: ?
                                  openLuup downloaded, installed, and running...
                                  visit http://192.168.0.159:3480 to start using the system
                                  pi@raspberrypi:/etc/cmh-ludl $ lua5.1: openLuup/init.lua:291: openLuup - is another copy already running?  Unable to start HTTP server on port 3480
                                  stack traceback:
                                  	[C]: ?  "
                                  If I try to open it in a browser the message is:
                                  "This XML file does not appear to have any style information associated with it. The document tree is shown below."
                                  What should I do?
                                  Krisz
                                  • K krisztianszabo
                                    initialising...
                                    stack traceback:
                                    	[C]: ?
                                    stack traceback:
                                    	[C]: ?  "
                                    What should I do?
                                    #28
                                    @krisztianszabo said in Vera or not vera?:
                                    It means exactly what it says.
                                    Try accessing it with AltUI URL. If it’s an old copy running, you can abort it with the exit command, as described in the documentation...
                                    http://openLuupIP:3480/data_request?id=exit
                                    • K Offline
                                      K Offline
                                      krisztianszabo
                                      with openluup ip, the browser prints the following (in black on a red background):
                                      "Waiting Initial Data"
                                      ... but nothing has happened for a long time ...
                                      Krisz
                                        Look for errors in the log file.
                                        You should be able to access the native openLuup UI with
                                        http://openLuupURL:3480/openLuup/
                                        ...in order to access the logs.
                                        The most common issue here is that your computer locale setting specifies a language which AltUI does not implement. The error log should clarify this. A workaround is to copy the English language file to one with your country extension OR set your language to one which is implemented.
                                        • K Offline
                                          K Offline
                                          krisztianszabo
                                          wrote on last edited by krisztianszabo
                                          #31
                                          Language really was the problem. Thanks.
                                          I got past that, but here's another one ....
                                          The two files were born in the right places (etc / cmh-ludl and systemd / system) with good content.
                                          When I type that:
                                          pi@raspberrypi:/etc/cmh-ludl $ sudo systemctl enable openLuup
                                          The unit files have no installation config (WantedBy=, RequiredBy=, Also=,
                                          Alias= settings in the [Install] section, and DefaultInstance= for template
                                          units). This means they are not meant to be enabled using systemctl.
                                          Possible reasons for having this kind of units are:
                                          • A unit may be statically enabled by being symlinked from another unit's
                                          .wants/ or .requires/ directory.
                                          • A unit's purpose may be to act as a helper for some other unit which has
                                          a requirement dependency on it.
                                          • A unit may be started when needed via activation (socket, path, timer,
                                          D-Bus, udev, scripted systemctl call, ...).
                                          • In case of template units, the unit is meant to be enabled with some
                                          instance name specified.
                                          Krisz
                                            154.1k
