  2. Hardware
  3. Vera
  4. Vera or not vera?
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
Vera or not vera?
104 Posts 10 Posters 67.0k Views 10 Watching
    @Black-Cat said in Vera or not vera?:
    The point I was trying to make is that you can trial HS software without a UZB, also there is other software than Z-Way.
    I'm hoping that the forum doesn't become Z-Way centric as there other good options available as well including Home Assistant.
    100%.
    These are just opinions based on individual experience... what else could they be?
    If there was a ‘perfect’ answer, then we wouldn’t need a forum.
    Edit: I should back up this philosophy with the very practical note that I am not, in fact, now, even ZWave centric, abandoning it for almost everything (can’t find a good replacement yet for two pulse-counter meter readers or MiniMote four-button hand-held controllers.)
    I’ve surprised myself by being impressed with Shelly WiFi-based devices.
      sender
      Have a look at esphome.io
      • S sender
        @sender said in Vera or not vera?:
        Yes, thanks. You (or someone else) May have pointed this out previously?
        I have no problem building my own stuff (I used to use MySensor Arduino-based sensors) but have been trying to move towards more consumer-based hardware (Philips Hue, etc.) for easier maintenance in the future (possibly by others, rather than myself.)
        It would seem that a natural response for a new owner acquiring a home-made smart home would be to rip it all out and start again, but an infrastructure of commercial, and documented, systems would, perhaps, be more likely to be retained?
        A theme for a separate topic, perhaps.
        • K Offline
          K Offline
          krisztianszabo
          @akbooer
          • If I connect a z-way or z wave stick later and leave the vera, will I still be able to run openluup? Will I keep all my devices, plugins, reactor scenes previously imported from vera?
          • What is your opinion on the shutter issue I mentioned earlier? Will go? That would be important because I wouldn’t get rid of the shutter controller.
          • Does zway also have a free trial?
          • I downloaded the homeseer to watch for free on windows. It's completely empty now. Should I install the vera plugin? In principle, it writes $ 40. Or is it free for 30 days in the trial version?
          Sorry if I asked something clear ....
          Krisz
            • openLuup has no dependency on Vera hardware at all. It is simply a reliable implementation of the Luup API.
            • I don’t think ZWay has a free trial. In openLuup it is just used as middleware to connect to the ZWave stack.
            • Black CatB Offline
              Black CatB Offline
              Black Cat
              Homeseer software is free for 30 days, Plug Ins vary, some are free to trial some not.
              The PI description will tell you the status.
              aka Zedrally
              • K Offline
                K Offline
                krisztianszabo
                @akbooer
                I bought the Pi! 🙂
                I'm right there now
                #wget https://github.com/akbooer/openLuup/raw/master/Utilities/openLuup_install.lua
                For some reason he writes to me that:
                openLuup_install.lus: permission denied.
                What do I have to do now?
                Krisz
                  mabye putting "sudo" in front of it? you may have to stand in the /Downloads folder as well, and then copy the downloaded file to /etc later..
                  • K Offline
                    K Offline
                    krisztianszabo
                    It was key !! 🙂
                    "saved"
                    I'm going on my way ... 🙂
                    Krisz
                    • K Offline
                      K Offline
                      krisztianszabo
                      #27
                      one more problem ...
                      the installation stalled here.
                      pi@raspberrypi:/etc/cmh-ludl $ sudo lua5.1 openLuup_install.lua
                      openLuup_install   2019.02.15   @akbooer
                      getting openLuup version tar file from GitHub branch master...
                      un-zipping download files...
                      mv: 'openLuup-master/openLuup/'-t can't remove here: './openLuup': The directory is not empty
                      getting dkjson.lua...
                      creating required files and folders
                      initialising...
                      downloading and installing AltUI...
                        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                       Dload  Upload   Total   Spent    Left  Speed
                      100 29170  100 29170    0     0  90309      0 --:--:-- --:--:-- --:--:-- 90309
                      100  6570  100  6570    0     0  32364      0 --:--:-- --:--:-- --:--:-- 32364
                      lua5.1: openLuup/init.lua:291: openLuup - is another copy already running?  Unable to start HTTP server on port 3480
                      stack traceback:
                      	[C]: in function 'error'
                      	openLuup/init.lua:291: in main chunk
                      	[C]: ?
                      openLuup downloaded, installed, and running...
                      visit http://192.168.0.159:3480 to start using the system
                      pi@raspberrypi:/etc/cmh-ludl $ lua5.1: openLuup/init.lua:291: openLuup - is another copy already running?  Unable to start HTTP server on port 3480
                      stack traceback:
                      	[C]: ?  "
                      If I try to open it in a browser the message is:
                      "This XML file does not appear to have any style information associated with it. The document tree is shown below."
                      What should I do?
                      Krisz
                      • K krisztianszabo
                        initialising...
                        stack traceback:
                        	[C]: ?
                        stack traceback:
                        	[C]: ?  "
                        What should I do?
                        #28
                        @krisztianszabo said in Vera or not vera?:
                        It means exactly what it says.
                        Try accessing it with AltUI URL. If it’s an old copy running, you can abort it with the exit command, as described in the documentation...
                        http://openLuupIP:3480/data_request?id=exit
                        • K Offline
                          K Offline
                          krisztianszabo
                          with openluup ip, the browser prints the following (in black on a red background):
                          "Waiting Initial Data"
                          ... but nothing has happened for a long time ...
                          Krisz
                            Look for errors in the log file.
                            You should be able to access the native openLuup UI with
                            http://openLuupURL:3480/openLuup/
                            ...in order to access the logs.
                            The most common issue here is that your computer locale setting specifies a language which AltUI does not implement. The error log should clarify this. A workaround is to copy the English language file to one with your country extension OR set your language to one which is implemented.
                            • K Offline
                              K Offline
                              krisztianszabo
                              wrote on last edited by krisztianszabo
                              #31
                              Language really was the problem. Thanks.
                              I got past that, but here's another one ....
                              The two files were born in the right places (etc / cmh-ludl and systemd / system) with good content.
                              When I type that:
                              pi@raspberrypi:/etc/cmh-ludl $ sudo systemctl enable openLuup
                              The unit files have no installation config (WantedBy=, RequiredBy=, Also=,
                              Alias= settings in the [Install] section, and DefaultInstance= for template
                              units). This means they are not meant to be enabled using systemctl.
                              Possible reasons for having this kind of units are:
                              • A unit may be statically enabled by being symlinked from another unit's
                              .wants/ or .requires/ directory.
                              • A unit's purpose may be to act as a helper for some other unit which has
                              a requirement dependency on it.
                              • A unit may be started when needed via activation (socket, path, timer,
                              D-Bus, udev, scripted systemctl call, ...).
                              • In case of template units, the unit is meant to be enabled with some
                              instance name specified.
                              Krisz
                              • K Offline
                                K Offline
                                krisztianszabo
                                @Akbooer
                                I copied this from the startup_log.
                                Something was not filled properly?
                                Could the above error message be the cause?
                                2020-11-05 15:35:49.788 openLuup.init:: Cjson not installed - using openLuup.json.Lua.decode() instead
                                2020-11-05 15:35:49.789 luup.create_device:: [1] D_ZWaveNetwork.xml / / ()
                                2020-11-05 15:35:49.789 openLuup.chdev:: ERROR: unable to read XML file I_ZWave.xml
                                2020-11-05 15:35:49.804 luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json (openLuup)
                                2020-11-05 15:35:49.804 openLuup.init:: loading configuration user_data.json
                                2020-11-05 15:35:49.804 openLuup.userdata:: loading user_data json...
                                2020-11-05 15:35:49.812 luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0
                                2020-11-05 15:35:49.812 openLuup.userdata:: loading rooms...
                                2020-11-05 15:35:49.812 openLuup.userdata:: ...room loading completed
                                2020-11-05 15:35:49.812 openLuup.userdata:: loading devices...
                                2020-11-05 15:35:49.813 luup.create_device:: [1] D_ZWaveNetwork.xml / / ()
                                2020-11-05 15:35:49.813 openLuup.chdev:: ERROR: unable to read XML file I_ZWave.xml
                                2020-11-05 15:35:49.908 openLuup.scheduler.sandbox:: device 3 defined 'string.starts' (a function value)
                                2020-11-05 15:35:49.908 openLuup.scheduler.sandbox:: device 3 defined 'string.altui_split' (a function value)
                                2020-11-05 15:35:49.908 openLuup.scheduler.sandbox:: device 3 defined 'string.template' (a function value)
                                2020-11-05 15:35:49.908 openLuup.scheduler.sandbox:: device 3 defined 'string.trim' (a function value)
                                2020-11-05 15:35:49.909 luup.create_device:: [3] D_ALTUI.xml / I_ALTUI.xml / D_ALTUI_UI7.json (urn:schemas-upnp-org:device:altui:1)
                                2020-11-05 15:35:49.917 luup.create_device:: [4] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json (urn:schemas-upnp-org:device:AltAppStore:1)
                                2020-11-05 15:35:49.917 openLuup.userdata:: loading scenes...
                                2020-11-05 15:35:49.917 openLuup.userdata:: number of scenes = 0
                                2020-11-05 15:35:49.917 openLuup.userdata:: ...scene loading completed
                                2020-11-05 15:35:49.917 openLuup.userdata:: loading installed plugin info...
                                2020-11-05 15:35:49.917 openLuup.userdata:: [openLuup] openLuup (20.5.22)
                                2020-11-05 15:35:49.917 openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30)
                                2020-11-05 15:35:49.917 openLuup.userdata:: [VeraBridge] VeraBridge (not.installed)
                                2020-11-05 15:35:49.917 openLuup.userdata:: [8246] Alternate UI (GitHub.master)
                                2020-11-05 15:35:49.917 openLuup.userdata:: [Z-Way] Z-Way (not.installed)
                                2020-11-05 15:35:49.918 openLuup.userdata:: [Arduino] MySensors (not.installed)
                                2020-11-05 15:35:49.918 openLuup.userdata:: ...user_data loading completed
                                2020-11-05 15:35:49.918 openLuup.init:: running openLuup_STARTUP
                                2020-11-05 15:35:49.918 luup_log:0: startup code completed
                                2020-11-05 15:35:49.918 openLuup.init:: init phase completed
                                2020-11-05 15:35:49.918 :: openLuup LOG ROTATION :: (runtime 0.0 days)
                                Krisz
                                  Looks great to me. No problem with the missing file, really.
                                  Is everything working?
                                    #34
                                    I do notice that you haven’t installed the VeraBridge plugin, so there will be no link to Vera.
                                    K 1 Reply Last reply
                                    • K Offline
                                      K Offline
                                      krisztianszabo
                                      #35
                                      The main problem is one post up. I'm still standing on "openLuup Start on Bootup Lua", unfortunately.
                                      (I was just guessing why it didn't work)
                                      Krisz
                                        K Offline
                                        K Offline
                                        krisztianszabo
                                        @akbooer
                                        Krisz
                                        • K Offline
                                          K Offline
                                          krisztianszabo
                                          Hello @akbooer,
                                          I’ve been working on the system a lot in recent days.
                                          (altui starts with "pi", I have the tools with all the icons and also the rooms, language file copied. I'm still in the process of installing the vera plugins and moving the reactor scenes (sensors).
                                          1, What I noticed:
                                          • startup lua error:
                                          2020-11-09 09: 24: 00.644 openLuup.init :: Cjson not installed - using openLuup.json.Lua.decode () instead
                                          2, I have read the openluup manual you wrote several times unfortunately, yet one or two things are not clear.
                                          Settings for the user_data.json file:
                                          • the actual location of the backup and log directory on the pi must be specified. Right?
                                          • "ditto Lines and Versions - number of lines before log rotation, number of versions saved"
                                            i don't know what to change here ....
                                          • "openLuup.UserData.Checkpoint - number of minutes between each user_data.json save."
                                            here the number 60 should be changed to 6?
                                          3, Altui for some reason identifies my wife's name in the system. he writes that
                                          "unregistered version for" my wife's login name "Why do I log in with this?
                                          Krisz
                                            165.2k
