  2. Hardware
  3. Vera
  4. Vera account suspended for a 1000 years
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
H
Vera
Vera
Vera
101 Posts 22 Posters 65.0k Views 20 Watching
    #57
    @pabla
    The acting is over... now you can just be a spectator. I thought the thread was closed. Apparently not...
    Have to appreciate all the posters for the courage to speak up and try to bring back reason in there. Sure managed to get the guy to come completely unglued.
      sender
      @toggledbits you are awesome! Never used reactor but I have seen your involvement and communication and I just wanted to have it said to you.
        Matteburk
        #59
        And the winner in the right corner of last nights MMA Forum Fight is .......Riiiiiiiiiiiiigpapaaaaa.......🤪
        So Sad that the other guy cant accept his limits. You cant act as a CEO on a companyforum like you were just an annoying user. If he had stayed off the forum and let Nice guys like Sorin and the others do the talkng i guess the hole forumclimate would be better and ezlo more successful.
        Good that you stand up and Don’t let bad People push you down @toggledbits
        • toggledbitsT Online
          toggledbitsT Online
          #60
          Jeeez, he's still ranting. Have any of you ever heard of "confession by projection"?
          Edit: It's time to bring the temperature down over there. We all know who we're dealing with. We've made our point. Thank you all who have chimed in on my behalf as well, and offered words of support here. I'm not leaving until he kicks me off. But it's time to let this one die out, cool the temp and let the forum get back to the business of the community. His anger on display won't change anything anyway; the market will sort him out, not me or anyone else here. For myself, I'm getting on with the business of building tools, and if a single-digit percentage of people use my work, I call that a pretty good day.
            Clearly deranged. All I ever wanted to do was support openLuup users, and point out that, under the new regime, that was best done here rather than there!
            • DesTD Offline
              DesTD Offline
              DesT
              Some people are having way too much free time 😉
                #63
                @akbooer said in Vera account suspended for a 1000 years:
                Didn't need to explain AK. The guy shows us something green and tells us that it is orange. It's be going on since I was there. Everybody else can see that it is green...
                @dest said in Vera account suspended for a 1000 years:
                And not enough neurons...
                Talk about forum rules.. so many he made up to justify banning people giving feedback and expressing their problems and obviously not applying them to himself. Community users are not possessions or employees... they are customers. He is dictating that everyone be happy with the trash and lies he is feeding people without asking why customers are unhappy. Honest customer feedback is essential to success. In my line of work, we don't let ourselves make a single customer unhappy... not one.
                Let him be.
                • DesTD Offline
                  DesTD Offline
                  DesT
                  Seeing all these stuff on the other forum, gave me more pressure to really remove my Vera dependency in my current setup!
                  • DesTD DesT
                    Use Vera-Decouple from @toggledbits
                    I still have my Vera (now Plus - I got one new for 80 bucks on eBay as backup and swapped my Edge to be the backup) perfectly decoupled from the cloud, happily doing its ZWave stuff and with 5-6 days of luup uptime for the things I'm still doing locally (like scenes or code to turn on lights in group, or things that are best locally). If they'll turn off their servers, I'll be impacted exactly zero from this.
                    • DesTD DesT
                      Yes, absolutely. Finally time to clone that ZWave dongle and plug it in to ZWay, or elsewhere.
                      • DesTD Offline
                        DesTD Offline
                        DesT
                        wrote on last edited by DesT
                        #67
                        @therealdb i'm using one Vera for my 3 zigbee thermostat (so I can probably replaced them by zwave) and the other one it's only for the DSC plugin, that I need to debug on openLuup directly to bring it back on openLuup (was there a while ago and stop working, already talk about that with AK)
                        All my zwave devices are since a while in ZWAY!
                        All my scenes/code/etc... are in openLuup since a while too!
                        • DesTD DesT
                          @dest this applies to your case as well. Give it a try 😉 https://github.com/toggledbits/Vera-Decouple
                            #69
                            And I do want to say for the record, the post which got me banned over there was about 2 things:
                            1. A response to a link to the review article for the ezlo USB powered dongle which obviously was written by a home automation newb journalist who knew nothing about it, making claims which were obviously untrue as I had one on hand myself. I called that false advertising.
                            2. The fact that the ezlo controllers, the ezlo plus was an obvious cost reduced version of the vera plus with everything that matters downgraded and everything which is unimportant brought up to date for cost reduction. It is basically a toy grade device barely good enough as a toy for my then 8 year old lego projects. I was pretty sad seeing all the people spending time and money on 3D printing for a shell which is likely worth more than the content. I am a hardware enthusiast working in the semiconductor industry and am pretty well versed in the grade of these chips, who makes them and how. That was my honest feedback. So I called out the false advertising and the forum spamming.
                            There is nothing wrong with the hardware of the vera. It is actually a very cleverly designed piece of hardware based on a wireless router which was not utilized appropriately by its mcv firmware developers. Unlike the ezlo, it uses SLC NAND which is bears >100x write cycle lifetime than the garbage ezlo put out (the partitioning of the vera storage was the main problem). It uses an appliance grade CPU which is much more reliable than the toy grade junk in the ezlo plus you can buy as a full system for $7 on aliexpress. I could tell from the build of material that it was reallly a cost reduced and downgraded from the vera plus from the build of material and would have never even tried to run my home on it even someone paid me to do it. The only reason why I am no longer using the vera plus as a radio for openLuup/home assistant or z-way is that I got tired of how prone to bricking these embedded devices are. They take a lot more work to recover when there is a storage problem (data corruption etc) so I went low cost x86/x86 which often can be more energy efficient but are always more cost effective and more reliable.
                              toggledbitsT Online
                              @rafale77 said in Vera account suspended for a 1000 years:
                              ROFLMAOO.... and I'm dead!!! 😂
                                Matteburk
                                Maybe I should sell my 3d printed ezlo Plus shell on Ebay along with the ezlo plus hardware .... Shell 20 Dollar, Hardware Free .... hahaha
                                  #72
                                  To give you a more graphic analogy of how I see it from a hardware engineer's point of view:
                                  The vera is equivalent to a solid 80's Mercedes with a V8 diesel engine in which mcv has tried to feed some gasoline to make it faster and forgot to install more than 1 seat. It still runs but sputters a little. With a little maintenance and a few fixes, it will run for a long time albeit with only one passenger.
                                  The ezlo plus on the other hand is a brand new 90's Lada on which they put the wings of cessna and they, ezlo, the snake oil salesmen, tell you it will fly you across the ocean powered by the Lada engine. Sorry I didn't believe it for one femto second, would you? Of course the paint job is worth a lot more than the vehicle... and it has 4 seats! yoohoo! You can seat more people but you can't go anywhere with it. And thanks but no thanks, I don't want to test drive it even for free. And no, I won't consider replacing my private jet with it... yeah yeah I know... the door on it can open really fast! awesome! got it! Still it's a "no".
                                    So this is where all the banned Vera members rejoice.. definitely will be posting here more than the toxic vera community forums
                                    @pabla said in Vera account suspended for a 1000 years:
                                    Surprised they haven't banned me yet.
                                    I always state my mind, good or bad.
                                    PablaP 1 Reply Last reply
                                      @cw-kid don’t jinx it, they’ll probably find a forum rule that you’ve somehow broken to ban you too if they want 🤣
                                        #75
                                        The only consistent rules there from what I can see after not having gone back there for so long are:
                                        Do not piss the CEO off, do not win an argument with him, do not prove him wrong, do not mention that he broke his forum rules. Truth does not matter. All you need to know is that they are awesome.
                                        Do not provide helpful information to make your home automation work better than ezlo can. They are already awesome. That's what they call stealing from their awesomeness.
                                        Do not criticize the product repeatedly and consistently or point out the false advertising/marketing, especially if what is said is true and you are a respected and regular contributor. Again, they are awesome. They call this spamming.
                                        Every other rule is fabricated to justify the above and are applied selectively except for one person. The ultimate purpose is obscurantism to brainwash possessions (huh, I meant customers) into believing that their broken systems work and that they are... you guessed it... awesome... and very fast!
                                        • MatohlM Offline
                                          MatohlM Offline
                                          Matohl
                                          #76
                                            230
                                            150.6k
