  4. Is it possible to use a single reaction for multiple entities as variables?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
30 Posts 4 Posters 10.1k Views 4 Watching
  • CrilleC Online
    CrilleC Online
    #21
    @tamorgen You need MSR to evaluate the whole data being sent
    ${{ { “message”: window_names + “ opened!” } }}
    • CrilleC Crille
      #22
      @Crille said in Is it possible to use a single reaction for multiple entities as variables?:
      That's not working either. It actually disables the Play button at he end of Entity Action.
      This is a system call on home assistant (call_service) to send a notification via the HA companion app. The message: text isn't part of the message to be sent, it's yaml code that is part of the data field.
      For example, I have another reaction that sends a message to my phone when my washing machine has completed a cycle.
      The word message doesn't appear on my phone, just the data after it.
      Here is my current rule:
      In the Local Expressions, you can see Last value: (string) "Office Windows", so that value should be returned for window_names in the system call.
        wrote on last edited by Pabla
        #23
        Try without the spaces so it looks like this message: ${{window_names}} Open. MSR supports both JSON and Yaml, but you just gotta make sure theres no errors. Usually online validators help with this
        T 2 Replies Last reply
        • CrilleC Online
          CrilleC Online
          Try my example by hitting the general play button for Reaction.
            @Pabla said in Is it possible to use a single reaction for multiple entities as variables?:
            Doesn't work. MSR throws this error.
              I don't think you have it written correctly here's an example of how I have it used in one of my own notifications
                That triggers the notification, but the value isn't returned.
                  Don't use the play button next to the action, use the play button right under set reaction
                    Well that makes a difference! This has been driving me nuts all afternoon. Thanks for cluing me in!
                      It should look like this:
                      message: "${{window_names}} Open"
                        163.1k
