  3. Vera
  4. Setting Device Parameters (from documentation)
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
12 Posts 4 Posters 4.0k Views 4 Watching
    Before I give up completely, and lose my entire mind, can someone please tell me I'm following the correct steps to get the LED of my NodOn Soft Remote configured through Vera?
      Here's how the documentation reads:
      Here's where I go, under Vera Plus > Devices > Soft Remote > Device Options:
      And here's what I entered as the desired parameter/value:
      I then clicked SAVE CHANGES and woke up the remote by pressing one of its (known-working) buttons. Still, the (also known-working!) LED never lights as expected.
      Any tips on making this otherwise trivially simple change??
        Not knowing what is going on while you are doing it, you currently are following all the right steps. The issue is the delay in the vera command queue which can takes seconds, minutes well up to if I remember correctly 30min before it crashes. If they have not fixed that, and your network is chatty, I can only recommend to keep trying. It will likely eventually take, maybe one out of 10 or 20 times depending on how busy the command queue is. This was similar to my problems including and configuring some devices on the vera where it would take me all day... and why I moved to z-way which only takes seconds.
          I should mention that every attempt I've made thus far causes the Luup engine to reboot, which is exasperating. I do think Vera simply refuses to accomplish this goal. Even the "1 byte [hex]" / "1 byte [dec]" / etc. drop-down box is technically inoperable (does not open when clicked; you must TAB your way into it and use Up/Down arrows to adjust). Harumph.
            Aren't the configuration settings only set to the device during the initial interview and device configuration on Vera? It's always been my experience that a reload is required, and a hard-refresh of the browser to make the Device Configuration show the right values, too.
            Of course, you could take the brute force approach, which is to use a SendData ZWave device action and just construct the configuration command yourself... grab the node ID from Attributes (altid) and send x70 4 8 1 3
              hex or dec doesn't make any difference since the number you are setting is <10. Just FYI.
              I do remember that it reloads avidly and inexplicably for things like these.
              @toggledbits, I had a large number of devices for which I did send custom configurations successfully in the past (not just during inclusion). I would guess that it queues the command but upon each luup reload the zwave command queue is so long that the command either gets scrapped or the device just times out going back to sleep. The send command is a good suggestion.
              Edit: actually @DesT and I are constantly doing this on z-way but used to do it on the vera as well as I control the LED colors of my leviton scene controllers this way for example. I use this as my house alarm/housemode status indicator.
                Funny, guys, here's my younger, braver self trying to educate @Ap15e (remember him? is he here?) on how to accomplish this very thing back in 2009, LOL!
                http://forum.micasaverde.com/index.php/topic,1937.0.html
                  Before I unleash the dragon, is this the correct command format? (Answer: YES)
                  luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='24',Data='x70 4 8 1 3'},1)
                  I ran that exact command in Vera's APPS > DEVELOP APPS > Test Luup Code (Lua) window -- immediately after waking up the battery-powered remote by tapping one of its buttons -- and it worked perfectly!
                  LED does what it's supposed to do now. THANK YOU ALL!
                    @Pabla, you may want to try this on your problematic devices...
                    for you it would be
                    luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='??',Data='x70 4 13 1 1'},1)
                    PablaP 1 Reply Last reply
                      for you it would be
                      @rafale77 No luck, tried setting to 0 to turn off scene activation and device still fails to set user configuration. Looks like I will have to re-pair these devices. Have been trying everything this morning only got a few back online
                        Before you jump, I have something else to try... give me a moment to write it up...
                        Try manually clearing out the state variable that Vera uses to hold the Configuration Parameters:
                        luup.variable_set( "urn:micasaverde-com:serviceId:ZWaveDevice1", "VariablesSet", "", devnum )
                        luup.variable_set( "urn:micasaverde-com:serviceId:ZWaveDevice1", "ConfiguredVariable", "", devnum )
                        luup.reload()
                        Change devnum to your device number (not Zwave node number here). After doing this, hard refresh your browser and go to the device configuration page. The configuration parameters should now be empty/gone. And hopefully your device reconfigured without error.
                        By the way, the entire UI7 UI has become disastrous at maintaining sync with the Vera state variables when you're in a device's control panel, any tab. Make sure you hard refresh a lot, like after every time you do anything, and any time things don't look right. You'll see a lot of the time, it has simply lost sync and is reporting incorrect data.
                          luup.reload()
                          @toggledbits That seems to have fixed it!!
                          Is there a similar way to fix the purging associations error. One device had an association that I deleted but its not configuring past "Setting Association"
                            148.4k
