  3. Vera
  4. Unexplained "LinuxTest" admin account on my Vera?!?
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
5 Posts 4 Posters 941 Views 4 Watching
    I just peeked into my Vera Plus > User and Account Info > Other Users and much to my astonishment (and horror?) found a little surprise waiting for me, an account called "LinuxTest".
    Seems it magically has the highest possible authority ("Account Administrator") within my Vera Plus, along with a contact email of linuxtest@mailinator.com
    Does this appear on anyone else's 7.32 (beta firmware) Vera unit?
    (In case it matters... no, I've never requested or authorized Customer Support on this unit, at least not in the past 10 years.)
    Hmm. - Libra
      I just checked and I do not have any extra accounts on my VP running 7.32
      • LibraSunL LibraSun
        Hmm. - Libra
        @librasun
        I always looked at the vera's "secure tunnels" to the mcv servers as highly insecure (and there are many of them) and the vera secure as an oxymoron. The first thing I did to make the vera work better was to take it off of these nasty servers if you recall in the "off the grid thread"... and got rid of the cloud dependent mobile app... Between this and the geofence problem you have posted... These are the type of things I promised myself to never get caught by again. Foul me once, shame on you, foul me twice...
          mrFarmer
          Hi @LibraSun
          The users are at the account level, i.e. for all your Vera's not just for one, to my understanding. I am not seeing any account I did not create my self.
          Cheers Rene
            Ah, then that likely explains it, since I do have a beta-testing Ezlo Plus, and I did authorize them to create an admin account on it recently.
            MYSTERY SOLVED! (I may leave this thread intact in case others have the same question.)
              140.5k
