  4. calculate with MSR variables in LuaXP
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
9 Posts 3 Posters 2.4k Views 3 Watching
  • E Offline
    E Offline
    Edwin1972
    In MSR I have found that you can use lua code. Can I also calculate in lua with MSR variable? I have the following varaible in MSR:
    TotalTimeUp
    TimeUp_Start
    TimeDown_Start
    TimeStop
    South_Manual_MoveTime
    I want to calculate below
    if TotalTimeUp == TimeStop THEN
    South_Manual_MoveTime == (TimeUp_Start-TimeStop)
    End
    If TotalTimeDown == TimeStop
    South_Manual_MoveTime == (TimeStop-TimeDown_Start))
    END
    Maybe someone can help me
      You cannot use Lua code in MSR; you can ask a Vera controller connected to MSR to run some Lua code on the Vera, which is what the action you posted in your screen shot would do (although the Lua you provide there isn't actually a valid script).
      You also cannot use MSR variables in Lua running on the Vera. The Vera cannot "see" the MSR variables. You could, in theory, build up Lua as a string and place MSR expression results into the built-up string, which would then be sent to the Vera to be executed, but this is a kludge and is not the same as using a variable from MSR in the Lua code (i.e. you could not set the variable in the Lua code and have the value magically port back to the MSR variable's value).
      You can do the expressions above in the MSR expression language, although (I see an X-Y problem here) I suspect there are behaviors and side-effects of this you are hoping for or expecting that would not be true (some would apply both to Lua and MSR expressions).
      Why don't you tell us what you are actually trying to do, rather than asking us about one piece of how you think your problem can be solved? Your approach may be valid in some contexts, but maybe not the best/easiest way on Vera or MSR.
      Note: there is no LuaXP in MSR. LuaXP is Reactor for Vera's expression language, written in Lua. MSR uses an entirely different expression language written on entirely different code. So don't use any LuaXP knowledge or documentation to try to solve expression puzzles in MSR. The information you need for MSR is here.
      E 1 Reply Last reply
      • E Offline
        E Offline
        Edwin1972
        Thanks for the quick response. Clear answer. I will try to describe my project later. The forum may be able to help me further.
            E Offline
            E Offline
            Edwin1972
            @toggledbits My explanation of my project
            I use somfy motors (rfx) to open and close my roman blinds electrically. I can control this via RFXtrx433E USB Transceiver connect to my Vera. RFX gives no feedback so I can only open and close them and not moving them to a position based on the percentage of the slider. The RFX plugin (Tinmann) works with a slider related on MaxMoveTime (time to go from completely open to completely close)., but it doesn’t work with somfy. So I started my own project.
            I have installed the switchboard plugin on my Vera. I have created a virtual switch (virtual window coverings) and use it in MSR to close my blinds with the slider based on MaxMoveTime (time to go from completely open to completely close). It works with Vera and also with voice control by google home.
            MRS setting:
            Expression : LoadLevel_Last_Oost, MaxMoveTime_Oost
            What I haven't solved yet is the following:
            I can operate Romand blinds by MSR with time schedule but would like to operate Roman blinds manually with the fibaro roller shutter 2, double click down / up and triple click stop function. For example, with a double click function I can start the following action:
            I am using the virtual window covering (Switchboard) and switching up (double click Up), down (double click down) and stop (Triple click down). Switchboard can simulate motor movement of the covering by ramping LoadLevelStatus at a rate of XX% per second to the target value. This is the problem.
            MaxMoveTime (time to go from completely open to completely close) = 40 sec. Switchboard simulate motor movement = 34 sec (RampRatePerSecond =2).
            To set simulate motor movement =40 seconds, RamRatePerSeconde should be = 2.35. This does not work because they must be integer number. Is there a possibility to set the MaxMoveTime to simulate motor movement instead of movement % per sec?
              There's nothing enforcing RampRatePerSecond being an integer. Have you tried setting it to 2.35? It should work. The only thing that stands out as "iffy" about the whole idea is that the resolution of the timer on Vera is one second, so if the target isn't an even multiple of the ramp rate times the number of seconds needed to get to target, it will overshoot. For example, if the target is going to 22 from 0, that's 10 seconds ramping at 2.35/sec and will give you 23.5 position, not 22. And it will store the fraction in LoadLevelStatus which is probably going to make something crazy somewhere, so I've updated the stable branch release on Github to make sure it only writes the rounded whole number to LoadLevelStatus (but otherwise preserves the resolution of RampRatePerSecond).
              BTW, if it takes 40 second to go 0 to 100, that's 2.5 ramp rate, not 2.35.
              Github stable: https://github.com/toggledbits/Switchboard-Vera/tree/stable
              To install on Vera:
              1. Click the green "Code" button and choose "Download ZIP"
              2. Unzip the downloaded file.
              3. Open Apps > Develop apps > Luup files in Vera web UI
              4. Drag files (only, not folder) to "Upload button"
              5. When upload and reload finish, hard-refresh your browser.
              Expected version number in Switchboard control panel: 21098
              • E Offline
                E Offline
                Edwin1972
                Thanks! I have installed version 21098 on my vera and I entered 2.5 but it returns the same as 2. With stopwatch about 50 sec.
                  OK. Pull the latest stable again and install it. I did another update. This is a much better ramp for fractional timing. Still won't be absolutely perfect, but should not be wildly off. I've also added a "Ramping" state variable you can use to see if it's "in motion".
                    E Offline
                    E Offline
                    Edwin1972
                    Yes, it works! Excellent.
                    Thank you for your time! Now I can continue my project. The new variable is also useful.
                      164.3k
