  4. Expression to randomly run Global Reactions ?
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
39 Posts 4 Posters 13.6k Views 3 Watching
  • cw-kidC cw-kid
    OK understood I will change the expression back to how it was and remove the set variable in the set reaction area.
    I will increase the trigger repeat to 5 minutes and test it one evening when its dark outside.
    Ideally I'd like for a different colour each time to be selected, but I guess the expression for the random numbers could select the same number again and therefore the colour would not change for that cycle.
    ElcidE Offline
    ElcidE Offline
    Elcid
    wrote on last edited by Elcid
    #21
    @cw-kid said in Expression to randomly run Global Reactions ?:
    I use this to generate a random number that has not been used last time. In the reaction use express variable randomVal, once the reaction is over set randomVal to
    ${{int(split(join(split("1234567", randomVal || 0),""),"")[floor(random()*6)])}}
    Then every time you get a different number.
    • LibraSunL LibraSun
      You've got me curious now: What make/model of garden lights do you have? And what is their ultimate color palette? Have you tried setting them to intermediate colors using the [Set_Color_RGB] action in MSR, for instance?
      @librasun
      It's a Fibaro RGBW module v1
      • ElcidE Elcid
        @elcid said in Expression to randomly run Global Reactions ?:
        That's what I needed!
        ElcidE 1 Reply Last reply
        • cw-kidC cw-kid
          ElcidE Offline
          ElcidE Offline
          Elcid
          #24
          @cw-kid This is probably more efficient
          ${{int(substr(replace("1234567", randomVal || 0,""),floor(random()*6),1))}}
          Then I looked at moving this to MSR as I have it in Reactor, . I found the remove function and this is now easily expanded to larger number and you can easily set a range
          ${{remove( 1..7, randomVal - 1)[floor(random()*6)]}}
          @toggledbits , possible bug
          list(1..7]) gives [[1,2,3,4,5,6,7]] a nested array.
          Is that expected.
          toggledbitsT LibraSunL cw-kidC 3 Replies Last reply
          • ElcidE Elcid
            Is that expected.
            Is that expected.
            Yes, because 1..7 on its own produces an array. So wrapping it in list() gives you an array containing an array.
            FWIW, list() is basically deprecated, because lexpjs lets you use common array notation (e.g. [1,2,3,4,5,6,7]) to define an array.
            • ElcidE Elcid
              Is that expected.
              #26
              ${{remove( list(1..7)[0], randomVal - 1)[floor(random()*6)]}}
              GENIUS! Gonna borrow this.
              Is that expected.
              Yes, that's expected, since 1..7 itself creates an array – namely, [1,2,3,4,5,6,7] – while list() (now deprecated = avoid in MSR) also turns its argument into an array. I suggest omit list and see if things improve.
                Is that expected.
                ElcidE Offline
                ElcidE Offline
                Elcid
                @toggledbits just discovered that as you posted, is it mentioned in the docs, as I had not come acreoss it?
                  Yup. That's in the docs.
                    ElcidE Offline
                    ElcidE Offline
                    Elcid
                    #29
                    Its a bit confusing, i read this
                    "[5,7,9], so this function is now obsolete and may be removed later)"
                    and tried [1..7], when that failed, I assumed the only way to spread was list(1..7)
                    May be add a note about 1..7 being the same as list(1..7). As I found it some what unclear.
                    • ElcidE Elcid
                      #30
                      @elcid , it says:
                      I think this is pretty clear. The range operator is documented separately.
                      But it's not. That's how we got started. 🙂
                        @elcid , it says:
                        ElcidE Offline
                        ElcidE Offline
                        Elcid
                        #31
                        @toggledbits said in Expression to randomly run Global Reactions ?:
                        I mean 1..7 being what I assume list(1..7) would produce a single array. That's why I found it confusing, I think that I expected a array to have [ ] around them.
                        Maybe add "also see range operator".
                        LibraSunL 1 Reply Last reply
                        • ElcidE Elcid
                          #32
                          Funny you should mention this, since all yesterday, I grappled with the question, "How can I find the minimum of an array in MSR?" (Answer: Not easily at all!) Turns out the min() function only works on a list with 2 elements, not arrays of arbitrary length. In other words, min(1,2,3) yields 1 without a hitch, whereas min([1,2,3]) returns null (for good reason: There's no guarantee the argument will always be a 1-dimensional numeric array!). Same for max().
                          Which led me to the realization that there's no direct way in MSR to "convert" an array into a list. Seems your brain encountered the same type of mental collision while trying to work out your imported expression. 🙂
                            @librasun My notes in the code:
                            Guess it's time to get to work.
                            • cw-kidC cw-kid
                              @librasun
                              What makes the expression run and generate a new number after a period of time?
                              This is what I have so far.
                              Trigger is the virtual switch in Vera.
                              Pulse every 1 seconds and repeat every 60 seconds.
                              Set Reaction - Groups that look at the expression named "ChooseColour" and its current number value and then runs a Global Reaction now directly sets that colour on the LED strip.
                              The random number generator expression named "ChooseColour" this is a rule expression not a Global Expression.
                              I added an 1 minute interval to the triggers and the virtual switch is true trigger is also pulsing every minute.
                              The expression is now changing numbers every minute, but the reactions don't seem to be running as the colour is stuck and not changing.
                              Also I think this expression generates the number zero which I don't have assigned to any reaction.
                              @cw-kid Just so you know, I have a "Color Cycler" rule that uses the [Entity Action] [Set Color RGB] action with this expression inside each field ("R", "G" and "B"):
                              ${{ floor(random()*255) }}
                              which makes the associated light (a Hue bulb) adopt a perfectly random color. Just something you might consider trying.
                                Thanks I will try the "Color Cycler" in a brand new rule to test it out.
                                I haven't as yet looked at updating my current rule with the new expression to always guarantee a new random number that hasn't been repeated etc.
                                I will have a look over the weekend. Sure I will have questions.
                                Cheers
                                • ElcidE Elcid
                                  Is that expected.
                                  #36
                                  I've just tried using this in my rule set, I added it as the expression for the rule. When I press the play button next to it, it seems to work and changes to different numbers between 1 to 7 etc.
                                  However when I restart Reactor it says it cannot find the Global Expression named "randomVal".
                                  So I then created it as a Global Expression, the error has now gone away, but I don't understand what this Global Expression is for?
                                  • ElcidE Offline
                                    ElcidE Offline
                                    Elcid
                                    #37
                                    That should be used in the reaction as image below
                                    The expression global or normal is left blank. so every time your rule reaction runs it sets a new unique random number, ready for next time
                                    • ElcidE Elcid
                                      #38
                                      @elcid
                                      This look better now?
                                      I have added the Set Variable in the Set Reaction and made the expression empty:
                                        It looks to be working OK. Its changing the colours on the LED strip every 5 minutes currently. I'll leave it running for a while tonight.
                                          164.4k
