  4. Having issues with a shell command
60 Posts 2 Posters 22.5k Views 2 Watching
    #21
    That's right.
    Show all the values when you post an error, please.
      #22
      This is what the summary card looks like after hitting the Reset button and then the red alerts come back each time after I have cleared them
      Expressions:
      Not sure why the alerts are appearing ?
        No errors there.
          Have you removed the Set Variable actions?
            #25
            @toggledbits said in Having issues with a shell command:
            Yes
            The bell icon goes red when the rule is Reset.
              Removing the actions is/was correct. I'll give this a try later today and see
                #27
                Using a Vera Multistring plugin device.
                I added these in the rules Reaction to send the values to the generic sensor device in Vera etc.
                Just need to translate codes 200 and 620 to "On" and "Off" instead.
                I could maybe delete these two expressions from the rule also.
                EDIT:
                I've just seen a new field called "status" maybe I can use that instead.
                On = "OK"
                Off = "Standby"
                  #28
                  I had a moment to do a quick test. Duh; I'm forgetting my own code's behavior. This is actually pretty simple. When you reset the rule, all state and expression/variable values are removed, so effectively, everything is null. When the rule is then re-evaluated, expressions are evaluated first, and since ps4wakercheck is null at that point because the action has not yet run, then ps4wakerparse is also null, so the last two expressions can't dereference through null and throw an evaluation error. This is actually all expected, correct behavior.
                  You can probably just clear these two spurious errors (caused by the reset/no data condition at rule "boot"), as they will not happen again, typically. The only other way you would see this is if the command actually fails hard in some way and produces no parseable JSON output. Then you'll get alerts again, but that's probably good because you might want to know that.
                  Another way to handle it is to simply modify the last two expressions like this:
                  • ps4powerstatus = ps4wakerparse?.statusCode
                  • ps4runningapp = ps4wakerparse?["running-app-name"]
                  The ?. and ?[ operators, described in the docs, are special coalescing versions of the standard . and [ operators that guard null on their left-hand operands. If the left-side operand value is null, the coalescing operator will simply return null and no error will be issued. I think this also makes sense in this application. These coalescing operators are provided for exactly this kind of case, so this is a perfect example of their use, and you should familiarize yourself with them (and apply them often).
                    #29
                    You can map a value from one to another using a simple map object, like this:
                    mappedStatus = ( { '200': 'On', '620': 'Off' } )?[ ps4wakerparse.statusCode ] ?? "unknown"
                    Here, we create an object on the fly (the ( { ... } ) part), dereference through it using the ?[ coalesce operator, which will return null if the value of statusCode doesn't match anything in the object, and then use a final ?? coalesce operator to change an unmapped/null to the word unknown
                    Ref: Reactor docs: Expressions
                      That fixes it the red alerts don't appear any more when Resetting the rule.
                        #31
                        Finished device in Vera:
                        Home Remote dashboard tile:
                        Had to just add an additional ? to this code to stop the red alert appearing again.
                        ( { '200': 'On', '620': 'Off' } )?[ ps4wakerparse?.statusCode ] ?? "unknown"
                        And now the alert doesn't come back again when resetting the rule.
                        So I think everything is all working fine now, at least while the PS4 is turned ON.
                          #32
                          So everything last night was working OK when the PS4 was turned ON.
                          I am now testing when the PS4 is OFF.
                          Some issues the shell command doesn't seem to be populating the ps4wakercheck variable for some reason and its null.
                          Vera device when PS4 is OFF
                          If I run the "ps4-waker check" command in terminal it outputs correctly as expected.
                          root@HP-Thin01:/home/stuart# ps4-waker check
                            "type": "device",
                            "statusLine": "620 Server Standby",
                            "statusCode": "620",
                            "status": "Standby",
                            "host-id": "C863F1400EF1",
                            "host-type": "PS4",
                            "host-name": "PS4-806",
                            "host-request-port": "997",
                            "device-discovery-protocol-version": "00020020",
                            "system-version": "08520011",
                            "address": "192.168.0.201"
                          Log file:
                          2021-08-02T10:51:27.077Z <Engine:NOTICE> Starting reaction PS4 Waker Check<SET> (rule-krq612qx:S)
                          2021-08-02T10:51:27.077Z <Engine:5:Engine.js:1378> Engine#1 reaction rule-krq612qx:S step 1 shell command { "command": "ps4-waker check", "rule": "rule-krq612qx", "rvar": "ps4wakercheck", "ignore_exit": true }
                          2021-08-02T10:51:27.094Z <Engine:5:Engine.js:1105> _process_reaction_queue() task returned, new status 3; task 19
                          2021-08-02T10:51:27.098Z <Engine:5:Engine.js:1140> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting
                          2021-08-02T10:51:27.617Z <Engine:ERR> Engine#1 reaction PS4 Waker Check<SET> step 1 error executing shell `ps4-waker check': Error: Command failed: ps4-waker check
                          2021-08-02T10:51:27.620Z <Rule:5:Rule.js:674> Rule#rule-krq612qx rule set variable ps4wakercheck = (object) (null)
                          2021-08-02T10:51:27.621Z <Engine:5:Engine.js:940> Engine#1 set variable rule rule-krq612qx ps4wakercheck=(null), requesting re-eval
                          2021-08-02T10:51:27.624Z <Rule:5:Rule.js:962> Rule#rule-krq612qx (PS4 Waker Check) evaluate() acquiring mutex
                          2021-08-02T10:51:27.625Z <Engine:5:Engine.js:1140> _process_reaction_queue() wake-up!
                          2021-08-02T10:51:27.625Z <Rule:5:Rule.js:966> Rule#rule-krq612qx._evaluate() mutex acquired, evaluating
                          2021-08-02T10:51:27.626Z <Rule:5:Rule.js:970> Rule#rule-krq612qx update rate is 2/min limit 60/min
                          2021-08-02T10:51:27.627Z <Rule:5:Rule.js:892> Rule#rule-krq612qx evaluateExpressions() with 3 expressions
                          2021-08-02T10:51:27.628Z <Rule:5:Rule.js:982> Rule#rule-krq612qx._evaluate() trigger state now false (was false)
                          2021-08-02T10:51:27.629Z <Rule:5:Rule.js:984> Rule#rule-krq612qx._evaluate() constraints state true
                          2021-08-02T10:51:27.629Z <Rule:5:Rule.js:993> Rule#rule-krq612qx rule state now false, changed no
                          2021-08-02T10:51:27.631Z <Engine:5:Engine.js:1101> _process_reaction_queue() running task 19 { "tid": 19, "id": "rule-krq612qx:S", "rule": "rule-krq612qx", "__reaction": [RuleReaction#rule-krq612qx:S], "next_step": 2, "status": 1, "ts": 1627901487069, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 1 }
                          2021-08-02T10:51:27.632Z <Engine:NOTICE> Resuming reaction PS4 Waker Check<SET> (rule-krq612qx:S) from step 2
                          2021-08-02T10:51:27.632Z <Engine:NOTICE> PS4 Waker Check<SET> delaying until 1627901492632<02/08/2021, 11:51:32>
                          2021-08-02T10:51:27.633Z <Engine:5:Engine.js:1105> _process_reaction_queue() task returned, new status 2; task 19
                          2021-08-02T10:51:27.636Z <Engine:5:Engine.js:1140> _process_reaction_queue() ending with 1 in queue; waiting for 1 (next delayed task)
                          If I turn ON the PS4 it starts working again and the variable is populated with data via the shell command.
                            #33
                            Make sure you restarted Reactor after installing the update. The ignore flag is in the action data (so the UI has done the right thing), but the log file content looks like an older version of the Engine running.
                              Any update on this?
                                Any update on this?
                                Sorry for the delay.
                                Yes its working now after restarting MSR.
                                So when the PS4 is OFF its now reporting the status correctly from the ps4-waker check variables.
                                So its working when its on and off now.
                                However I am still getting some alert errors sometimes occasionally.
                                This seems to happen if the shell command doesn't return any response on the first go, but maybe on the second attempt it works and then populates the variables OK.
                                When this happens these alerts remain in the MSR gui etc.
                                  Use your coalesce operators on those expressions to suppress the reference errors and just yield a null result.
                                    #37
                                    The actions in the Reaction that send the data to the Vera MutliString device, didn't have "?" in their expressions.
                                    I have just added them like this:
                                    af2110ec-866f-49ea-b68a-ad78217f406b-image.png fe8507c9-65d5-47cf-985e-b1c2ac880567-image.png
                                    EDIT:
                                    It doesn't like the first one " mappedstatuscode? " I've removed the question mark for that one.
                                      #38
                                      I've also now added a virtual switch in Vera, this works with two new MSR rules (#3 and #4).
                                      First rule (#4), that when the virtual switch it turned on or off manually in Vera / Home Remote app, it will send the appropriate power command to the ps4 via shell command:
                                      ON = ps4-waker
                                      OFF = ps4-waker standby
                                      The second rule (#3) updates the state of the Vera virtual switch, if the PS4's power is controlled by some other outside means.
                                      This rule monitors the "mappedstatuscode" expression variable, which will either say "On" or "Off" and then it adjusts the Vera virtual switch accordingly to match that current actual state of the PS4, so the virtual switch doesn't get out of sync.
                                      I am still experimenting with this, but my thinking was to have an additional "switch" in Vera / Home Remote app, to be able to manually / directly control the PS4's power (outside of a Harmony activity) as a backup switch. Say if the PS4 didn't turn on when the Harmony Activity for it was started and the other MSR rule (#1) didn't work with its attempt and didn't turn on the PS4.
                                      Although having said that, I guess some kind of test and retry (in rule #1) to attempt to turn on the PS4 power again, might be a better way of doing it, if it failed to do so initially.
                                      So in total I currently have four rules.
                                      1. "Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command"
                                      Turns on PS4 when Harmony Activity is starting.
                                      1. "PS4 Waker Check"
                                      This is the rule with all the expressions in it for the MultiString Vera device. Displays the PS4's current status etc
                                      1. "Playstation 4 Virtual Switch Status from PS4-Waker"
                                      Controls the virtual switch in Vera based on the actual state of the PS4 power, info as coming from ps4-waker check and rule #2
                                      1. "Playstation 4 Virtual Switch ON / OFF"
                                      Sends either the on or off shell commands to the PS4 based on the virtual switch in Vera / Home Remote app being manually operated.
                                      Home Remote tiles:
                                      I am sure there must be better / easier ways of doing all this.
                                        Have you figured out what ps4-waker does when it doesn't get the device turned on? Does it return a particular exit code that isn't used by the on/off status result? Or does it just give an empty reply? Either way, you might write a wrapper script to detect that and retry (Reactor would then start the wrapper script instead of ps4-waker directly.
                                        Issues like this are how you bring your shell scripting and system administration skills up a notch.
                                        cw-kidC 2 Replies Last reply
                                          #40
                                          I'm not sure, I will look out for when it happens again.
                                          I think it makes MSR error when it tries to send the "ps4-waker" command to turn ON the games console but fails to connect for whatever reason.
                                          Most times it works and the console does turn on but sometimes it doesn't.
                                            138.8k
