  3. Z-Wave.me
  4. Z-way several questions
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
9 Posts 2 Posters 2.2k Views 2 Watching
    sender
    So I installed z-way and I have a bunch of questions. I also sent an email to z-way@zwave.me but might receive an answer here quicker 🙂
    1. MQTT. I cant get MQTT to work. I need integration for homeassistant! What can I do?
    2. I have ordered a UZB1 via amazon including license. It is not yet connected to my z-way server. When I want to go to settings I get below, is this normal? Installing the remote app does not solve this.
    3. Setting the time zone in the standard interface says it is save but it is not. What is wrong there?
      Also going to the expert screen does not save it:
      1. Can’t help with that one as I don’t use this. Hopefully you will get an answer through emails.
      2. Remote access only works on the rPi as it relies on little program not available for other distros. It is completely unimportant unless you want their support team to dial into your z-way-server instance.
      3. You don’t need to worry about time. It is already controlled by the ubuntu OS. This is a leftover from “embedded image installations” like on a pi. You can ignore this.
        sender
        These all 3 are stressing my OCD.
        So for question 1. What's left is: How can I get Z-way zwave devices integrated in home assistant?
        I now have a few options for z-wave on home assistant and all 4 have their downsides... as far as I have seen z-way it must be the most promising one but for the fact I have never seen it in action 🙂
        These are my z-wave options now.
        1. Vera
        2. zwave2mqtt but this is old... (see: https://github.com/hassio-addons/addon-zwave2mqtt/issues/54 and https://community.home-assistant.io/t/home-assistant-community-add-on-z-wave-to-mqtt/115899/148?
        3. z-way
        4. QT-zwave2mqtt - but this is more vague than all 3 above but also seems promising as I read is is the succesor of zwave2mqtt and both ahve openzwave 1.6 (see https://community.home-assistant.io/t/choosing-a-bridge-openzwave-qt-openzwave-vs-openzwave-zwave2mqtt/179002/1)
        Thus... questions, options, questions...
          My personal opinion:
          Only z-way and QT-zwave would be of consideration. QT is still major WIP. Looks promising but who knows...
          Z-way is pretty mature on the other hand and is with HomeSeer the only choice at the moment.
          As for the plugin installation problem, makes sure you installed openSSH. Have you tried installing any other plugin?
          There was a problem with the curl version initially which may or may not have been resolved. ubuntu 18 introduced curl4 which z-way was not supporting. You may need to force install curl3. I don't seem to be having this problem but I upgraded from ubuntu 16. Try making sure that openssl is installed first and see if it works.
            sender
            So received an answer from z-way:
            It seems the "ubuntu" and thus UZB (dongle) way is not the preferred one reading the answers. Sergei is pointing me toward a PI solution but I do not really prefer that.
            Below his answers and my response.
            A.
            Me:MQTT. I cant get MQTT to work. I need integration for homeassistant. What can I do?
            Z-way: This looks like libcurl problem on your Ubuntu. What is your system?
            Me: 2. Ubuntu 18.04.4 LTS (GNU/Linux 4.15.0-99-generic x86_64) as a virtual machine in ESX.
            I prefer running in VM for several reasons, portability, ability to consistantly backup (entire machines) and to avoid “additional” hardware and network issues.
            B.
            Me: How to auto start?
            Z-way: You can add in /etc/rc.local: (cd <YOURFOLDER>; LD_LIBRARY_PATH=./libs ./z-way-server)
            This is dirty, but works. We plan to make a clean debian package soon.
            Me: I followed: https://smarthome.community/topic/108/auto-start-z-way-server works now.
            C.
            Me: 4. I have ordered a UZB1 via amazon including license. It is not yet connected to my z-way server. When I want to go to settings I get a message ERROR - Remote Access is not ebabled. Is this normal? Installing the remote app does not solve this.
            Z-way: Remote access is not working on Ubuntu. We think to change this in next releases too.
            Me: I think I don’t need RA. Can I disable the error message?
            D.
            Me: Setting the time zone in the standard interface says it is save but it is not. What is wrong there?
            Z-way: Same - this can be done on Ubuntu using standard UI, so it is not working via Z-Way. This feature is also for Raspberry Pi.
            Me: I have changed the time on the ubuntu server to correct time-zone, this solves the wrong time displaying in Z-way.
            What is left now as a real problem for me is "A"... I do not really understand what Sergei is meaning with "libcurl" problem and have asked him. But maybe someone on this forum is able to help out?
              For A, did you try what I suggested on my previous post? It is an operating system compatibility problem and has nothing to do with what machine you are running. Libcurl is a standard linux library which got updated to v4 on most distributions. You would have the same problem on the rPi if you try installing in raspbian buster... lots of people reported it. You can try downgrading libcurl on your installation.
                sender
                rafale, yes tried, but I had no success. maybe I did something wrong. i was not able to install curl3... (see other post on fourm)
                  sender
                  root@z-way-server:~# # install libcurl3
                  root@z-way-server:~# # this will temporarely overwrite/remove libcurl4
                  root@z-way-server:~# apt-get -y install libcurl3
                  cp /usr/lib/x86_64-linux-gnu/libcurl.so.4.5.0 /usr/lib/x86_64-linux-gnu/libcurl3.so.4.5.0
                  # reinstall libcurl4 - libcurl3 will be overwritten but copied file will be still there
                  apt-get -y install libcurl4 libcurl4-openssl-dev
                  Reading package lists... Done
                  Building dependency tree
                  Reading state information... Done
                  libcurl3 is already the newest version (7.58.0-2ubuntu2).
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  root@z-way-server:~# # Making a copy of libcurl.so.4.5.0 and rename it to libcurl3.so.4.5.0
                  root@z-way-server:~# cp /usr/lib/x86_64-linux-gnu/libcurl.so.4.5.0 /usr/lib/x86_64-linux-gnu/libcurl3.so.4.5.0
                  root@z-way-server:~# # reinstall libcurl4 - libcurl3 will be overwritten but copied file will be still there
                  root@z-way-server:~# apt-get -y install libcurl4 libcurl4-openssl-dev
                  Suggested packages:
                    libcurl4-doc libidn11-dev libkrb5-dev libldap2-dev librtmp-dev libssh2-1-dev
                    libssl-dev pkg-config zlib1g-dev
                  The following packages will be REMOVED:
                    libcurl3
                  The following NEW packages will be installed:
                  0 upgraded, 2 newly installed, 1 to remove and 0 not upgraded.
                  Need to get 509 kB of archives.
                  After this operation, 1397 kB of additional disk space will be used.
                  Get:1 http://nl.archive.ubuntu.com/ubuntu bionic-updates/main amd64 libcurl4 amd64 7.58.0-2ubuntu3.8 [214 kB]
                  Get:2 http://nl.archive.ubuntu.com/ubuntu bionic-updates/main amd64 libcurl4-openssl-dev amd64 7.58.0-2ubuntu3.8 [294 kB]
                  Fetched 509 kB in 0s (1097 kB/s)
                  (Reading database ... 68576 files and directories currently installed.)
                  Removing libcurl3:amd64 (7.58.0-2ubuntu2) ...
                  Selecting previously unselected package libcurl4:amd64.
                  (Reading database ... 68569 files and directories currently installed.)
                  Preparing to unpack .../libcurl4_7.58.0-2ubuntu3.8_amd64.deb ...
                  Unpacking libcurl4:amd64 (7.58.0-2ubuntu3.8) ...
                  Selecting previously unselected package libcurl4-openssl-dev:amd64.
                  Preparing to unpack .../libcurl4-openssl-dev_7.58.0-2ubuntu3.8_amd64.deb ...
                  Unpacking libcurl4-openssl-dev:amd64 (7.58.0-2ubuntu3.8) ...
                  Setting up libcurl4:amd64 (7.58.0-2ubuntu3.8) ...
                  Setting up libcurl4-openssl-dev:amd64 (7.58.0-2ubuntu3.8) ...
                  Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
                  Processing triggers for libc-bin (2.27-3ubuntu1) ...
                    This is the process for ubuntu 18+ on a x86 machine:
                    sudo systemctl stop z-way-server
                    sudo apt-get -y install libcurl3
                    sudo cp /usr/lib/x86_64-linux-gnu/libcurl.so.4 /usr/lib/x86_64-linux-gnu/libcurl.so.3
                    sudo apt-get -y install libcurl4 libcurl4-openssl-dev
                    sudo systemctl start z-way-server
                      155.6k
