  3. Z-Wave.me
  4. Cannot add ZOOZ power strip in Zway
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
8 Posts 2 Posters 1.9k Views 2 Watching
    RogerO
    Hello,
    Recently picked up a 5 socket zooz powerstrip to use to test with. Tried adding to my Razberry setup and while I can get it to be seen, the only thing showing in the Z-Wave app are the master switch, and two power monitors (KWh and W). None of the individual sockets are showing up. Anyone have any experience with power strips?
      I think this device is very similar to the one @iRobot was discussing. Have you completed interview and can you show what command class it displays after NIF/forced interview?
        RogerO
        Not sure what you are asking for.
        • R RogerO
          @RogerO
          This is likely the problem... How did you include it on the razberry?
          The inclusion of more complex devices must be done through the expert UI.
          You would go under Device/Status of the expert UI and then select the device in question after which you should see this:
          where you can see the call for NIF button, the force interview button and the list of command classes I spoke of.
          I also suspect that this power strip support S2 security class so you may need to include it securely with S2.
            RogerO
            I did it through the expertUI. It fails some of the Interviews:
            Failed ones are:
            SwitchBinary
            AssociationGroupInformation
            ZWavePlusInfo
            MultiChannel
            ManufactureSpecific
            PowerLevel
            FirmwareUpdates
            Association
            Version
            MultiChannelAssociation
            SecurityS2
            How do I remove it from Zwave? Don't see that option in the expert UI.
              It is not uncommon to not get to 100%. Some devices have a command class registered on their list but actually don't have them implemented in their firmware. (it's the fault of the device manufacturer who may have forgotten to remove it from their node info)
              This does not appear to be your case. I suspect for you that the problem comes from the non secure inclusion which zooz may not support. Do you have one which succeeded called "security"?
              For exclusions, go under the "Network" menu and into the "control" screen. This is where you can include with or without security too.
              If your device supports non secure inclusion, you may want to look into its manual as well. I know I had an Aeotec plug which needed to follow different wakeup sequences depending on whether they were to be included securely or not.
              To use S2 inclusion, you will need an S2 key which should be somewhere in the device documentation or packaging.
              Edit: Have you tried going into the interview results and manually interview the command classes one by one? Sometimes this is required if the device has a lot of command classes and is not respond timely to how fast the "forced interview" process from z-way is.
                RogerO
                Going from bad to worse. Now when I try to add it in the expert UI, it says "device fond" and then does nothing. I can include and exclude all day long but the device never shows up. Argh.
                  It doesn't show up on the device menu list? It will not show up in the control screen obviously. This would be rather odd. I have never see this behavior, neither myself nor on the zwave.me official forum.
                  One other possibility is that it requires S2 and you would need to follow the S2 process from the smart home UI. Generally if it says device found and does nothing, it either means the device is already included in the list or that it is expecting something else (ie. key exchanges) to happen. Either way, the device should be displayed in the device list.
