  2. Blogs
  3. My migration from Vera, or what I did on my holidays
Seeking Advice:
Blogs
L
Blogs
Blogs
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
105 Posts 6 Posters 78.0k Views 7 Watching
    Nest closed its APIs, so you cannot request a new key, but previous integrations works. I may have a key or two laying around. We’ll see.
    CatmanV2C rafale77R 2 Replies Last reply
      @therealdb said in My migration from Vera, or what I did on my holidays:
      Ahhh I see!
        Yeah and this was the trigger which motivated me to get rid of my nest protects and ban google devices and replace all the other unnecessarily cloud dependent ecosystems.
          Yep, but they’re way more stylish than other options and style is very important to me. Wife demands style too, so I can’t really change them right now.
            You could just hide them! 😉
              1.1k
              159.0k
