  2. Blogs
  3. My migration from Vera, or what I did on my holidays
Seeking Advice:
Blogs
L
Blogs
Blogs
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
105 Posts 6 Posters 78.0k Views 7 Watching
    Whatever you say, boss. this was after a Luup reload.
    2020-06-20 20:40:04.474   :: openLuup LOG ROTATION :: (runtime 0.0 days)
    2020-06-20 20:40:04.474   openLuup.init:: init phase completed
    2020-06-20 20:40:04.474   openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x2683d34
    2020-06-20 20:40:04.474   openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x2685da4
    2020-06-20 20:40:04.474   openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x2688224
    2020-06-20 20:40:04.475   openLuup.historian:: starting data historian
    2020-06-20 20:40:04.475   openLuup.historian:: using memory cache size (per-variable): 1024
    2020-06-20 20:40:04.475   openLuup.scheduler:: starting
    2020-06-20 20:40:04.475   openLuup.scheduler:: [2]     openLuup device startup
    2020-06-20 20:40:04.475   luup_log:2: v20.5.22
    2020-06-20 20:40:04.475   luup_log:2: sync in 115.5 s
    2020-06-20 20:40:04.475   luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode
    2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local
    2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local
    2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local
    2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local
    2020-06-20 20:40:04.475   luup.chdev.append:: [AltAppStore] Alternate App Store
    2020-06-20 20:40:04.475   luup.chdev.sync:: [2]     openLuup, syncing children
    2020-06-20 20:40:04.476   luup_log:2: 3Mb, 0.1%cpu, 0.0days
    2020-06-20 20:40:04.476   openLuup.scheduler:: [2]     openLuup device startup completed: status=true, msg=sync in 115.5 s, name=L_openLuup
    2020-06-20 20:40:04.476   openLuup.scheduler:: [3] Alternate UI device startup
    2020-06-20 20:40:04.476   luup_log:3: ALTUI: initstatus(3) starting version: v2.49b
    2020-06-20 20:40:04.476   openLuup.scheduler:: [3] Alternate UI device startup completed: status=, msg=, name=
    2020-06-20 20:40:04.476   openLuup.scheduler:: [7] VeraBridge device startup
    2020-06-20 20:40:04.476   luup_log:7: VeraBridge
    2020-06-20 20:40:04.476   luup_log:7: 2020.04.30
    2020-06-20 20:40:04.476   luup_log:7: 192.168.70.6
    2020-06-20 20:40:04.476   luup_log:7: device clone numbering starts at 10000
    2020-06-20 20:40:04.476   luup_log:7: VeraBridge maps remote Zwave controller
    2020-06-20 20:40:04.476   luup_log:7: v20.4.30
    2020-06-20 20:40:04.644   luup_log:7: Vera info received!
    2020-06-20 20:40:04.644   luup_log:7: MiOS-50103066
    2020-06-20 20:40:04.644   luup_log:7: new room number: 1
    2020-06-20 20:40:04.644   luup_log:7: PK_AccessPoint = 50103066
    2020-06-20 20:40:04.644   luup_log:7: BuildVersion = *1.7.4833*
    2020-06-20 20:40:04.644   luup_log:7: number of remote devices = 117
    2020-06-20 20:40:04.644   luup.create_device:: [1] D_ZWaveNetwork.xml / X /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
    2020-06-20 20:40:04.645   luup.create_device:: [10002] D_ZigbeeNetwork.xml /  /    ()
    2020-06-20 20:40:04.645   openLuup.chdev:: ERROR: unable to read XML file D_ZigbeeNetwork.xml
    2020-06-20 20:40:04.645   luup.create_device:: [10003] D_BluetoothNetwork.xml /  /    ()
    2020-06-20 20:40:04.645   openLuup.chdev:: ERROR: unable to read XML file D_BluetoothNetwork.xml
    2020-06-20 20:40:04.645   luup.create_device:: [10004] D_SceneController1.xml /  /    ()
    2020-06-20 20:40:04.645   openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml
    2020-06-20 20:40:04.646   luup.create_device:: [10006] D_SceneController1.xml /  /    ()
    2020-06-20 20:40:04.646   openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml
    2020-06-20 20:40:04.646   luup.create_device:: [10007] D_SceneController1.xml /  /    ()
    2020-06-20 20:40:04.648   luup.create_device:: [10008] D_MotionSensor1.xml / X / D_MotionSensorWithTamper1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
    2020-06-20 20:40:04.648   luup.create_device:: [10009] D_TemperatureSensor1.xml /  /    ()
    2020-06-20 20:40:04.648   openLuup.chdev:: ERROR: unable to read XML file D_TemperatureSensor1.xml
    2020-06-20 20:40:04.649   luup.create_device:: [10010] D_LightSensor1.xml /  /    ()
    2020-06-20 20:40:04.649   openLuup.chdev:: ERROR: unable to read XML file D_LightSensor1.xml
    2020-06-20 20:40:04.650   luup.create_device:: [10011] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
    2020-06-20 20:40:04.650   luup.create_device:: [10015] D_DimmableLight1.xml /  /    ()
    2020-06-20 20:40:04.650   openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml
    2020-06-20 20:40:04.652   luup.create_device:: [10018] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
    2020-06-20 20:40:04.654   luup.create_device:: [10019] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
    2020-06-20 20:40:04.655   luup.create_device:: [10020] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
    2020-06-20 20:40:04.657   luup.create_device:: [10023] D_ALTUI.xml / X / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
    2020-06-20 20:40:04.657   luup.create_device:: [10026] D_DayTime.xml /  /    ()
    2020-06-20 20:40:04.657   openLuup.chdev:: ERROR: unable to read XML file D_DayTime.xml
    2020-06-20 20:40:04.657   luup.create_device:: [10027] D_HouseModes.xml /  /    ()
    2020-06-20 20:40:04.657   openLuup.chdev:: ERROR: unable to read XML file D_HouseModes.xml
    2020-06-20 20:40:04.657   luup.create_device:: [10031] D_DigitalSecurityCamera2.xml /  /    ()
    2020-06-20 20:40:04.657   openLuup.chdev:: ERROR: unable to read XML file D_DigitalSecurityCamera2.xml
    2020-06-20 20:40:04.658   luup.create_device:: [10033] D_DigitalSecurityCamera2.xml /  /    ()
    2020-06-20 20:40:04.658   openLuup.chdev:: ERROR: unable to read XML file D_DigitalSecurityCamera2.xml
    2020-06-20 20:40:04.659   luup.create_device:: [10037] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
    2020-06-20 20:40:04.661   luup.create_device:: [10041] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
    2020-06-20 20:40:04.662   luup.create_device:: [10057] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
    2020-06-20 20:40:04.663   luup.create_device:: [10061] D_DimmableLight1.xml /  /    ()
    2020-06-20 20:40:04.663   openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml
    2020-06-20 20:40:04.663   luup.create_device:: [10062] D_DimmableLight1.xml /  /    ()
    2020-06-20 20:40:04.663   luup.create_device:: [10079] D_Heater1.xml /  /    ()
    2020-06-20 20:40:04.663   openLuup.chdev:: ERROR: unable to read XML file D_Heater1.xml
    2020-06-20 20:40:04.664   luup.create_device:: [10080] D_Heater1.xml /  /    ()
    2020-06-20 20:40:04.664   openLuup.chdev:: ERROR: unable to read XML file D_Heater1.xml
    2020-06-20 20:40:04.664   openLuup.context_switch::  ERROR: [dev #7] ./openLuup/devices.lua:538: table index is nil
    2020-06-20 20:40:04.664   openLuup.scheduler:: job aborted : ./openLuup/devices.lua:538: table index is nil
    2020-06-20 20:40:04.664   openLuup.scheduler:: [4] Alternate App Store device startup
    2020-06-20 20:40:04.664   luup_log:4: AltAppStore : starting...
    2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: AltAppStore #hooks:0
    2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was:  now:  #hooks:0
    2020-06-20 20:40:04.664   luup_log:4: AltAppStore : v20.3.30
    2020-06-20 20:40:04.664   luup.set_failure:: status = 0
    2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
    2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
    2020-06-20 20:40:04.664   openLuup.scheduler:: [4] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore
    2020-06-20 20:40:05.372   openLuup.io.server:: HTTP:3480 connection from 192.168.70.251 tcp{client}: 0x27493a4
    2020-06-20 20:40:05.373   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=578672005&Timeout=60&MinimumDelay=1500&_=1592671339440 HTTP/1.1 tcp{client}: 0x27493a4
    2020-06-20 20:40:05.602   openLuup.server:: request completed (128491 bytes, 9 chunks, 228 ms) tcp{client}: 0x27493a4
    2020-06-20 20:40:05.602   luup_log:3: ALTUI: startupDeferred, called on behalf of device:3
    2020-06-20 20:40:05.606   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49b now: v2.49b #hooks:0
    2020-06-20 20:40:05.649   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"key":"nodeid","type":"number","default... #hooks:0
    2020-06-20 20:40:05.650   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"key":"nodeid","type":"number","default... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0
    2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0
    2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToSend was:  now:  #hooks:0
    2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.RemoteVariablesToWatch was:  now:  #hooks:0
    2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToWatch was:  now:  #hooks:0
    2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now: [] #hooks:0
    2020-06-20 20:40:05.651   luup_log:3: ALTUI: Wkflow - enableWorkflows(3,0,0)
    2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now:  #hooks:0
    2020-06-20 20:40:05.652   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.WorkflowsActiveState was: [] now:  #hooks:0
    2020-06-20 20:40:05.652   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.WorkflowsVariableBag was:  now:  #hooks:0
    2020-06-20 20:40:05.652   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.WorkflowsActiveState was:  now: [] #hooks:0
    2020-06-20 20:40:05.652   luup.register_handler:: global_function_name=myALTUI_Handler, request=ALTUI_Handler
    2020-06-20 20:40:05.654   luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.RunLua
    2020-06-20 20:40:05.654   luup.register_handler:: global_function_name=ALTUI_LuaRunHandler, request=ALTUI_LuaRunHandler
    2020-06-20 20:40:05.655   luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.RunLua
    2020-06-20 20:40:05.656   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was:  now: [] #hooks:0
    2020-06-20 20:40:05.656   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.PendingReset was: 0 now: 0 #hooks:0
    2020-06-20 20:40:05.662   luup.set_failure:: status = 0
    2020-06-20 20:40:05.662   luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
    2020-06-20 20:40:05.662   luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
    2020-06-20 20:40:05.662   luup_log:3: ALTUI: startup completed
    2020-06-20 20:40:05.669   openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=578663463&_=1592671339441 HTTP/1.1 tcp{client}: 0x27493a4
    2020-06-20 20:40:05.857   openLuup.server:: request completed (179603 bytes, 12 chunks, 187 ms) tcp{client}: 0x27493a4
    2020-06-20 20:40:07.905   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=682008955&Timeout=60&MinimumDelay=1500&_=1592671339442 HTTP/1.1 tcp{client}: 0x27493a4
    2020-06-20 20:40:08.014   openLuup.server:: request completed (20870 bytes, 2 chunks, 108 ms) tcp{client}: 0x27493a4
    2020-06-20 20:40:08.166   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=682008971&Timeout=60&MinimumDelay=1500&_=1592671339443 HTTP/1.1 tcp{client}: 0x27493a4
    2020-06-20 20:41:08.520   openLuup.server:: request completed (363 bytes, 1 chunks, 60353 ms) tcp{client}: 0x27493a4
    Hit update. Showing 2.4.30 No change in the devices (I don't have an update button on the console page, but I did it from AltUI)
      Can you update openLuup from the development branch, and try again?
        Happy to, but, ummm, how?
        Cheers
          #24
          Type development into the box on the openLuup line on the Plugins page (either in AltUI or openLuup console) and click the Update (recycle icon) button. Then wait for a reload (~15 seconds)
            So Home>Plugins has 20.4.30 still
            Need logs?
            Cheers
              Well, you’re doing something not right, because I’ve just followed that recipe and now I’m running v20.6.20.
                Hmmm, not sure what to do then chap.
                Open AltUI
                More > Plugins
                Type 'development' into the update box (is that case sensitive? I've tried both)
                Hit the update button and wait. Refresh browser and it's still 2.4.30
                Force a luup reload, and nothing changes 😞
                Is there an manual install?
                Cheers
                  #28
                  OK so Luser error. I was trying to update Verabridge, 😞
                  Now I have all my devices. Verabridge has the details for the Vera and looks like all my devices are in.
                  Everything looks like it should be OK, so more playing tonight. Thanks!
                    #29
                    So what are my next steps, gents?
                    I assume a UZB stick will need to be purchased and I can look at migrating some of the devices that are easy / non critical over.
                    Or perhaps a better direction would be to go for the HA Bridge plug in and then get Alexa skill working?
                    Thoughts?
                      Dived in to get HA-bridge up and running. Not too hard, but getting the config was a bit trickier. Using the base instructions here:
                      GitHub - bwssytems/ha-bridge: Home automation bridge that emulates a Philips Hue light system and can control other systems such as a Vera, Harmony Hub, Nest, MiLight bulbs or any other system that...
                      Home automation bridge that emulates a Philips Hue light system and can control other systems such as a Vera, Harmony Hub, Nest, MiLight bulbs or any other system that has an http/https/tcp/udp int...
                      I installed in my home directory on Debian so
                      mdkir /home/catman/ha-bridge
                      cd /home/catman/ha-bridge
                      wget https://github.com/bwssytems/ha-bridge/releases/download/v5.3.0/ha-bridge-5.3.0.jar
                      Creating the service file gave me a choice, I could either change the file or make symlink the folder referenced, which was what I actually went for
                      sudo mkdir /home/pi
                      chmod 555 /home/pi
                      cd /home/pi
                      sudo ln -s /home/catman/ha-bridge/ ha-bridge
                      The systemctl was all fine but it failed on start with the pretty obvious fact that java was missing!
                      sudo apt-get install default-jdk
                      Then it fired up fine, but going to my IP address gave me the Debian apache2 landing page. So that needed fixing. I decided to change the port number to 8080 using:
                      -Dserver.port=<port number>
                      So my service command is now:
                      ExecStart=/usr/bin/java -jar -Dserver.port=8080 -Dconfig.file=/home/pi/ha-bridge/data/habridge.config /home/pi/ha-bridge/ha-bridge-5.3.0.jar
                      Quick demon reload and ha-bridge reload and there it is on port 8080;
                      Excellent!
                        Even better. Using HTTP to my vera IP I have successful voice control!
                            They are at the right place. It's gotta be something else. Unless the device json file indicates a completely different path... Or altui can't read the json files?
                              @rafale77 said in My migration from Vera, or what I did on my holidays:
                              I don't know what it was. It all started working when I checked in another browser on another machine.
                              FWIW some of the ones originally in 'icons' had had 0b file size. I supect there was an abortive copy at some point and then subsequent 'get Vera files' took a safe option. I manually scped them all over, but still didn't work when I posted that message.
                              I guess some odd caching (even though I was very rigorous with my cmd-R
                              So another challenge has reared its head.
                              Tried to start migrating some of my Reactor sensors over per my other thread.
                              Turns out that Vera Bridge seems to poll Vera every 80 seconds or so. That causes reactor to see an update sl_Central_Scene change and thus triggers. This took some time to work out! 😄
                              This puts something of a crimp in my plans. My understanding is this:
                              I can plug my (soon to arrive) UZB into my Vera and move all my devices on to it. Then plug it into the NUC and there they all all. That was the big bang I was rather hoping to avoid.
                              What I suspect I can't do is plug the UZB into the NUC. Un pair the controllers from Vera, pair them to the NUC, confirm a stack of functionality and then plug the UZB into Vera.
                              Or am I being too pessimistic?
                              Dunno if this post needs to be moved?
                              Cheers
                                Cheers
                                @CatmanV2 said in My migration from Vera, or what I did on my holidays:
                                Not uncommon then. Glad you got over this. The icons do get aggressively cached by browsers and sometimes require some brute force "empty the browser cache"
                                Hmm I don't remember it doing this. A number of people are running reactor through openLuup verabridge I believe and I have never heard of it. I don't use reactor myself though.
                                This is my recommended migration method indeed.
                                Not fully understanding this sentence. Unpair what controllers from vera?
                                  Apologies. The devices in question are Remotec ZRC-90 keypads and Zwave.me keyfobs.
                                  I have used these for many years to trigger activities in Reactor (although frankly with Alexa and the new less cloud based, they get very little use)
                                  Each of these has an sl_scene attribute and an sl_scene update attribute. Because sl_scene might not change from one execution to another, you need to use both.
                                  The issue I hit is that every 80 seconds or so the Reactor sensor would trigger. Looking in Openluup's logs:
                                  2020-06-22 14:17:48.358   luup.variable_set:: 10238.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 4 now: 4 #hooks:0
                                  2020-06-22 14:19:29.972   luup.variable_set:: 10238.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 4 now: 4 #hooks:0
                                  2020-06-22 14:21:11.559   luup.variable_set:: 10238.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 4 now: 4 #hooks:0
                                  2020-06-22 14:22:53.595   luup.variable_set:: 10238.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 4 now: 4 #hooks:0
                                  2020-06-22 14:24:35.115   luup.variable_set:: 10238.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 4 now: 4 #hooks:0
                                  2020-06-22 14:26:16.532   luup.variable_set:: 10238.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 4 now: 4 #hooks:0
                                  Which was causing the sensor to trip (actually as it should) even though there was no actual button press.
                                  What I would like to do is un-pair these devices from Vera and pair them to my UZB stick while plugged into the NUC. Get those Reactor sensors migrated over properly, then take the UZB stick back to Vera and move the rest of my devices.
                                  Does that help?
                                  (NB given the progress I've just made it might all be a moot point anyway as my most complex and WAF testing piece of automation seems to have moved over without issue) Not sure how to test it though 😄
                                  Cheers
                                    I see. Yes of course you can do that. The migration from the vera is really meant to prevent any exclusion/inclusion which I know can be tedious depending on your device but if you want to exclude these devices from the vera first. Run the migration and reinclude them on z-way, it is up to you.
                                      @rafale77 thanks!
                                        #39
                                        So long day working round some gotchas.
                                        What have we learned:
                                        Scene controllers behave a little oddly under Verabridge it appears
                                        Restoring Reactor sensors (one at a time)
                                        First back up your Reactor from the Backup and Restore tab. Download it and then scp to you Openluup install directors
                                        Install Reactor on your Openluup host
                                        Create a new sensor
                                        Move it to the right room
                                        Restore the desired sensor onto the sensor you just created.
                                        Go to to tools tab to fix it (assuming you have the correct version)
                                        For testing I disable the Vera instance and enable the Openluup instance.
                                        Once you're happy, you can delete the Vera instance.
                                        Vera TTS was simplest of those so far. Install from Alt market place.
                                        Copy your hosts, username and password into the Attributes. Then scp your .alexa.cookie from /storage/alexa on the Vera into /VeraAlexa on your Openluup device
                                        I actually found it easier to copy the contents and create a new file than working out how to SCP hidden files, but Filezilla will do it simply
                                        iPhone locator.
                                        These don't come across well it seems. It's probably easier to create them from scratch.
                                          Create a new sensor
                                          iPhone locator.
                                          @CatmanV2 remember to install Jq and enable the flag. You'll get sync'ed announcements and much more!
                                            1.1k
                                            158.9k
