  3. Vera
  4. Vera account suspended for a 1000 years
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
101 Posts 22 Posters 65.5k Views 20 Watching
    sender
    #41
    Welcome! I have just read that topic 🤣.
    Wow that guy Melih runs a company, well a "thing" trying to push to existing customers of Vera but he is not succeeding in any way 🤣.
    Sorry but if it werent to serious and pathetic it would be very funny 🤪.
    I keep stressing my argument.
    Melih, monkey, I am so glad you took over the company! If you had not I would not know what would be out there more and I would still be sticked to a retired product. Thanks Melih!
      Every time he posts I just laugh. So childish, I would be surprised if Ezlo even last a year.
        He's got enough money to keep it going as long as he wants until he gets tired of it. It's a toy for him, I think.
        PablaP 1 Reply Last reply
          @toggledbits it’s definitely a toy for him. But why get so defensive then! I would definitely move on if the product is failing. But then again I’m not a billionaire
            I am just in shock, how low can one go to try to prove themselves right. @toggledbits i commend your ability to remain professional and true to the facts. What Melih is saying is just infuriating me, I can’t imagine how it makes you feel.
              Well, I’m glad I got banned from there earlier, because if I was allowed to post there now, I certainly could find some choice words which would really lead me into trouble. Better out than in.
                @akbooer if I had the ability to answer the thread I would definitely exercise my Freedom of speech
                  #48
                  Guys, the best possible answer is to make our home automation setup work the way we want it in reliable and efficient manner, with or without our EOL veras but with each other's help. That's what we are seeking after all. While keeping our minds open, exploring all the novelties and discussing what we can do to continuously innovate improve and optimize. The vera had an awesome forum with tremendous community of developers. I sensed the end of an era and as much of our time and energy we have spent there, it was not all wasted. The best answer is to move on, not only for the sake of answering but also to refocus on what we aim to do: A community to grow, develop, debate, explore smart home technologies.
                    He's publishing the truth himself, I don't need to say anything. Honestly, I don't know how he doesn't see that he looks like a fool. I don't want to be ugly with him, but I won't not defend myself.
                      I petition to move all dev’s Vera plugin forums to here
                        sender
                        Omg this is really unbelievable!
                        https://community.getvera.com/t/clarification-of-forum-contributors-being-banned
                        I read rigpapa is also active with homeassistant.
                        Is rigpapa also active on this forum? What name? Anyone knows his name on homeassistant?
                        I justed wanted to say, go rigpapa!
                        • S sender
                          @sender he’s known as @toggledbits here!
                            Shoot... the secret's out now... they'll find me for sure, now... 😉
                            • Black CatB Offline
                              Black CatB Offline
                              Black Cat
                              THis is better than Days of our Lives.......
                              aka Zedrally
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                I'm out of popcorn.. Switching to chocolate 😉
                                  The movies over for me.. got banned. Well I at least asked for it
                                    #57
                                    @pabla
                                    The acting is over... now you can just be a spectator. I thought the thread was closed. Apparently not...
                                    Have to appreciate all the posters for the courage to speak up and try to bring back reason in there. Sure managed to get the guy to come completely unglued.
                                      sender
                                      @toggledbits you are awesome! Never used reactor but I have seen your involvement and communication and I just wanted to have it said to you.
                                        Matteburk
                                        wrote on last edited by Matteburk
                                        #59
                                        And the winner in the right corner of last nights MMA Forum Fight is .......Riiiiiiiiiiiiigpapaaaaa.......🤪
                                        So Sad that the other guy cant accept his limits. You cant act as a CEO on a companyforum like you were just an annoying user. If he had stayed off the forum and let Nice guys like Sorin and the others do the talkng i guess the hole forumclimate would be better and ezlo more successful.
                                        Good that you stand up and Don’t let bad People push you down @toggledbits
                                          #60
                                          Jeeez, he's still ranting. Have any of you ever heard of "confession by projection"?
                                          Edit: It's time to bring the temperature down over there. We all know who we're dealing with. We've made our point. Thank you all who have chimed in on my behalf as well, and offered words of support here. I'm not leaving until he kicks me off. But it's time to let this one die out, cool the temp and let the forum get back to the business of the community. His anger on display won't change anything anyway; the market will sort him out, not me or anyone else here. For myself, I'm getting on with the business of building tools, and if a single-digit percentage of people use my work, I call that a pretty good day.
                                            154.7k
