  3. Vera
  4. Vera account suspended for a 1000 years
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
101 Posts 22 Posters 65.5k Views 20 Watching
    Are you kidding me? For what? Saying the thread isn't constructive? Well, shucks, there's just no room for you around here, Captain Obvious.
    DesTD 1 Reply Last reply
      DesTD Offline
      DesTD Offline
      DesT
      • DesTD Offline
        DesTD Offline
        DesT
        @toggledbits don't worry, I will be able to sleep tonight 😉
          I think Melih is having troubles sleeping, hence his easily bothered behaviour. He needs a drink.. or two.. or maybe 5?
          • DesTD Offline
            DesTD Offline
            DesT
            can share a bottle of whisky with him 😉
              Pretty sure at this point that he and I aren't going to be drinking buddies, so I'll leave that to you guys. 😉
                The maturity, repeated disrespect and name calling indicates he already had too many in my opinion.😉
                  Maipensato
                  Well....since this morning I cannot login to the vera forum anymore.. Account suspended for 1000 years. No warnings at all. What a joke....The almighty dictator that cannot endure any criticism and breaks every forum rule himself again proves what kind of person he is. Really unbelievable his recent behaviour towards rigpapa and akbooer !! Well I don't bother at all. Seeing the lack of progress in Ezlo controllers these will not be part of my (future) home automation system.
                  @toggledbits: I liked your reactions towards the dictator (probably the reason he suspended me) and I really fully behind you !!
                  @akbooer: ridiculous that the dictator calls you a thief (you stole away "his"customers). He'\s very good in chasing them all away himself.
                  I use Vera controllers for almost 8 years now. Honestly I'm quite happy with how they function right now. Thanks to the great research and tips of @rafale77 and switching all my scenes to the magnificent Reactor plugin it is now working (although with on average 1 luup reload per day). My setup is quite complex and next to a lot of zwave devices I also use the plugins for e.g. Hue, Sonos, Netatmo, Milight, RFXcom, smartmeter, Datamine2. For short term I will consider decoupling my Veras from the Vera servers and/or start using Openluup. First dig in to this a little more, I already noticed this forum is very informative about all the options.
                  I think much more members are banned now from the vera forum. Because if they ban me for liking the posts of rigpapa.... well I was not the only one.
                  @toggledbits: are you still allowed by the almighty dictator?
                  • M Maipensato
                    @maipensato
                    Welcome to the group! Seems like most of the plugins you use are authored by folks here, so support should be fine. As you mention, good alternative paths forward are also available.
                    AK
                      #90
                      @maipensato
                      Hmm interesting, this is becoming a welcome to new members thread... So welcome!
                      There is so much more I have to say about the spectacle on the other side but I will refrain to not bore anyone since most of it will be just stating the obvious.
                        shit, i thought this ended when melih got sober/hung over.. mabye I should recommend MSR as an alternative for mr. rutledgehouse in the thread? 🙂
                        • E Offline
                          E Offline
                          eonnet
                          wrote on last edited by eonnet
                          #92
                          The crazy guy banned me also
                            WTF me too!
                              wrote on last edited by PerH
                              #94
                              I'm still not excluded, but I think it's a matter of time until he sees the same profile picture.
                              I was hoping to be able to test the eZLO plus some more, but given the temperature, i'd rather stay with the "Rafael group". 😁
                              Utterly flabberghasting!
                              Edit: And there, i'm out too. Should we count how many eZLO plus beta testers he threw out? I have one.
                              CrilleC 1 Reply Last reply
                                Wait... is he... talking about these forums in his own thread? Another rule violation? And with a picture?
                                  #96
                                  Jun 17, 2020
                                  An embarrassing ad from the "competition"
                                  Had to share this ad that showed up in my news feed today for ezlo which apparently used to be Vera. When I saw the preview, I was seriously confused. They’re proud of the fact that it takes almost two seconds for a light to come on! It’s been a while since I used a z-wave or zigbee bulb, so maybe...
                                  interesting... I just discovered this.
                                  Not quite sure what part of this is more impressive:
                                  The sheer dishonesty of test environment comparing the systems which I didn't know about until I read that thread or how shamelessly ridiculous and ignorant the ad is since speed was unique problem of the z-wave network management of the vera... yep no other platforms have this kind of problems so speed is definitely not a relevant factor anymore.
                                  • E Offline
                                    E Offline
                                    eonnet
                                    By some chance of accident i’m not just Vera user but my company is also a Vera Dealer 🙂 just started off before the pandemic and didnt knew about ezlo controllers and the “monkey” if somebody needs Edge, Plus or Secure brand new let me know i will sell them at cost price plus shipping 🙂
                                    P.S. Its EU frequency
                                    • PerHP PerH
                                      @perh Yes, I have an Ezlo Plus too and I actually like it so far. Still a lot to develop before it’s ready for sale and accomplish a bit more advanced automations, and I’d like to see and participate in the progress, but not very motivating when my forum account got suspended.
                                      For what reason? “Forum rules”.
                                      No further explanation or warning!
                                        I was just thinking, these forums remind me of my earliest days working in startups, when you showed up for an interview and the furniture was clearly from a local thrift shop, the coffee station was a folding table or plywood over two saw horses, and your interview was conducted with all parties in jeans and a t-shirt. In those days, the focus was strictly on the work and bringing something exciting into the market. People of every history and skill were brought together. The CEO worked right next to you and could be seen cleaning the office's only toilet on a Friday night before he went home. And he was there on Saturday, and on Sunday, because we only worked on days ending in "y".
                                        These forums are a refuge. It's a place where technical discussion can lead over corporate policy and the pressure to sanitize and control the view. It's a place where we can take a wide view of the HA market, and not be beholden to one product. We can share success and failure with, and our adulation or bewilderment for, any product in the space. We talk about bugs and needs and challenges. We get work done. We get work done for each other.
                                        This is shaping up to be a really fun community, and I'm excited to be involved. The direction is forward. Onward!
                                          @toggledbits said in Vera account suspended for a 1000 years:
                                          Bravo! Well said.
                                            154.7k
