  3. Vera
  4. Vera or not vera?
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
Vera or not vera?
104 Posts 10 Posters 62.3k Views 10 Watching
  • K krisztianszabo
    Thank you for your response @akbooer.
    "Nothing needs changing here – all the defaults are just fine. What problem are you trying to solve?"
    I'm following the openluup briefing.
    I found there: "Appendix: Configuring key openLuup parameters at Startup"
    From this I thought something had to be changed in user_data.json.
    Don't I have to be change someting there?
    Or don't have to?
    I'm starting to lose a little bit of the yarn between a lot of information ... sorry.
    @krisztianszabo said in Vera or not vera?:
    This is entirely optional, and just describes a way to change things if you want to... but you don't, so nothing to do here!
    I'm sorry the manual is perhaps not as clear as it could be. It has rather grown over time as features got added, so the organisation of it is not ideal. I did try to put everything necessary in the early chapters and additional documentation in the Appendices.
    VeraBridge, installed, bridge, running, connection good, devices taken over.
    That's great.
    I'm trying to run with Vera for now and I don't have an Altui license. Then it's so good. Right?
    OK, that explains it. If you want to get rid of the message, then you need to contact @amg0 about a licence. You should ask for it in the login name that it is trying to use, in this case, your wife's. Then openLuup will pick up this information too, and if you keep Vera attached all will be well. If, someday, you remove Vera, having transferred all your ZWave devices to ZWay, say, then you will need a licence key from me to enable you to keep your AltUI licence running, but openLuup, itself, requires no licence.
    • K Offline
      K Offline
      krisztianszabo
      @akbooer!
      Don't worry, the manual is definitely good, I think I'm an amateur to it ..... 🙂 🙂 🙂
      AltUi license is clear, thank you.
      I move on, successfully “resetting” and repairing all my reactor sensors in Altui.
      Got the automation it's super! 🙂
      Then I installed the Netatmo plugin on Altui, provided all the data.
      One main station and children are placed / updated in the openLuup / Altui interface, but the other main station is not present.
      I don't see an error in the log file, there are all of them.
      What could be the problem?
      I also installed a Harmony hub, but there is a problem here as well. Harmony appears on the interface, but there is no icon and no child devices.
      How can I fix this?
      Thank you for your patience.
      Best regards:
      "amateur" 😄
      Krisz
      • K Offline
        K Offline
        krisztianszabo
        .... yeah and one (two) more ..... 🙂
        How can I create multiple Auto Virtual Thermostats?
        If I install the plugin twice, the second one will not appear is AltUi.
        I didn't find a DSC plugin in the App Store. Then it stays based on vera?
        Krisz
          You push the "Create device" button in the "devices" tab, insert name and D_AutoVirtualThermostat1.xml/I_AutoVirtualThermostat1.xml in the fields, and up it pops. 🙂
          You might be able to make DSC work by copying the files to the AltUI unit and using the same Create device procedure as above.. It worked with VeraFlux which wasn't in AltAppStore either.
          K 1 Reply Last reply
            It's been a conscious decision not to place plugins in the Alt App Store unless we have permission of the developer. If they're not there, it doesn't mean that permission was denied, they may simply not yet have been asked (or they're not around any more.)
            The store, itself, only contains metadata. The actual code is in the developers' own GitHub repositories.
              Would like to see these plugins in the store:
              Sonos - originated by lomdomo and updated by toggledbits - not sure what the hold up is here - it's in GitHub.
              Datamine2 - an old favorite of many (excuse me akbooer) - originated by Chris Jackson and updated by sknightley aka ConstantSphere - Chris is OK, need to check with ConstantSphere
              GC1000 IR plugin driver - maybe a Vera plugin (Sorin??? - license unclear) but there are more recent improvements to make use of - I can put it into GitHub with permission.
              Any others out there of good use? More than likely.
              akbooerA K 2 Replies Last reply
              • A a-lurker
                @a-lurker said in Vera or not vera?:
                It was a real favourite of mine too. DataYours (and, in fact, openLuup’s Data Historian) can read directly from it... but the disc space requirements were large, and searches extremely difficult due to the folder structure. IIRC, it’s possible to plot Datamine with Grafana, although it’s a while since I tried that.
                  @akbooer said in Vera or not vera?:
                  Arhhh - I remember 64 kB of static RAM literally hanging over the edge of a S100 board and it cost ALOT; used with the CPM OS plus all sorts of other boards to make it all work. Years later, I can still learn much much more. Datamine's memory needs are - well not much at all, looking at to-days gear. However a Vera 3 was a little constrained - if perhaps a little unnecessarily so.
                  • PerHP PerH
                    K Offline
                    K Offline
                    krisztianszabo
                    @PerH said in Vera or not vera?:
                    The desired sensors have appeared! 🙂
                    Krisz
                    • K Offline
                      K Offline
                      krisztianszabo
                      @akbooer,
                      Do you have any idea about the netatmo and harmony hub bug I asked above?
                      Krisz
                      • A a-lurker
                        K Offline
                        K Offline
                        krisztianszabo
                        Unfortunately, I didn't understand much of that. Remember I'm a beginner ..... 🙂
                        What should I do?
                        Krisz
                        • K krisztianszabo
                          @akbooer!
                          How can I fix this?
                          Best regards:
                          "amateur" 😄
                          I thought we had this sorted. Are you saying that it’s different from running on Vera?
                          What does the diagnostics page show?
                            K Offline
                            K Offline
                            krisztianszabo
                            I mailed the diagnostics to you.
                            Device Tree device list is empty.
                            Haromony also has no icons or children's tools ...
                            Krisz
                              It is possible that you are not running the latest version? You need the development branch, not the master.
                                K Offline
                                K Offline
                                krisztianszabo
                                Maybe not the latest. Version 20.10.15. I updated in AltUi, but the version number remains ...
                                Krisz
                                  No, that's the wrong one. Looking at the update log in the file I see:
                                  -- 2020.10.15   fix possibly missing "station_name" / "home_name" (thanks @Krisztian_Szabo)
                                  -- 2020.10.21   another fix for the above (with multiple stations) (thanks again @Krisztian_Szabo)
                                  so you need at least 2020.10.21. Update from the development branch.
                                    K Offline
                                    K Offline
                                    krisztianszabo
                                    Would you forward me the github link, where I can download the 10.21 updated files?
                                    Krisz
                                      Just type development into the Netatmo line update box on the Plugins page and click the update button.
                                        K Offline
                                        K Offline
                                        krisztianszabo
                                        Grateful thanks!
                                        Netatmo is fine too!
                                        Have no idea about a Harmony control error?
                                        Krisz
                                        • K Offline
                                          K Offline
                                          krisztianszabo
                                          Has anyone already managed to install the DSC plugin under AltUi?
                                          I have already created the two devices manually in (DSC alarm panel and Partition 1)
                                          In AltUi, but unfortunately I don’t see the possibility to specify many variables. (eg zones, motion detectors, etc.)
                                          Do you have any ideas?
                                          Krisz
                                            146.7k
