  3. Vera
  4. Vera or not vera?
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
Vera or not vera?
104 Posts 10 Posters 63.8k Views 10 Watching
  • DesTD DesT
    @akbooer What's in my plugin code I need to check that can trigger openLuup to reload ?
    @dest said in Vera or not vera?:
    • Creating new child devices?
    • When does it happen?
    • Do you have Startup and main logs?
    • K Offline
      K Offline
      krisztianszabo
      @akbooer
      I find that sunrise and sunset happen late on openLuup compared to vera. OpenLuup is delayed for more than 1 hour.
      Could this be a localization problem?
      Krisz
        #83
        @krisztianszabo said in Vera or not vera?:
        You perhaps have not set your location correctly in openLuup. The latitude and longitude are initially set in the Lua Startup code, which has as default:
        -- You can personalise the installation by changing these attributes,
        -- which are persistent and may be removed from the Startup after a reload.
        local attr = luup.attr_set
        -- Geographical location
        attr ("City_description", "Greenwich")
        attr ("Country_description", "UNITED KINGDOM")
        attr ("Region_description", "England")
        attr ("latitude", "51.48")
        attr ("longitude", "0.0")
        K 1 Reply Last reply
          K Offline
          K Offline
          krisztianszabo
          @akbooer said in Vera or not vera?:
          Thank you, I corrected the values. We will see the result when it gets dark ... 🙂
          Krisz
          • K Offline
            K Offline
            krisztianszabo
            @akbooer
            For some reason, after the AltUi "reload engine" I get a "controller did not respond" response with an orange background.
            So far, I thought dsc and harmony are not due to connection.
            I just deleted my two unconnected devices.
            And still this message.
            I looked at the logs for the duration of the error message and did not see anything to throw out.
            How can I find out the cause of the error?
            K
            Krisz
            • K krisztianszabo
              @akbooer
              K
              This is absolutely normal and is simply AltUI noting that connection has been lost during the restart. The only time you need to worry is if there is a timer counting away the seconds for a long time.
              • DesTD DesT
                K Offline
                K Offline
                krisztianszabo
                Hi @DesT !
                I don't want to urge you, I'm just interested,
                do you have any good news about dsc?
                K
                Krisz
                • K krisztianszabo
                  Hi @DesT !
                  K
                  K Offline
                  K Offline
                  krisztianszabo
                  Hi @akbooer ,
                  Another task ahead of me:
                  I have a 15 channel shutter control module that I want to run under OpenLuup. (if you help I can transfer the plugin files)
                  The shutter control interface is connected to the vera via usb.
                  The following setting is in Vera:
                  Where can I make such settings in openLuup?
                  Krisz
                    Probably much the same way as the RFX?
                    https://smarthome.community/topic/253/setting-up-rfxcom-plugin-in-standalone-openluup?_=1606133137706
                    baud, parity, etc is set up in the ser2net file.. then connect using IP:Port (127.0.0.1 if its on the local computer)
                    • PerHP PerH
                      K Offline
                      K Offline
                      krisztianszabo
                      @perh
                      Thanks for the reply and tip.
                      I installed ser2net, I think it worked fine, but I don't have a / serial directory under the / dev directory .....
                      What do you think I should do then?
                      Krisz
                        wrote on last edited by PerH
                        #91
                        You're running Debian 10.6 right? if so its hidden, but just type cd /dev/serial/by-id/
                          if not, you can use /dev/ttyUSBxx(whatever usb you device is connected to)
                          K 2 Replies Last reply
                          • PerHP PerH
                            K Offline
                            K Offline
                            krisztianszabo
                            @perh
                            How can I check if I am using debian 10.6?
                            I tried to type, but unfortunately there is no such directory ...
                            Krisz
                            • PerHP PerH
                              K Offline
                              K Offline
                              krisztianszabo
                              @perh said in Vera or not vera?:
                              There is no ttyUSB file in the / dev directory.
                              There are several tty files numbered here, but without USB ...
                              Krisz
                                mabye its a "ttyACMx"?
                                You've reached the limit of my linux knowledge. Good luck. 🙂
                                • K Offline
                                  K Offline
                                  krisztianszabo
                                  I think I also reached the limit .... 🙂 🙂
                                  Krisz
                                  • PerHP PerH
                                    K Offline
                                    K Offline
                                    krisztianszabo
                                    After many attempts, he finally succeeded.
                                    Ser2net installed, restarted, ser2net.conf configured.
                                    MySensors plugin is not red, startup lua does not write an error.
                                    However:
                                    The children's tools were not made, but the shutters did not appear.
                                    Do they need to be created manually?
                                    Krisz
                                    • DesTD DesT
                                      @akbooer Last time, the thing I remember, the plugin was unable to "connect" to the socket on the DSC controller!
                                      I would need to recreate my DSC device on openLuup and disable Vera for being able to test!
                                      DSC.zip
                                      K Offline
                                      K Offline
                                      krisztianszabo
                                      DSC.zip
                                      Hi @DesT!
                                      Maybe you may have fixed the dsc plugin error?
                                      Krisz
                                      DesTD 1 Reply Last reply
                                      • K krisztianszabo
                                        DSC.zip
                                        Hi @DesT!
                                        DesTD Offline
                                        DesTD Offline
                                        DesT
                                        @krisztianszabo Nah sorry! Got too much thing to do @ work!
                                        I will have more free time in a couple of weeks for the holidays!
                                        • DesTD DesT
                                          K Offline
                                          K Offline
                                          krisztianszabo
                                          @dest I think you have more important things than this. 🙂 🙂
                                          Please let me know if you have any progress on the matter.
                                          Thanks in advance.
                                          K
                                          Krisz
                                            154.9k
