  3. Vera
  4. Vera or not vera?
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
Vera or not vera?
104 Posts 10 Posters 63.8k Views 10 Watching
  • K krisztianszabo
    @dest I think you have more important things than this. 🙂 🙂
    Please let me know if you have any progress on the matter.
    Thanks in advance.
    K
    DesTD Offline
    DesTD Offline
    DesT
    @krisztianszabo I'm still working a lot for the next couples of days, after, I will have some spare time and will check that 😉
      I am, of course, biased...
      You can progress in easy steps, and see how things improve. You will need another computer (Raspberry Pi of any sort is not a bad choice.)
      • install openLuup on RPi
      • link openLuup to Vera
      • move any plugins to openLuup (really helps reliability)
      • move scenes to openLuup (ditto)
      These are easy steps for which there is much help available. If this is not reliable enough for you then
      • buy a UZB stick with ZWave licence, and software (runs on RPi)
      • clone your Vera ZWave network to it
      • plug in UZB to RPi
      • throw away Vera
      Then you are in a hugely reliable, yet still familiar, home automation environment.
      P Offline
      P Offline
      powisquare
      @akbooer said in Vera or not vera?:
      • throw away Vera
      Thinking about replacing my 3 veras. Would it be possible to clone them to separate zway devices and continue with openluup/vera bridges?
      • P powisquare
        • throw away Vera
        Yes. Not using vera bridges but z-way bridges. And also unless they are physically non co-located mesh, or the number of devices exceed the capacity of one mesh (>~200 nodes) you probably are better off making them all one single mesh. z-way doesn't have the non-sensical overhead on the zwave network and can handle the full z-wave network mesh capacity. Having multiple z-wave networks at the same location really makes no sense since they will be interfering with one another causing latencies and dropped packets since they all share air time on the same 2 frequency channels.
        • P Offline
          P Offline
          powisquare
          They are too far apart in my case but thanks for the heads up rafale. Advantage - I can test on the small mesh and see how it goes! : )
            155.0k
