  3. Vera
  4. Who owns Luup?
Oh the joy of pairing
Vera
Vera
Free to a new home
Vera
MiOS is Winning the X10 Wars
Vera
Let's assume you have done the following: Downloaded and installed Z-Way following these instructions. No Zway license is required to do the following. The software is now all up and running with your UZB stick (whole other post). Dial up this Zway web page: http://<Zway_server_IP_address>:8083/expert/#/network/controller Under the heading "Firmware" take note of the "SDK version" and the "Serial API Version". Say they equal 6.71.01 & 05.23 respectively like it shows here. Now on to Vera: Go to the Vera UI --> Z-Wave Settings and taken note of the "Version" shown for Vera's internal Zwave IC. For example purposes, say it equals "6.01". You plug your UZB stick into Vera. In the Z-Wave Settings you set the port to "/dev/ttyACM0" You've rebooted Vera, so that it starts using the UZB stick. OK, so what "Version" will Vera now display and the version of what? The version shown by Vera is the "Z-Wave protocol" version or the "Serial API" version - it's unclear which but I suspect the former. However on most occasions the numbers are the same. It's not the Software Developers Kit (SDK) version number. Knowing the UZB firmware version you can identify what Vera will show with the following table. From the example above: Zway stated the version as 5.23. It will show in Vera as version 4.61 - see table. However the Vera internals showed up as 6.01. So using this method to copy the Zwave configuration to the stick will not work, as the stick represents a downgrade and you can only do same to same or upgrades. So in this case you need to update the stick firmware from 5.23 to 5.32 as a minimum. Then the stick will show up in Vera with version of 6.01. Which is great. So you then use the Zway software to upgrade the stick firmware. And that's the last you hear from it because this happens: "Sorry to inform you, but there is a known issue in some UZB manufactured by our partners on license base that after upgrade they become bricked." And you have to do this to unbrick it. So time to try someone else's stick. Sigh. ZWay UZB version Vera version SDK version 5.39 6.09 6.82.01 6.08 6.82.00 6.07 6.81.06 6.06 6.81.05 6.05 6.81.04 6.04 6.81.03 6.03 6.81.02 5.37 6.02 6.81.01 5.36 6.02??? 6.81.00 ???? 5.33 6.02??? 6.81.00 ???? 5.32 6.01 6.81.00 5.03 6.71.03 5.02 6.71.02 5.27 BL 48059 4.61 6.71.0? 5.26 4.61 6.71.0? 5.23 4.61 6.71.01 4.6 6.71.00 5.2 4.6? 6.7?.00 5.16 4.6? 6.70.00 4.62 6.61.01 4.33 6.61.00 4.54 6.51.10 5.07 4.38 6.51.09 4.34 6.51.08 4.24 6.51.07 4.05 6.51.06 5.06 4.01 6.51.04 3.99 6.51.03 3.95 6.51.02 3.92 6.51.01 3.83 6.51.00 3.79 6.50.01 3.71 6.50.00 3.67 3.35 6.10.00 3.41 6.02.00 3.37 6.01.03 2.78 The table is based on page 434 of silabs app INS13954 and the UZB firmware revision information found here. The table may have errors!
Vera
Vera
floor heating automation
Vera
Nuke Vera Script
Vera
Vera
Vera
Vera
Vera
Power monitoring options
Vera
Vera
Vera to zwavejs
Vera
Vera firmware 7.32 beta
Vera
Vera
Vera
Vera
Vera
Who owns Luup?
languagelua
10 Posts 4 Posters 2.9k Views 4 Watching
    I first learned of Lua and Luup (Lua+UPnP extensions) in 2009, but was never quite clear on who created reach language or who "owns" them now.
    Are these proprietary? Open source? IEEE spec? Fully documented? Extensible?
    Heck, I didn't even realize there was an SDK out there until this year! Suddenly desirous of learning more...
    Libra
    • HSD99H Offline
      HSD99H Offline
      HSD99
      Lua: https://en.wikipedia.org/wiki/Lua_(programming_language)
      Interesting backstory.
      • HSD99H Offline
        HSD99H Offline
        HSD99
        Forgot this: https://www.lua.org/
          Never thought about it as I never notice any trademark or registration. Thanks @HSD99 for providing an answer.
          HSD99H 1 Reply Last reply
            HSD99H Offline
            HSD99H Offline
            HSD99
            @rafale77 From Lua.org:
            Lua is free
            Lua is free open-source software, distributed under a very liberal license (the well-known MIT license). It may be used for any purpose, including commercial purposes, at absolutely no cost. Just download it and use it.
              I am (edit: was) still left wondering who originated the Luup extension of Lua, which got me to Googling, when this minor gem turned up: http://www.pearltrees.com/t/micasaverde-developer-program/id4660384
              ANSWER HERE: http://wiki.micasaverde.com/index.php/Luup_Press_Release#What_is_Luup.3F
              Besides @toggledbits , have any of you undertaken to create your own Lua-derived language? I know so little about programming languages generally, but enough to ask: Has LUUP been taken as far as it needs to go?
                LUUP is not a language to my understanding. It is a Lua extension making use of the UPnP library into an API. The language remains Lua.
                • HSD99H Offline
                  HSD99H Offline
                  HSD99
                  LUUP on Vera is a Linux executable written in C/C++ that provides the operational functions of Vera, a Lua environment for running Lua scripts, HTTP, serial device support and the UPnP control model. The problem as I see it is that many of these functions should not be part of single executable, but in fact should be provided by the OS since that's why it's there. The basic architecture of LUUP is therefore fragile, and can become unstable under a variety of internal and external conditions. For example, HTTP request to external sites (e.g. a cloud-based whatever) can crash LUUP if the external site takes too long or responds in a way that LUUP can't process. LUUP either crashes on its own, or makes the decision to "self-crash" and reload to attempt to get itself back to a sane operating state. These are my assumptions based on what I've been able to observe. Anything that causes a delay will almost certainly crash LUUP. I know we have folks here who have delved much more deeply into LUUP, or at least as deep as you can by observing its external behavior and who will have far more insight than I.
                  I have done embedded Linux systems since the early 2000's. We used as many OS functions as possible, since that's why you have an OS. We wrote our own Linux device drivers for our special I/O devices, and confined the executable to the actual control and computations required by our application. We also used shell scripts, as does Vera, for various OS functions. Our systems did not use Lua, and did not have any mechanism for user-written code. This made it much easier to have stable systems. It comes down to architectural decisions and IMHO Vera chose poorly.
                    Let’s be clear...
                    "Lua" (pronounced LOO-ah) means "Moon" in Portuguese. As such, it is neither an acronym nor an abbreviation, but a noun. More specifically, "Lua" is a name, the name of the Earth's moon and the name of the language. Like most names, it should be written in lower case with an initial capital, that is, "Lua". Please do not write it as "LUA", which is both ugly and confusing, because then it becomes an acronym with different meanings for different people. So, please, write "Lua" right!
                    ...from http://Lua.org/about.html
                      Edited my post accordingly. Thank AK!
                        164.6k
