  2. Hardware
  3. Z-Wave.me
  4. Adding Z-way as secondary controller to vera zwave network
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
38 Posts 7 Posters 16.1k Views 7 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    libcrypto it's for the libcrypto.so.1.0.0 cannot open shared object error you got!
      sender
      Ok ,on-topic again. If z-way is secondary controller with
      <TryToBecomeSIS>0</TryToBecomeSIS>
      <Autoconfig>0</Autoconfig>
      Can I use z-way to do device config there? And will Vera also "see" the values then?
      So I can use z-way to get rid of the horribe "waiting for wakeup to configure device messages? (hope z-way will do fine however :-))
        You can configure the device a lot more clearly and in more details on z-way than on the vera for sure.
        The "waiting for wakeup" thing for the vera is internal to the vera and has little to do with the actual configuration of the device.
        The vera wants to push its auto-preset device configs to the device or it is just a flag mistakenly tagged to that device requiring to wakeup for it to reconfigure the device when it was the vera's own data which was messed up. Really a nice piece of garbage if you ask me. But no it won't remove these tags because the vera won't know that another controller already did the job. To eliminate that from the vera you need to remove the auto configuration.
        S 1 Reply Last reply
          sender
          #31
          @rafale77 So to be clear. If I change a parameter in z-way, z-way will know, the device will take it but Vera will not know/display it?
          Edit: I think I bricked something with a "firmware" update... so I should speak in past time... 🙂
            Correct. You have to make the vera stop caring (by disabling auto-configure) or allow the vera to push its configuration to the device again.
              I have auto configure to off and while I wait the summer for more time and promote my zway to primary, I'm using it as secondary to configure devices. I can fiddle with parameters and prevent reboots.
                sender
                Ok, thanks guys, but please confirm or deny: I I change a parameter on a zwave device in z-way. Will vera see that?/ Display that?
                  Yes. As I already said.
                    sender
                    Sorry @therealdb, I haven't seen that you specifically said thát...?
                      Only for non-configuration parameter... Things like wakeup intervals, configuration parameters etc... the vera will not know unless you make the vera poll them and the vera does not make it easy to just do a poll of parameter since mostly the "set parameters" command is implemented as part of its configuration process.
                      Status (variables) which update regularly to their lifeline controllers will get updated on the vera if vera is in the lifeline association.
                      • S sender
                        @sender
                        So, as rafale said, it's OK for configuration parameters, not for wakeup and such.
                          160.4k
