  2. Hardware
  3. Z-Wave.me
  4. External antenna on razberry board
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
14 Posts 5 Posters 3.4k Views 5 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    I will do it for sure! 😉
    • DesTD Offline
      DesTD Offline
      DesT
      Just need to find an antenna on Internet for the US band
        How much range do you need? My NotVera is in the server cupboard on the 3rd floor. The most distant devices are in the garage about 30 ft horizontally and those three floors vertically. No communications issues that I can see at all.
        Just curious is all
        • DesTD Offline
          DesTD Offline
          DesT
          @CatmanV2 got some stuff "outside". The NotVera is in the middle of the main floor and trying to reach correctly stuff outside in the "shed", so that's 75 feet and I'm having a couple of stuff inside that are having a hard time too like in the basement.
          I think that I have a little bit too much of interference around here!
            That’s why I ended up with multiple Veras, although I’m now back down to just the one (other technologies now in play.)
            • DesTD DesT
              @DesT Easy 75ft from my NotVera to the gear in the garage. It's going through a brick wall at an acute angle as well....
              Still, I had to install Ubiquit wifi a couple of weeks back. Got so hacked off with getting 1M sitting on top of the AP in the lounge hanging off a 200M cable connection.
              Have to say the Ubiquiti stuff is barking. Setup can be intimidating if you're not a tech but I figure it took me about 3 minutes. 150M now. The AP is on the ground floor, in the 3rd floor office I get a rock solid 40M.
              The only reason I'd get another is that my POS Canon printer moans that there's too much interference. Even though it'll ping away quite happily :<
              DesTD 1 Reply Last reply
                DesTD Offline
                DesTD Offline
                DesT
                @CatmanV2 I'm a Ubiquity fan since a while, we installed that everywhere!
                At home, I have 4 AP-HD, one per floor and one outside in the shed to cover the backyard! 😉
                  Funny, I de-unified just in the past three months and couldn't be happier. ubiquiti, I sensed is going the "vera style" adding more and more useless junk in the controller, creating overhead and unnecessary interdependencies and degraded performance I got fed up with.
                  As you know, I am very hardware and semiconductor oriented and found out that many of the unifi devices are obsolete cheap hardware with a pretty UI and very well designed controller. Performance is often very poor but lately (past 2 years) it's been degrading with an overfocus on bling bling marketing and dubious advertising instead of products and performance. I saw a lot of nonsensical products being released (why a 4x4 wifi6 AP with a gigabit uplink for example?)
                  I upgraded my home network to 10G/5G infrastructure, and cut the cost of the whole installation by 50% by reselling all my ubiquiti stuff while doubling my wifi performance and coverage and no longer having to constantly tinker with my network... So not a fan of unifi any more.
                  As for noise for zwave, you can probably monitor it... a lot of devices unfortunately emit RF noise.
                    @rafale77 said in External antenna on razberry board:
                    Any clues as to how, exactly?
                      I can share my spreadsheet and your mileage may vary on the savings depending on your installation. I have a pretty large installation so...
                      For APs, I moved to wifi6 using the Engenius EWS377AP which has a 2.5G uplink. Got 3 for $200 each and I discovered they doubled speed and coverage allowing to use one less than unifi UAP-AC-HD/SHD/XG of which I had for and priced ranged from $300-$750.
                      I replaced:
                      US XG6-POE ($599) with a Zyxel XS1930-12HP ($999) but double the number of ports, POE capacity and half the problems.
                      USW-24Pro-POE ($699) with Netgear MS510TXPP ($260)
                      US8-60W ($120) with Zyxel GS1200-8HP ($54) (for areas not needing multigig)
                      US8-150W ($200) with Netgear MS5120TXPP($260)
                      I reused all of my wiring which is ~20y old CAT5 but of good quality. Probably better than most cheap CAT8 being sold out there (pure copper, low gauge, STP)
                      Covd19 work from home situation has accelerated this upgrade along with gigabit internet...
                        139.1k
