  2. Hardware
  3. Z-Wave.me
  4. Adding Z-way as secondary controller to vera zwave network
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
38 Posts 7 Posters 16.1k Views 7 Watching
  • K Offline
    K Offline
    kfxo
    @rafale77 @iblis @DesT I appreciate all the input. I have successfully removed all association to the secondary controller (z-way) and also set all battery devices back to vera (node 1) for receiving wakeup notifications. I believe that Node1 is SUC/SIS but I just want to make sure. Vera's settings show "Node 1 Suc 1" and "Role: Suc SIS: YES PRI: YES". Z-way setting show "SUC/SIS in network: 1 (SIS)". Does that look correct? I think I am ready to exclude z-way as secondary controller to prepare for cloning.
      Yes looks good! You can now exclude z-way and do the cloning.
        I can confirm ZWay is cool. I did a couple of maintenance actions on my devices and I can't think about all the time I lost trying to do the same thing with Vera. I'm still using it as a secondary, because I need to plan a smooth transition (Alexa, Nest, and many other things to figure it out), but I'm glad I got mine for only 9 EUR, license included 🙂
        I rafale77R 2 Replies Last reply
          I Offline
          I Offline
          iRobot
          @therealdb That's an amazing price!
          Bought my UZB1 including license for 80 EUR just a couple of weeks ago.
            @therealdb
            When you will move it to a primary, you may well see yet another benefit:
            Extended battery life of all your battery operated devices...
            On the vera, disabling polling and nightly heal helped with the battery life of the FLiRS.
            Disabling nnu helped dramatically with the battery life of the non FLiRS battery operated devices.
            But the vera continues to do wakeup polling which is something I requested to remove as it is useful for only some very rare specific devices and of course I was ignored for almost a year now.
            Z-way doesn’t do any of this craziness and it is very noticeable that all my locks and sensor battery lives have noticeably extended. I use NiMH rechargeable batteries everywhere I can and have recharged batteries only once in 9 weeks with z-way while I used to have to recharge a few sets a week before 7.30 and then about once every week or two after 7.30 and disabling all the vera bloatware they let us. I have 72 battery operated devices and FLiRS...
            So much time and money saved from not having to go swap and recharge batteries...
            This helped with the WAF... 😉 @CatmanV2
              I remember your battle to disable and I'm glad something was introduced.
              I have no FLiRS devices, only less than 10 battery operated one. I hate batteries and I tried to avoid them as much I could. it's just a couple of door/window sensors and two motion sensors where it was impossible (or I missed) to plan a wired one.
                I wish I was that lucky! I practically have no choice for these devices ranging from security door and motion sensors, to locks, HVAC vents etc... Thus the move to rechargeable batteries except for the doorlocks which are high drain and take lithium.
                  sender
                  Took the bit and bought it...
                  Stick plus license... will be here lots of time next week :-)...
                  Z-Wave. Me USB stick incl. Z-Way Controller software : Amazon.nl: Electronics & Photo
                    sender
                    #23
                    What am I doing wrong here?
                    EDIT: Nevermind installed ubuntu 18 and works...
                      sender
                      Sorry, I know I asked beofre but cannnot find it... got z-way running again but how can I auto start it?
                      sudo service z-way-server start doesnt work
                      and start it only one time:
                      LD_LIBRARY_PATH=./libs ./z-way-server
                      • DesTD Offline
                        DesTD Offline
                        DesT
                        You need to install libcrypto package!
                        S 1 Reply Last reply
                        • DesTD DesT
                          sender
                          @DesT libcrypto for that ssl error? I managed to revert to ubunto 18 and have z-way running. Or was your answer to my question on how to auto start z-way? I think not?
                          • S sender
                            @sender
                            It looks like you are going through the “learning” on linux and you are doing it pretty fast. The libcrypto was for the error you were showing on the screenshot. Not a response to your last post.
                            I am running this on ubuntu as well along with openLuup.
                            The issue with z-way-server is that it was set to be installed on a rPi first and therefor assumed the preinstallation of a number of dependencies like libcrypto there are others and we have to install them one by one, looking at the error thrown at us when attempting to start the z-way-server. Different linux distros and versions have different packages pre-installed but they generally have access to mostly the same packages.
                            I autostart my z-way-server with systemd. I will post how to do it here a bit later.
                            • DesTD Offline
                              DesTD Offline
                              DesT
                              libcrypto it's for the libcrypto.so.1.0.0 cannot open shared object error you got!
                                sender
                                Ok ,on-topic again. If z-way is secondary controller with
                                <TryToBecomeSIS>0</TryToBecomeSIS>
                                <Autoconfig>0</Autoconfig>
                                Can I use z-way to do device config there? And will Vera also "see" the values then?
                                So I can use z-way to get rid of the horribe "waiting for wakeup to configure device messages? (hope z-way will do fine however :-))
                                  You can configure the device a lot more clearly and in more details on z-way than on the vera for sure.
                                  The "waiting for wakeup" thing for the vera is internal to the vera and has little to do with the actual configuration of the device.
                                  The vera wants to push its auto-preset device configs to the device or it is just a flag mistakenly tagged to that device requiring to wakeup for it to reconfigure the device when it was the vera's own data which was messed up. Really a nice piece of garbage if you ask me. But no it won't remove these tags because the vera won't know that another controller already did the job. To eliminate that from the vera you need to remove the auto configuration.
                                    sender
                                    #31
                                    @rafale77 So to be clear. If I change a parameter in z-way, z-way will know, the device will take it but Vera will not know/display it?
                                    Edit: I think I bricked something with a "firmware" update... so I should speak in past time... 🙂
                                      Correct. You have to make the vera stop caring (by disabling auto-configure) or allow the vera to push its configuration to the device again.
                                        I have auto configure to off and while I wait the summer for more time and promote my zway to primary, I'm using it as secondary to configure devices. I can fiddle with parameters and prevent reboots.
                                          sender
                                          Ok, thanks guys, but please confirm or deny: I I change a parameter on a zwave device in z-way. Will vera see that?/ Display that?
                                            160.4k
