  2. Hardware
  3. Z-Wave.me
  4. Auto Start z-way-server
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
5 Posts 3 Posters 1.5k Views 3 Watching
    This could probably done in a script but short of it, this is the fairly simple process:
    from the SSH or terminal prompt of ubuntu run this:
    sudo nano /etc/systemd/system/z-way-server.service
    then paste the following:
    # /etc/systemd/system/z-way-server.service
    #       systemctl enable z-way-server
    #       systemctl start z-way-server
    #       journalctl -f
    [Unit]
     Description=z-way server
     Wants=network-online.target
     After=network-online.target
    [Service]
    Type=simple
    # User= Group=owntracks
    WorkingDirectory=/opt/z-way-server
    Environment='LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/z-way-server/libs'
    ExecStart=/opt/z-way-server/z-way-server
    Restart=always
    RestartSec=15
    StandardOutput=syslog
    StandardError=syslog
    SyslogIdentifier=z-way-server
    [Install]
    WantedBy=multi-user.target
    then
    sudo systemctl enable z-way-server
    z-way-server will start automatically at the next reboot.
    I probably should also post how to make it rotate logs... This will be another post.
      sender
      Thank you, that works!
      But make the first line with a "sudo" else it won't work
        You are correct. I missed that and corrected it. Thanks for reporting back!
        • I Offline
          I Offline
          iRobot
          Just wandering if a wait on network should be added.
          With a pi this is done using raspi-config, but any other Linux distribution doesn't have that.
          Maybe add?
          [Unit]
            I did not need in my VM case but it can’t hurt and certainly can help other installations.
            Thanks for the input! It’s updated.
              233
              3.6k
              3.2k
              763
