  3. Z-Wave.me
  4. z-way installation horror
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
9 Posts 5 Posters 2.2k Views 5 Watching
    sender
    Sorry, I have to say... installation of z-way is not simple.
    I started with ubuntu 20. turned out that it is too new due to various reasons. So reverting back to 18... also too new... libcurl4 vs liburl3 etc. not able to install apps etc.
    So reverted back to ubuntu 16.
    installed 16 successfully and then install z-way:
    sudo wget --no-check-certificate -c http://storage.z-wave.me/z-way-server/z-way-server-Ubuntu-v3.0.6.tgz --no-check-certificate -O - | sudo tar -xz -C /opt/
    then followed:
    https://smarthome.community/topic/108/auto-start-z-way-server
    reboot... nothing
    luckily rafael is there to help, but this is NOT EASY AT ALL!
    ...waiting for personal support from rafael...
    • propheadP Offline
      propheadP Offline
      prophead
      wrote on last edited by prophead
      I'm also having the libcurl3/4 issue on a fresh pi install, this is ridiculous.
      to make matters worse someone removed the libcurl3 from the apt-get repository, so now I can't even apply the fix I read about unless I recompile libcurl3 from source...for ARM...to install a home automation system...to make my life easier...
      • I Offline
        I Offline
        iRobot
        Had the same libcurl problems with my Ubuntu server 18.04 VM.
        Ended up downloading the "Fresh Pi" image (https://razberry.z-wave.me/z-way-server/razberry.img.zip) and was up and running within a hour.
        At the moment I suggest to spare yourself all that frustration and do the same.
        propheadP 1 Reply Last reply
        • I iRobot
          propheadP Offline
          propheadP Offline
          prophead
          @iRobot I'll try your suggestion, I'd rather redo a zway installation then go back and redo the full pi install. How do I remove zway before I start?
          Wait a minute, this is a full image, no way am I going through the kabuki dance again to get this thing booted on ssd with new image. Did you perhaps mean I should mount the image and try and grab libcurl3 from it? I'm ready to ditch zway, I need something more reliable. These bozos can't spell right, the main install link on their download page that clearly says supports buster doesn't work. And worse, they KNOW it doesn't work. Oh, sorry did I say bozos, I mean bozo. Weak. Lame. Fail.
            remove the z-way installation:
            sudo rm -R /opt/z-way-server
            As for @sender ... it was an attempt to run a 64bit version of z-way-server on a 32bit OS...
              sender
              Yes, as for the ubuntu 16 I downloaded the 32 bits version due to the 64 was intel and 32 AMD and since I have intel NUC with ESXI... but now I am running on ubuntu 16 64 and still horror... app still not downloading... adn why can't I paste pictures?
              • S sender
                @sender said in z-way installation horror:
                Could be that you need to do this in the full reply window, rather than the quick one.
                S 1 Reply Last reply
                  sender
                    sender
                    @akbooer yes thats it
                      159.9k
