  4. system capability zwave_scene_controller
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
46 Posts 5 Posters 22.1k Views 5 Watching
    Can you send me a log? I'd like to see if there's some obvious delay going on in MSR. And just to make sure, you're not using any condition options on the scene variable test, right?
      I am not using any Constraints if that is what you mean.
      Yes I can do some logs at some point.
      There was one particular Fibaro Roller Shutter 2 module in the Kitchen, that was being very slow with the action running after the clicks.
      I'll test that module again and look at logs.
      As for all the others, 2 seconds seemed to be about the time it takes after clicking, for the action to run. Some of my actions are calling existing Vera scene I had in place, I can probably tidy that up a bit and control devices directly via MSR in the action maybe that may help.
        OK. In case you want to poke at it yourself, and for the benefit of other readers... if you modify the level in logging.yaml for Rule to 6 (that is, find the line in the file that reads Rule: and change the level on the line below that one to 6), you'll get some deeper debug from all rules. Then restart MSR and activate your Fibaro device in whatever way you want to test.
        At that level, you should be able to find a logged entry in reactor.log with the string "launching evaluation for" that references your Fibaro device. This is the detection of the change on the Fibaro. That causes the rule to be evaluated, and you'll see that happening shortly after. Follow that along, and you'll see "Enqueueing" followed by the name of the set or reset reaction that is to run based on the rule's result state. That will be followed by the execution of the reaction, which comes mostly from the Engine, so you'll see it report "Starting reaction" (followed by the reaction name), and then the steps. The reaction is finished executing when it logs "all actions completed". If you note the timestamps on all these, you'll get a feel for how fast its responding in the three major phases: detection -> evaluation -> execution.
        • E Offline
          E Offline
          Edwin1972
          #44
          I want to start moving ReactorOpenLuup to MSR and have the following problem. In Reactor OpenLuup I have set up below. Update does not show in de list in MRS. @cw-kid @ cw-kid What kind of setting do you use to use double click in MRS with roller shutter 2?
          • E Edwin1972
            #45
            @edwin1972
            I am just using the LastSceneID
            Here is an example for S2 Double Click which has a number of "24"
            You also need to reset the LastSceneID back to 0 in the "Set Reaction".
            The different SceneActivation numbers can be seen from the Fibaro Roller Shutter 2 user manual:
            • E Offline
              E Offline
              Edwin1972
              Thanks for the quick response. It works!
                163.1k
