  2. Hardware
  3. Z-Wave.me
  4. z-way-server ubuntu install
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
38 Posts 5 Posters 19.5k Views 6 Watching
    Yes I think so too. Adding the older repo should not be hard.
      @rafale77 said in z-way-server ubuntu install:
      Certainly not normally.
        sender
        So, today my dead-new arrived ZMEEUZB1 usb dongle arrived. plugged it in the VM, USB-passed through it and can see "something" in zway again. But I cannot seem to have it "fully" seen. Do you think I need to do some more?
        E.g. Is do see:
        but I don't see:
        Hm... now I m looking (after pressing Cal for NIF) and it says:
        do you think I am "up and running" again?
          Looks like you are up and running. Just call on NIF on the z-way controller. This status is just a single variable switch which was probably not toggled back. If it persist, I can give you a url to switch it off.
            sender
            Well... I did only press that "Call for NIF" thind and since it is dead. rebooting and pulling usb stick do not help:
            it does something the button:
              The fact that you get to that screen is already an indication that it is not dead. You can safely ignore that message.
              If it was dead, you would not be able to access the job queue and you wouldn't get any background noise level.
              Just start building your network.
                sender
                well... I removed the device from vera (z-way) and everything in the server settings is the same (SIS etc) so I will have to add as secondary controller again...
                One thing I do not get... i why is EVERY screen about configure including firmware upgrade saying:
                  Ignore that too, this device can't be configured through zwave. It is a controller. If the device has not be interviewed to support the configuration command class or wakeup command, it will show this message. Most devices don't support this command class and only battery powered devices which are not FLiRS support wakeup.
                  It seems like you had it perfectly working and you broke it by doing things you should not be doing.
                  It's good for you to play around and to learn how zwave works. You were obviously bothered by things which were perfectly normal and have been breaking your configurations trying to fix things which were not broken.
                  What you saw were not error messages or incomplete connections. They are just normal behavior based on the specific device and controller you have.
                  S 1 Reply Last reply
                    sender
                    Ok definitely something is wrong here. I have added to vera as secondary controller, it is detected by vera. but not just like last time it shows no devices at all in z-way... just 1 in vera with device id 104 and in z-way with 104 as well...
                    and... omg? z-way is now micasaverde and vera is zway:
                    force interview does nothing...
                    it seems to be included somehow:
                      sender
                      @rafale77
                      Qoute
                      Quote
                      What do you exactly mean I had broken? I have just received a new ZMEEUZB1 stick today. I had to remove the device from Vera (previous stick) and to connect this new stick to my z-way server... there is nothing I did try to fix what was broken...?
                        You can also read the z-way manual.
                        Looking at your screen shot, it looks like you went ahead and called a NIF on the controller because the firmware update tab showed that the service is not available.
                        You are on a zwave screen. It means that the firmware update tab is a zwave OTA upgrade function. Since you selected the z-way controller chip, it will obviously not be supported. OTA means over the air. It is obvious to me because I have been digging around zwave for some time but I suppose you were trying to upgrade the controller. This is done in the controller menu the same way you did it before. After you called the NIF, you broke the controller information because a NIF is a zwave message sent by the controller into the network. So you basically ask Paul to go send a radio message to nobody (since you have no other devices) what's Paul's name. It doesn't make sense and that's why you got a failure.
                        Now on adding vera, it doesn't look like you did it correctly either. You seem to have set vera in inclusion mode correctly but for z-way, you need to put it in learning mode under network/control/join network. If you set it to just send a nif to the vera, it will do just that and be added as a device without knowledge of what else is on the vera network. As for the node 1 showing mi-casa verde. It's perfectly normal too because this screen shows the info for the master controller. The vera is the master and will show up in z-way as node 1 but since the name of the node has not been updated (interview is not done), it still is named Z-way. You can do a refresh interview and this should be corrected in the case your z-way was included as a controller and not as any device. It seems you did all these before but have forgotten how. Play around and get more familiar...
                          sender
                          Rafael, you are right... I don't know z-wave well enough. at least the low level details. I am just a user that wants a "stable" network without too much trouble. And yes to achieve that I realize I need to get familiar with the terminology and techniques.
                          For that vera inclusion part. I did exactly what was on page 1 of https://smarthome.community/topic/63/adding-z-way-as-secondary-controller-to-vera-zwave-network/38 just like last time. That's pretty straightforward and I cannot imagine what could be wrong there... You write " You seem to have set vera in inclusion mode correctly but for z-way, you need to put it in learning mode under network/control/join network." and with that you mean below though?
                            Yes, I meant include into network. after you do this, all your devices on the vera will show up in z-way. Vera does not support S2 so you don't need to worry about the first section.
                              sender
                              Ok, I update the firmware of the stick a few times.
                              Now trying to include in Vera... but got stuck after many minutes:
                              I do get the fact that when all is well this product should be awesome. But having spent so many times (and money) and took so many hurdles to get things going, this is where my journey ends and I would like to thank you all kindly for all help and effort. I really hope one day z-wave will see the light but I think this way, it will only get darker. Don't get me wrong, there is always a small group of enthusiasts to which I also wanted to belong but with SO MANY TROUBLES, User side (mine/me) or technology side this is too many steps too far for me.
                              Thanks again and it was a very pleasant view to have my vera devices in z-way for a very little while (around 15 minutes) about 2 weeks ago.
                              A BIG THANK YOU AGAIN!
                              Update: just took A LOT of time?:
                              but still no devices... like last stick (2 weeks ago):
                                You got an error because you tried to exclude a device from z-way when the exclusion process needs to start from the master controller. You need to set the vera in exclusion mode and then go to z-way to "leave the network".
                                The way you did it, the vera has not configured the z-way controller yet. It just included it. Because it is an unknown device, the vera buggy autoconfiguration will not work. You have to disable auto configuration on the vera to get rid of that error.
                                All z-way does when you hit the leaving the network button, is to wakeup the z-way's zwave chip. It is expecting the master controller to be in exclude mode. If it isn't it will fail and this is by design.
                                When adding a secondary z-wave controller, you have to think of it as just an additional device on the network. That's all it is. Everything you did using the vera remains the same. Nothing has changed. Configuring devices, including, excluding... all the same. You would be doing the same thing if you included another vera or any other controller or even any other device and needed to exclude it.
                                Understanding how zwave works under the hood is not very complicated and essential but most of your problems are caused by vera's incomplete implementation of z-wave network control making things very obscure.
                                If you had started from clean from z-way, you would have a much simpler system. If you want to run a dual controller, setup, you will need to learn how the z-wave topology and commands work at the most basic level. If you want a clean and simple z-wave system, you are better off getting rid of the vera and forget everything about it.
                                S 2 Replies Last reply
                                  sender
                                  I want! But there is a way between Vera <--> homeassitant and Z-way <--> homeassistant. Well 2 ways. 1 is migrating and 2, the most important one, there is nothing for z-way in home assistant, the MQTT plugin is buggy, installation is not straight forward etc...
                                    sender
                                    I did not try to exclude anything in z-way. I did that excatly: set vera in exclusion and "leave network" in z-way, that works well! Only the other way around doesn't, the inclusion in the network (Include into network). In the screenshot you may see (Re-)inclusion started but that shows also when I did "include into network".
                                      sender
                                      #22
                                      See, unparing works well:
                                        #23
                                        I see. Sorry if I misunderstood.
                                        The only time I have seen this is when the vera is in its typical crash hang up mode. The vera has started to include a device and its command queue got into wait mode therefore never completing the inclusion. In that case, I would repeat it until it works. It is a vera problem, no different from all the problems including secure class devices the vera has been struggling with.
                                        Again, when you do it this way, z-way is no more than an additional device on the vera network and has all the same problems the vera has with secure class devices.
                                          sender
                                          This sounds logical, but this would be the 5th time then... I am running out of patience...
                                            158.2k
