  2. Hardware
  3. Z-Wave.me
  4. Add Indicator commandClass to zNode metric
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
19 Posts 5 Posters 4.0k Views 5 Watching
    ronluna
    wrote on last edited by ronluna
    Example:
    P 1 Reply Last reply
      This is the problem with not having the bridge polling the zwave API or even the JS API. The readback is only from the Automation API which is more limited. You can obviously get the signal readback from the zwave API...
      Only three ways to get around this:
      Ask PoltoS to bridge this command class to the Automation API,
      Write a plugin in JS for Z-way. (I may be able to do this but will be learning in the process)
      Or... rely on @akbooer’s future change to move the bridge to one of the other APIs if this is still the plan.
        ronluna
        not sure @akbooer would be in the mood migrate form the automation API and as you mentioned it seems is very limited as well.
          We have been discussing it and it was clear that eventually it would be the direction we would have to take. A lot of the refactoring he has been doing to the bridge is to prepare for such a move.
            Yes, this is the (a) plan. Each of the APIs has their own merit. I will, no doubt, end up with using aspects of all of them.
            But I’m a bit busy at the moment, and this, I think, is mainly a cosmetic issue?
            • R ronluna
              Example:
              P Offline
              P Offline
              PoltoS
              @ronluna said in Add Indicator commandClass to zNode metric:
              You are right, Indicator CC is handled by lib zway, but is implemented on the high level yet. You can copy everything about Switch Multilevel and rename this part to Indicator. It will add support of this CC. You can them make a pull request to include it in the dev branch on our github. Or wait for us to implement it.
                ronluna
                @PoltoS I've started your suggestion for adding Scene Controller indicator class and scene activation following your comment above by simply replicating "Switch Multilevel" in the index.js . Although wondering if this approach would be acceptable to submitted to the dev branch.
                After modifying the z-way-server-path/automation/modules/ZWave/index.js and adding the command classes 135 and 45 as:
                	this.CC = {
                		"Basic": 0x20,
                		"SwitchBinary": 0x25,
                		"SwitchMultilevel": 0x26,
                		"SwitchColor": 0x33,
                		"SoundSwitch": 0x79,
                		"SceneActivation": 0x2b,
                		"Alarm": 0x71,
                		"AlarmSensor": 0x9c,
                		"SensorBinary": 0x30,
                		"SensorMultilevel": 0x31,
                		"Meter": 0x32,
                		"MeterPulse": 0x35,
                		"ThermostatMode": 0x40,
                		"ThermostatSetPoint": 0x43,
                		"ThermostatFanMode": 0x44,
                		"DoorLock": 0x62,
                		"CentralScene": 0x5b,
                		"Battery": 0x80,
                		"DeviceResetLocally": 0x5a,
                		"BarrierOperator": 0x66,
                		"Wakeup": 0x84,
                		"Indicator": 0x87,
                		"sceneControllerConf": 0x2D
                And:
                				} else if (this.CC["sceneControllerConf"] === commandClassId) {
                			var devId = vDevId + separ + 'DS';
                			defaults = {
                				deviceType: 'sensorDiscrete',
                				location: smartStartEntryPreset && _.isNumber(smartStartEntryPreset.location)? smartStartEntryPreset.location : 0,
                				probeType: 'control',
                				metrics: {
                					probeTitle: 'Control',
                					icon: 'gesture',
                					level: '',
                					stat: '',
                					title: compileTitle('Sensor', 'Control', vDevIdNI),
                					state: '',
                					currentScene: '',
                					discreteStates: {},
                					isFailed: false
                			// apply postfix if available
                			if (changeVDev[changeDevId]) {
                				defaults = applyPostfix(defaults, changeVDev[changeDevId], devId, vDevIdNI);
                			var vDev = self.controller.devices.create({
                				deviceId: devId,
                				defaults: defaults,
                				overlay: {},
                				handler: function(command) {
                					if (command === "update") {
                						cc.Get();
                				moduleId: self.id
                			// disable value set on z-way startup
                			var startup = true;
                			setTimeout(function() {
                				startup = false;
                			}, 1000);
                			if (vDev) {
                				vDev.set('metrics:isFailed', self.zway.devices[nodeId].data.isFailed.value);
                				self.dataBind(self.gateDataBinding, self.zway, nodeId, instanceId, "SceneActivation", "currentScene", function(type) {
                					try {
                						if (!(type & self.ZWAY_DATA_CHANGE_TYPE["Invalidated"])) {
                							vDev.set("metrics:currentScene", this.value);
                					} catch (e) {}
                				}, "value");
                				self.dataBind(self.gateDataBinding, self.zway, nodeId, instanceId, "Indicator", "stat", function(type) {
                					try {
                							vDev.set("metrics:stat", this.value);
                					} catch (e) {}
                				}, "value");
                The changes above start monitoring those two classes for my static scene controller
                http://z-way-server-ip:8083/ZAutomation/api/v1/devices shows the values as
                creationTime: 1601994291,
                creatorId: 1,
                customIcons: { },
                deviceType: "sensorDiscrete",
                h: -849256330,
                hasHistory: false,
                locationName: "globalRoom",
                metrics: {
                probeTitle: "Control",
                icon: "gesture",
                level: "",
                title: "Cooper Control (#17)",
                state: "",
                currentScene: 5,
                discreteStates: { },
                isFailed: false,
                stat: 20,
                nodeId: 17,
                order: {
                rooms: 0,
                elements: 0,
                dashboard: 0,
                permanently_hidden: false,
                probeType: "control",
                tags: [ ],
                visibility: true,
                updateTime: 1602006617,
                Now I'm wondering what would the best way to add support to this command classes (45 and 135) . "currentScene" would be for the last triggered scene and "stat" would be the Indicator value.
                @akbooer I've noticed that command class 45 is already there for Leviton Scene controller as:
                  -- Scene Controller Configuration
                  ["45"] = {
                    updater = function (d, inst)
                      d, inst = d, inst
                    end,
                     -- Leviton Zone/scene controller
                    files = { "D_SceneControllerLED1.xml", SID.SceneControllerLED, "D_SceneControllerLED1.json"},
                But is not grabbing the currentScene metric.
                Mind sharing a good approach for ZWay plugin to properly trace those two classes ?
                • R ronluna
                  	this.CC = {
                  		"Basic": 0x20,
                  		"Alarm": 0x71,
                  		"Meter": 0x32,
                  		"MeterPulse": 0x35,
                  		"DoorLock": 0x62,
                  		"Battery": 0x80,
                  		"Wakeup": 0x84,
                  		"Indicator": 0x87,
                  And:
                  			defaults = {
                  				metrics: {
                  					icon: 'gesture',
                  					level: '',
                  					stat: '',
                  					state: '',
                  					currentScene: '',
                  					discreteStates: {},
                  					isFailed: false
                  				deviceId: devId,
                  				defaults: defaults,
                  				overlay: {},
                  						cc.Get();
                  				moduleId: self.id
                  			var startup = true;
                  				startup = false;
                  			}, 1000);
                  			if (vDev) {
                  					try {
                  					} catch (e) {}
                  				}, "value");
                  					try {
                  					} catch (e) {}
                  				}, "value");
                  creatorId: 1,
                  customIcons: { },
                  h: -849256330,
                  hasHistory: false,
                  metrics: {
                  icon: "gesture",
                  level: "",
                  state: "",
                  currentScene: 5,
                  isFailed: false,
                  stat: 20,
                  nodeId: 17,
                  order: {
                  rooms: 0,
                  elements: 0,
                  dashboard: 0,
                  tags: [ ],
                  visibility: true,
                    ["45"] = {
                        d, inst = d, inst
                      end,
                  This is just a stub, it doesn’t do anything.
                  I’ll take a look.
                  R 1 Reply Last reply
                    I’ll take a look.
                    ronluna
                    @akbooer I've tried adding
                        files = { nil, SID.EnergyMetering },
                      -- IndicatorStatus
                      ["135"] = function (d, inst)
                        local indicatorStatus = tonumber (inst.metrics.stat)
                        setVar ("IndicatorStatus", indicatorStatus, SID[S_HaDevice], d)
                      end,
                      -- Manufacturer proprietary
                      ["145"] = {
                    no joy
                    • R ronluna
                        -- IndicatorStatus
                        end,
                        ["145"] = {
                      no joy
                      I've tried adding
                      At first sight, that looks right. You're sure that your ZWay JS mods are doing the right thing?
                      Have you tried the same for the currentScene state?
                        I've tried adding
                        ronluna
                        @akbooer I've tried with currentScene as well. the metric is being collected by ZAutomation/api just fine as shown here.
                        creatorId: 1,
                        customIcons: { },
                        h: -849256330,
                        hasHistory: false,
                        metrics: {
                        icon: "gesture",
                        level: "",
                        state: "",
                        currentScene: 5,
                        isFailed: false,
                        stat: 20,
                        nodeId: 17,
                        order: {
                        rooms: 0,
                        elements: 0,
                        dashboard: 0,
                        tags: [ ],
                        visibility: true,
                        updateTime: 1602028670,
                        Even the Zway plugin see the classes on the device (In the example is device 17) but no their values.
                        I've tried modifying L_ZWay2.lua as:
                         --   files = { "D_SceneControllerLED1.xml", SID.SceneControllerLED, "D_SceneControllerLED1.json"},
                          -- currentScene
                          ["45"] = function (d, inst)
                            local currentScene = tonumber (inst.metrics.currentScene)
                            setVar ("currentScene", currentScene, SID[S_HaDevice], d)
                        end,
                          -- binary sensor
                          ["48"] = {
                        I'm not entirely sure that the ZWay js mods I've added is perfectly doing the right thing, I'm a little doubtful of how devId is being handled.
                        not sure if it requires the "DS" suffix.
                          Unless you changed something really drastic, the fact that the values are not appearing in the raw zway_xxx variables indicates that they are not being sent correctly from the actual ZWay system.
                          • DesTD Offline
                            DesTD Offline
                            DesT
                            @ronluna I'm having also a bunch of Leviton scene controller everywhere and can't use them with zwave+openLuup!
                            Did you make some progress since October ?
                              ronluna
                              I did, I will explain in detail in a little bit once I get to the computer.
                                ronluna
                                Most scene controllers behave differently. I don't have a Leviton scene controller in my network. Although I've read they are a little easier to properly manage them as they report the indicator status of each button individually (Cooper RFWC5 does not whichi is what I have) . So I'm assuming Z-way has created 5 toggle switches in your Z-Way Automation API (1 for each LED button of your Leviton scene controller ). If that's the case there then the missing piece for your environment would be for the openluup Z-Way plugin to track the status of those variable (The toggle switches for each indicator button on your leviton scene controller) .
                                Can you share an screenshot of all the variable the openluup z-way plugin is reading for your Leviton scene controller?
                                Currently L_Zway2.lua is only updating metrics.level (updateChildren function #1649) and is not tracking all the z-way classes. so you will need to add support for the missing classes for your scene controller and update the "updateChildren function" accordingly inside L_Zway2.lua
                                  When you find out what’s missing, I’ll happily put it into the baseline. As you say, scene controllers vary wildly.
                                    ronluna
                                    @akbooer I have not share what to modify on L_Zway2.lua because I'm not sure about the changes I've made on the Z-way automation module. I'll continue playing with it and report back in a couple of days.
                                    • DesTD Offline
                                      DesTD Offline
                                      DesT
                                      @ronluna that's the model I have
                                      https://store.leviton.com/collections/z-wave/products/vizia-rf-4-button-remote-scene-controller-vrcs4-m0z?variant=33666558595
                                      I'm trying to make it work properly on zway first, 'cause right now it not appearing under openLuup
                                      • DesTD Offline
                                        DesTD Offline
                                        DesT
                                        @ronluna @akbooer
                                        Done re-adding the device to zway correctly... not if I'm playing with one of them in the hallway, I got this in the openLuup log...
                                        2020-12-28 13:39:26.931 luup.variable_set:: 31940.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 4 now: 3 #hooks:0
                                        2020-12-28 13:39:26.932 luup.variable_set:: 31940.urn:micasaverde-com:serviceId:SceneController1.LastSceneTime was: 1609180558 now: 1609180766 #hooks:0
                                        2020-12-28 13:39:38.712 luup.variable_set:: 31940.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 3 now: 1 #hooks:0
                                        2020-12-28 13:39:38.713 luup.variable_set:: 31940.urn:micasaverde-com:serviceId:SceneController1.LastSceneTime was: 1609180766 now: 1609180778 #hooks:0
                                        2020-12-28 13:39:53.350 luup.variable_set:: 31940.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 1 now: #hooks:0
                                        2020-12-28 13:39:53.351 luup.variable_set:: 31940.urn:micasaverde-com:serviceId:SceneController1.LastSceneTime was: 1609180778 now: 1609180793 #hooks:0
                                        What I did, I click on number 3 (ON), then number 1 (ON), then number 1 again (OFF)
                                        The other thing, openLuup is not getting the "right" device name, sometime it use one "child" instead of the main device.
                                        So I think the best way to handle that under openLuup will be to have a scene that run when sl_SceneActivated "changed" and do some "IF = 1 then, IF = 2 then..... "
                                          932
                                          2.0k
                                          3.7k
                                          3.3k
