  3. Zway Bridge
  4. Recreate Zway device in Openluup
full devices reset
@akbooer Since a couple of weeks/months, we are in the process to redo 5 rooms @ home (kids are moving from room to another room) and of course, I would need to redo a bunch of device name and room name in Zway.. Is there an easy way to tell openLuup to completely start over fresh without having to delete/rename them one by one in openLuup ?
Zway Bridge
Help with Z-Way plugin
I hope this is the correct forum – apologies if not! I have a Raspberry Pi3 with a Razberry Z-Wave card installed. I have installed the Z-Way software and have successfully included a Fibaro Z-Wave switch on the Z-Wave network. I can toggle the switch on and off successfully from my laptop through port 8083 of the Raspberry Pi3. On the same Raspberry Pi3 I have installed openLuup on which I have installed the Z-Way plugin. I can access this through port 3480 on the Raspberry Pi3 from my laptop. Here is where I have come to a dead stop. How do I get access to the Fibaro Z-Wave switch from the openLuup application? I can find no documentation that tells me specifically how to do this. Any help would be greatly appreciated. _John.
Zway Bridge
openLuup Z-Way bridge: Version Log
Master Branch: 2020 Release 4.5 Roll-up of recent changes in development branch.
Zway Bridge
Fibaro Wall plug power metering
PerHP
I have an odd issue which seems to be only for Fibaro wall plugs. They come in to Z-Way with two "electric meter" entrys, one "Power" meter and a couple of alarm entrys. In addition to the switch that is. One of the "electric meters" is KWh and the other one is seemingly Watts, but it stays at 0/-1w. The "Power" meter shows the Watts used right now. When these come into openluup, the wrong electric meter is selected for displaying the Watts, is there any way to manipulate which one openLuup uses? I see that the sub channel for power also is transferred, but it isn't in the data Veraflux is transmitting to my influxdb.. Haven't used the watts reading for anything before now, now i want to estimate when my dryer is done based on power usage.
Zway Bridge
Renaming device name...
@akbooer What's the "logic" behind zway plugin about renaming ? Are you always renaming when starting openLuup ?
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Having some trouble getting the Fibaro TRV device working with the ZWay bridge. The device works in the ZWay (Zwave.Me) Smart Home GUI, and creates a number of devices in OpenLuup, some of which appear to have the right variables in it. Changing the XML and JSON files makes no difference. I also tried creating a separate child device for Parameter 67 (using the gui for the ZWay bridge, see below), and setting the XML/JSON types for that device (like I've havd to do for a few other devices). This results in a device that correctly displays the TRV setpoint, but chaning the setpoint in the OpenLuup gui does not result in anything being transmitted to/by ZWay. 20490 49-0 D_ComboDevice1.xml zNode #49-0 49-0-113-8-12-A 49-0-113-8-13-A 49-0-113-8-14-A 49-0-113-8-15-A 49-0-113-9-3-A 49-0-64 49-0-67-1 20491 49-1 D_ComboDevice1.xml zNode #49-1 49-1-113-8-12-A 49-1-113-8-13-A 49-1-113-8-14-A 49-1-113-8-15-A 49-1-113-9-3-A 49-1-64 25031 49-1-67-1 D_Heater1.xml Radiator Bedroom 20492 49-2 D_ComboDevice1.xml multi #49-2 49-2-113-8-10-A 49-2-113-8-11-A 25030 49-2-49-1 D_TemperatureSensor1.xml Radiator Bedroom
Zway Bridge
Z-way token Expiration
@akbooer, I just woke up to a z-way bridge token expiration again forcing me to login again and reload openluup. It appears to happen once a week. It doesn't appear that the auto renewal of the token is working?
Zway Bridge
Why Migrate to Z-way from vera and how?
I expect this document to be dynamic based on inputs from people who try but did not want to completely rewrite it here: https://github.com/rafale77/Z-Way/blob/master/README.md
Zway Bridge
XMLs & jsons without vera
P
Nearly there with the migration .. Is it ok to use older device files or do they get updated from time to time? Now that a fresh openLuup is up and running and connected to Zway where's the best place to source device files without vera? I probably have them on another openLuup install but not 100% which ones to copy over.
Zway Bridge
Error after device delete
PerHP
Zway Bridge
Device setup - organization strategy
PerHP
I've finally gotten the stuff to work together. Now - before I migrate all the vera devices, how do i use this? How does the variables NameDevices and CloneRooms work? (is there a manual or description of the plugin?) CloneRooms seems obvious, but is that the best way to go when I have more bridges? Set up rooms and names in Z-way? No rooms in z-way, and distribute them in openluup?
Zway Bridge
Changing device type for wall controller
Zway Bridge
Zway Bridge
Changing Device type from dimmer to Shutter
Zway Bridge
Child device undo failure
Hi AK, I must be missing something but I am having now some devices fail on the bridge due to them running out of battery. Upon battery replacement, they function properly on z-way-server but the failure remains over the bridge. The failure shows up on the parent device and it says that a specific command class has failed. Looking at the return API json, it should not return any command class level failure however so I am not sure where the bridge gets its failed state from... edit: Nevermind, I figured it out. It is a gap in data alignment between the different z-way APIs. The zwave and JS API got the update that the device recovered but not the smarthome API. Pausing and restarting the zwave app on z-way fixed it.
Zway Bridge
All Z-way devices "disabled" attribute is set to 1
K
Zway Bridge
So I started experimenting by moving some of my wallplugs and power switch zwave devices over from VeraPlus to Z-Way. In Z-Way this results in different elements for switching, Watts and kWh. Some even have Volts which I never saw on Vera. But using the Z-Way plugin in openLuup only the Switch element is visible and all other elements of the zwave node are not. I don't really know to much about Z-Way or the plugin, but am trying to learn on the run. Maybe someone can give me some pointers what and where to look for to solve this?
Zway Bridge
z-way with home assistant
Just wanted to point out and start the topic of the following: We are working on a project that will allow to use Z-Way library as the core of Z-Wave in Home Assistant. First releases will be around June/July I believe Additionally there are ways to support Z-Way from HAss via HTTP requests. This is a community project and we have no deep knowledge about it. С уважением, Полторак Сергей Z-Wave.Me https://community.home-assistant.io/t/official-z-way-integration-request/186710/27
Zway Bridge
Scheduled Pinned Locked Moved Zway Bridge
15 Posts 3 Posters 2.8k Views 3 Watching
    ronluna
    wrote on last edited by ronluna
      Luup restart?
        ronluna
        Currently it does not resync with a luup restart.
          I'm surprised. What's in the logs?
            Oh, no wait. I misunderstood, perhaps. You mean that you have deleted the Zway plugin?
              ronluna
              When I finished creating the new z-way-server setup. I went back to openluup and deleted an old ZWay device (not the ZWay plugin itself) that was there from the old z-way-server setup and re-login the ZWay plugin into the z-way-server, everything got transfer over except that one device.
              This happened in another openluup setup. If I manually delete a ZWay device from openluup and then reload the luup engine or getting the ZWay plugin to login to a new z-way-server, z-way-server devices that matches the device id of the device that was deleted in openluup won't get created.
                The device isn’t just in Room 101?
                  ronluna
                  no. not in there either.
                    Which version of openLuup and the ZWay plugin?
                      ronluna
                      Openluup 2020.04.03
                      Z-Way 20.7.14
                        Why are you deleting devices?
                          ronluna
                          I had an old device from an old z-way-server and I didn't want to start a brand new user_data. I even try to connect the openluup zway plugin with the new z-way-server without deleting the device but the old device remained as the old device type and did not update to what the new z-way-server had under that id. so then I tried deleting it to never see it again... It has happen on two different setup I'm currently migrating.
                            I am unable to reproduce this.
                            I have deleted a ZWay child device, and restarted. During the ZWay plugin initialization, it notices the missing device, recreates it (with the same numbering) and requests another reload, after which the device is there again, as it should be.
                            How are you viewing your devices? AltUI? Have you done a browser refresh??
                            Here's the log of the ZWay plugin starting up and making a new device (#20050)
                            2020-10-03 11:13:33.324 openLuup.scheduler:: [23] ZWay device startup
                            2020-10-03 11:13:33.324 luup_log:23: ZWay: v20.7.14
                            2020-10-03 11:13:33.382 luup_log:23: ZWay: HomeId: c5d860ea
                            2020-10-03 11:13:33.382 luup.variable_set:: 23.urn:upnp-org:serviceId:altui1.DisplayLine1 was: 52 vDevs, 24 zNodes now: #hooks:0
                            2020-10-03 11:13:33.382 luup.register_handler:: global_function_name=HTTP_Z-Way_23, request=z23
                            2020-10-03 11:13:33.421 luup.set_failure:: status = 0
                            2020-10-03 11:13:33.421 luup.variable_set:: 23.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                            2020-10-03 11:13:33.421 luup.variable_set:: 23.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                            2020-10-03 11:13:33.481 luup.variable_get:: No such device/serviceId/name 20050.urn:akbooer-com:serviceId:ZWay1.Children
                            2020-10-03 11:13:33.482 luup.create_device:: [20050] D_MotionSensor1.xml / / D_MotionSensor1.json (urn:schemas-micasaverde-com:device:MotionSensor:1)
                            2020-10-03 11:13:33.482 luup.variable_set:: 20200.urn:upnp-org:serviceId:altui1.DisplayLine1 was: Humidity:1 Light:1 Motion:1 Temperature:1 now: Humidity:1 Light:1 Motion:1 Temperature:1 #hooks:0
                            2020-10-03 11:13:33.482 luup_log:23: creating device numbers: [20170,20084,20080,20213,20040,20180,20140,20182,20100,20020,20050,20200,25001,25002,25003,25004,20085,20215,20214,20083,20212,20211,20210,20081,20190,20110,20181,20082]
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20002] Everspring Dimmer (2.0)
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20019] TKB Home Switch (#19)
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20004] node #4
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [21001] Aeon Labs Temperature (9.0.49.1)
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20005] node #5
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [21002] Aeon Labs Luminiscence (9.0.49.3)
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [21003] Aeon Labs Humidity (9.0.49.5)
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [21004] Everspring Humidity (10.0.49.5)
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20008] node #8
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [21005] Chromatic Technologies General purpose (5.0.48.1)
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20009] node #9
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [21006] Fibar Group General purpose (18.0.48.1)
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20010] node #10
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [21007] Aeon Labs General purpose (9.0.48.1)
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20011] Fibar Group (11.0.0) Button
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20014] Switch (14.0)
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20018] node #18
                            2020-10-03 11:13:33.482 luup_log:23: ZWay: Room 101: [20017] Switch (17.0)
                            2020-10-03 11:13:33.482 openLuup.luup:: device 23 'ZWay' requesting reload
                              I can second AK in saying I can't reproduce this. Deleting the device on openluup + luup reload has actually been the mechanism we used to reset configuration of errant devices because it recreates it.
                                ronluna
                                I'm reinstalling everything again. I'll report back in a few.
                                • Next Release?
