  3. Zway Bridge
  4. Renaming device name...
full devices reset
@akbooer Since a couple of weeks/months, we are in the process to redo 5 rooms @ home (kids are moving from room to another room) and of course, I would need to redo a bunch of device name and room name in Zway.. Is there an easy way to tell openLuup to completely start over fresh without having to delete/rename them one by one in openLuup ?
Zway Bridge
Help with Z-Way plugin
I hope this is the correct forum – apologies if not! I have a Raspberry Pi3 with a Razberry Z-Wave card installed. I have installed the Z-Way software and have successfully included a Fibaro Z-Wave switch on the Z-Wave network. I can toggle the switch on and off successfully from my laptop through port 8083 of the Raspberry Pi3. On the same Raspberry Pi3 I have installed openLuup on which I have installed the Z-Way plugin. I can access this through port 3480 on the Raspberry Pi3 from my laptop. Here is where I have come to a dead stop. How do I get access to the Fibaro Z-Wave switch from the openLuup application? I can find no documentation that tells me specifically how to do this. Any help would be greatly appreciated. _John.
Zway Bridge
openLuup Z-Way bridge: Version Log
Master Branch: 2020 Release 4.5 Roll-up of recent changes in development branch.
Zway Bridge
Fibaro Wall plug power metering
PerHP
I have an odd issue which seems to be only for Fibaro wall plugs. They come in to Z-Way with two "electric meter" entrys, one "Power" meter and a couple of alarm entrys. In addition to the switch that is. One of the "electric meters" is KWh and the other one is seemingly Watts, but it stays at 0/-1w. The "Power" meter shows the Watts used right now. When these come into openluup, the wrong electric meter is selected for displaying the Watts, is there any way to manipulate which one openLuup uses? I see that the sub channel for power also is transferred, but it isn't in the data Veraflux is transmitting to my influxdb.. Haven't used the watts reading for anything before now, now i want to estimate when my dryer is done based on power usage.
Zway Bridge
@akbooer What's the "logic" behind zway plugin about renaming ? Are you always renaming when starting openLuup ?
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Having some trouble getting the Fibaro TRV device working with the ZWay bridge. The device works in the ZWay (Zwave.Me) Smart Home GUI, and creates a number of devices in OpenLuup, some of which appear to have the right variables in it. Changing the XML and JSON files makes no difference. I also tried creating a separate child device for Parameter 67 (using the gui for the ZWay bridge, see below), and setting the XML/JSON types for that device (like I've havd to do for a few other devices). This results in a device that correctly displays the TRV setpoint, but chaning the setpoint in the OpenLuup gui does not result in anything being transmitted to/by ZWay. 20490 49-0 D_ComboDevice1.xml zNode #49-0 49-0-113-8-12-A 49-0-113-8-13-A 49-0-113-8-14-A 49-0-113-8-15-A 49-0-113-9-3-A 49-0-64 49-0-67-1 20491 49-1 D_ComboDevice1.xml zNode #49-1 49-1-113-8-12-A 49-1-113-8-13-A 49-1-113-8-14-A 49-1-113-8-15-A 49-1-113-9-3-A 49-1-64 25031 49-1-67-1 D_Heater1.xml Radiator Bedroom 20492 49-2 D_ComboDevice1.xml multi #49-2 49-2-113-8-10-A 49-2-113-8-11-A 25030 49-2-49-1 D_TemperatureSensor1.xml Radiator Bedroom
Zway Bridge
Z-way token Expiration
@akbooer, I just woke up to a z-way bridge token expiration again forcing me to login again and reload openluup. It appears to happen once a week. It doesn't appear that the auto renewal of the token is working?
Zway Bridge
Why Migrate to Z-way from vera and how?
I expect this document to be dynamic based on inputs from people who try but did not want to completely rewrite it here: https://github.com/rafale77/Z-Way/blob/master/README.md
Zway Bridge
XMLs & jsons without vera
P
Nearly there with the migration .. Is it ok to use older device files or do they get updated from time to time? Now that a fresh openLuup is up and running and connected to Zway where's the best place to source device files without vera? I probably have them on another openLuup install but not 100% which ones to copy over.
Zway Bridge
Error after device delete
PerHP
Zway Bridge
Device setup - organization strategy
PerHP
I've finally gotten the stuff to work together. Now - before I migrate all the vera devices, how do i use this? How does the variables NameDevices and CloneRooms work? (is there a manual or description of the plugin?) CloneRooms seems obvious, but is that the best way to go when I have more bridges? Set up rooms and names in Z-way? No rooms in z-way, and distribute them in openluup?
Zway Bridge
Changing device type for wall controller
Zway Bridge
Recreate Zway device in Openluup
Zway Bridge
Changing Device type from dimmer to Shutter
Zway Bridge
Child device undo failure
Hi AK, I must be missing something but I am having now some devices fail on the bridge due to them running out of battery. Upon battery replacement, they function properly on z-way-server but the failure remains over the bridge. The failure shows up on the parent device and it says that a specific command class has failed. Looking at the return API json, it should not return any command class level failure however so I am not sure where the bridge gets its failed state from... edit: Nevermind, I figured it out. It is a gap in data alignment between the different z-way APIs. The zwave and JS API got the update that the device recovered but not the smarthome API. Pausing and restarting the zwave app on z-way fixed it.
Zway Bridge
All Z-way devices "disabled" attribute is set to 1
K
Zway Bridge
So I started experimenting by moving some of my wallplugs and power switch zwave devices over from VeraPlus to Z-Way. In Z-Way this results in different elements for switching, Watts and kWh. Some even have Volts which I never saw on Vera. But using the Z-Way plugin in openLuup only the Switch element is visible and all other elements of the zwave node are not. I don't really know to much about Z-Way or the plugin, but am trying to learn on the run. Maybe someone can give me some pointers what and where to look for to solve this?
Zway Bridge
z-way with home assistant
Just wanted to point out and start the topic of the following: We are working on a project that will allow to use Z-Way library as the core of Z-Wave in Home Assistant. First releases will be around June/July I believe Additionally there are ways to support Z-Way from HAss via HTTP requests. This is a community project and we have no deep knowledge about it. С уважением, Полторак Сергей Z-Wave.Me https://community.home-assistant.io/t/official-z-way-integration-request/186710/27
Zway Bridge
Scheduled Pinned Locked Moved Zway Bridge
22 Posts 4 Posters 10.7k Views 4 Watching
  • DesTD DesT
    I think, from my point of "use", I will prefer that each time you change the name from the original device (z-way) with the room, so a full "sync" each time.
    I just got an issue this weekend. I think that my RaZberry board died and I recover from an old UZB stick with a old backup and when I reload openLuup it reconnect to zway but mixed some device, maybe 'cause of the device ID!
    In the kitchen, I got a dimmer named "Master Bedroom" and didn't know why but I think that the Master Bedroom dimmer was using this ID before...
    So I think it will prefer a full sync for the name and room coming from zway bridge. So each time I do some renaming or replacing a device, openLuup will always be in sync!
    @dest said in Renaming device name...:
    This it how it works in my system, all changes regarding name and room is done in Z-Way. I have set variables "CloneRooms =1" and "NameDevices = "" " (probably equals to false, not sure what this one does)
    akbooerA DesTD 2 Replies Last reply
    • PerHP PerH
      @perh said in Renaming device name...:
      In fact, if you set this variable to 1 or true, then the device names will be copied from ZWay. The default is simply not to do this.
      (It's a difference in philosophy – I don't name any devices in ZWay, but all done in openLuup.)
      • DesTD Offline
        DesTD Offline
        DesT
        @PerH
        Already having the same config but I think the "sync" is only done are creation time not everytime...
        • PerHP PerH
          DesTD Offline
          DesTD Offline
          DesT
          @perh
          • DesTD Offline
            DesTD Offline
            DesT
            @akbooer Ohh that mean I need to put "true" for NameDevices ?
              Yes, or 1.
                Actually, it seems that I lied...
                ...I've just checked the code and the device name update is not implemented. I recall, now, that I did look at it and stopped because, rather surprisingly, it seemed too hard to do at the time.
                • DesTD Offline
                  DesTD Offline
                  DesT
                  ahhhhhhhh 😉
                    ..And i was certain it was allready implemented! 😁
                    I've just assumed, as rooms are controlled by z-way here.. And i've been good at keeping names correct in both, so i didn't see that it wasn't happening!
                      More options is better but sometimes it can lead to more confusion.... I am partial to @akbooer approach... Set it up in openLuup rather than in z-way. It comes down to which one is easier to setup and which database is more reliable and from my observation, it is a flush so I prefer the openLuup route.
                        I've chosen to lett all source systems set as much as possible (Z-Way, Domoticz), and let mirror devices be just that.. No big caveats to either approach though.
                        • DesTD Offline
                          DesTD Offline
                          DesT
                          I'm still voting +1 on name from zway 😉
                          • DesTD Offline
                            DesTD Offline
                            DesT
                            @akbooer Is there a way to flush all device from zway to force a kind of "get all devices again", ? 😉
                              What problem are you trying to fix by doing this?
                              • DesTD Offline
                                DesTD Offline
                                DesT
                                To rename a bunch of devices from zway, don't want to do it manually one by one in openLuup!
                                  Have you tried just deleting the devices in question and reloading?
                                  (easy to delete a bunch of devices quickly from the console Devices Table page.)
                                  • DesTD Offline
                                    DesTD Offline
                                    DesT
                                    it works! thanks 😉
                                      Glad to hear it!
                                      I just looked at the code again, and indeed there's a NameDevices variable, which currently does absolutely nothing. I know that I looked at this several times and threw my hands up in disbelief at how hard it was going to be... but I can't remember why!
                                      • DesTD Offline
                                        DesTD Offline
                                        DesT
                                        But for the moment, doing this way, deleting the device from the device table make it easier!
                                          152.9k
