  2. Hardware
  3. Z-Wave.me
  4. Adding Z-way as secondary controller to vera zwave network
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
38 Posts 7 Posters 16.1k Views 7 Watching
    Strangely you can!
    But it will be chaos. The analogy would be... to have two twin brothers with the same name and you call their name and both respond at the same time... That's what happens when the devices respond to the controller.
    Say a sensor trips. It sends the message to the controller. The first controller gets the message and says "roger" the second controller gets it too and wants to respond too... you get a very chatty network with lots of frame collisions... I tried it. It's fun for 2 minutes then it gets old really quick.
    • K Offline
      K Offline
      kfxo
      Do you know if I will need a Z-Way license for UZB to accomplish cloning vera network, backing it up, and restoring on Razberry?
      DesTD 1 Reply Last reply
        The cloning from the vera for sure does not require a key. Saving that data on z-way is the only action which potentially would require a key and I honestly don’t know. Restoring the data to the razberry does not require a key either. Maybe @DesT can answer that?
          Before transitioning to Z-way completely, I was using it as a zwave tool for my vera controlled network.
          To do this, I added z-way as a secondary controller to the vera:
          1. Put the vera in inclusion mode by making it include a generic device.
          2. Go to the ExpertUI of z-way after you setup the zwave plugin on it to the right serial port and under the Network/Control menu click on “Join Network”
          That’s it... It will take a few seconds but and the vera will sluggishly luup reload and show a new controller device which will say that it needs to configure. Disable auto configuration for this device on the vera. Your z-way now should see all the devices on your network. You can even set SUC/SIS roles from it and do all kinds of things the vera cannot, or at least not easily.
          Examples of what I did: Look at routing, assign lifeline associations, survey and modify wakeup intervals. Check on device command classes hidden on vera. Verify routing health.
          Be careful with associations as by default z-way will want to add itself to the lifeline associations when you try to check them. I often had to delete z-way. There is a way to prevent that but requires editing some files and is probably not worth doing since you can just modify associations directly from z-way.
          iblisI Offline
          iblisI Offline
          iblis
          wrote on last edited by iblis
          @rafale77 said in Adding Z-way as secondary controller to vera zwave network:
          I have a couple of suggestions when adding z-way as secondary controller. If you edit the file [z-way-server root]/config/Defaults.xml you can set some default options for z-way that's not available in the gui.
          <TryToBecomeSIS>1</TryToBecomeSIS>
          By default this option is set to 1 meaning z-way will always try to become SUC/SIS in a network. If that is not preferable (specifically if you are planing to exclude z-way from the network at a later state) you should set this option to 0.
          <SecureInterviewAcceptedWithoutSchemeInherit>0</SecureInterviewAcceptedWithoutSchemeInherit>
          This option is by default set to 0 to comply to the z-wave protocol guidelines, if set to 1 z-way will not fail secure interview as secondary/inclusion controller if Scheme Inherit is not received.
          <WakeupInterval>3600</WakeupInterval
          This option is by default set to 3600 seconds that means every time z-way is reconfiguring a node it will change the default wakeup time to 3600 seconds. If you don't want to alter your default/preferred wakeup settings on nodes you can set this option to 0.
          <KeepMeInformedInsteadOfSIS>1</KeepMeInformedInsteadOfSIS>
          If you prefer that the primary controller should keep getting wakeup notifications from nodes after z-way is included as secondary controller you should set this option to 0.
          One feature in the zway expert gui that is heavily used here for troubleshooting is the Timing Info page. There you can quickly spot which node is having latency issues and in need of some tender love.
          You can disable this feature by setting the following parameter to 0 in Defaults.xml
          <Autoconfig>1</Autoconfig>
          Since you're already exploring the Defaults.xml at this point it's a good idea to change the FragmentSize for firmware updates if your z-wave controller is gen5+.
          <FragmentSize>32</FragmentSize>
          The default option is set to 32 to be backward compatible with older gen3 controllers. You can safely set this option to 40 if your controller is UZB/gen5.
          Just remember that your new customised Defaults.xml is NOT persistent during a software upgrade. So be sure to make a backup of the file outside the z-way-server root directory and copy it back after an upgrade.
          Live long and prosper 🖖
          Andreas Paulsen aka iblis
          Email: iblis@hjemmeautomasjon.no
          Norwegian Smarthome community: www.hjemmeautomasjon.no
          K 1 Reply Last reply
            DesTD Offline
            DesTD Offline
            DesT
            What I did back in time, I clone my Vera network to a UZB stick like @rafale77 told me using Vera "restore" function.
            Then, I put back my UZB in zway, wait a couple of minute to make sure I can see everything, then I backup the zwave network in Smarthome, to restore it on the RaZberry!
            • iblisI iblis
              K Offline
              K Offline
              kfxo
              @iblis said in Adding Z-way as secondary controller to vera zwave network:
              I have since added z-way as secondary and plan to exclude it before I clone the network. Since I did not do the above, is there anything I should look out for or that I can correct before I make the change?
              iblisI 1 Reply Last reply
              • DesTD DesT
                @DesT said in Adding Z-way as secondary controller to vera zwave network:
                I guess the question was wether you needed a a-way license key to do it....
                @kfxo said in Adding Z-way as secondary controller to vera zwave network
                This should disable the automated behavior for the z-way to try to add itself to the devices lifeline association list.
                So before you exclude the z-way, check all the devices associations and make sure the z-way controller node is removed. Funny I was just talking to the @therealdb about this.
                Thanks for your insights @iblis and welcome!
                • K kfxo
                  iblisI Offline
                  iblisI Offline
                  iblis
                  @kfxo said in Adding Z-way as secondary controller to vera zwave network:
                  Yes, there is a couple of things you should check to make the secondary controller exclusion less painless.
                  • Make sure Node1 is SUC/SIS, if not do the change and wait until every node in your network is updated with the new routes (manually wake up sleeping nodes if your in a hurry)
                  • Remove all secondary controller associations from nodes in the network before exclusion. This is not a problem if the primary controller also is running z-way-server since z-way automatically removes any association to a node that is no longer present in the network. This is one of the reasons Z-Way can be considered the Gold standard in Home Automation and unfortunately not many z-wave controllers on the marked today do this kind of maintenance by them self and what you end up with is more latency in your network due to nodes trying to communicate through association with hardware that is not present causing unnecessary traffic on your network (remember that according to z-wave protocol standards every node should try to communicate up to 4 times without getting a proper response before moving on to the next route).
                  • On your battery devices make sure the primary controller is set as the controller receiving wakeup notifications. If you did not make the <KeepMeInformedInsteadOfSIS> option change above before including z-way as secondary controller z-way will automatically set itself up as the receiving end after finish the first interview with your battery nodes.
                  • K kfxo
                    DesTD Offline
                    DesTD Offline
                    DesT
                    As far as I remember, the license is "included" in the UZB... but I can search in my old invoice with them if you need a real confirmation!
                      @DesT typically if it is included, you would have to manually type it into z-way. "Included" normally means it is on a piece of paper. If you don't remember doing that and you didn't buy it used then I think you did not need the license.
                      • K Offline
                        K Offline
                        kfxo
                        @rafale77 @iblis @DesT I appreciate all the input. I have successfully removed all association to the secondary controller (z-way) and also set all battery devices back to vera (node 1) for receiving wakeup notifications. I believe that Node1 is SUC/SIS but I just want to make sure. Vera's settings show "Node 1 Suc 1" and "Role: Suc SIS: YES PRI: YES". Z-way setting show "SUC/SIS in network: 1 (SIS)". Does that look correct? I think I am ready to exclude z-way as secondary controller to prepare for cloning.
                          Yes looks good! You can now exclude z-way and do the cloning.
                            I can confirm ZWay is cool. I did a couple of maintenance actions on my devices and I can't think about all the time I lost trying to do the same thing with Vera. I'm still using it as a secondary, because I need to plan a smooth transition (Alexa, Nest, and many other things to figure it out), but I'm glad I got mine for only 9 EUR, license included 🙂
                            I rafale77R 2 Replies Last reply
                              I Offline
                              I Offline
                              iRobot
                              @therealdb That's an amazing price!
                              Bought my UZB1 including license for 80 EUR just a couple of weeks ago.
                                @therealdb
                                When you will move it to a primary, you may well see yet another benefit:
                                Extended battery life of all your battery operated devices...
                                On the vera, disabling polling and nightly heal helped with the battery life of the FLiRS.
                                Disabling nnu helped dramatically with the battery life of the non FLiRS battery operated devices.
                                But the vera continues to do wakeup polling which is something I requested to remove as it is useful for only some very rare specific devices and of course I was ignored for almost a year now.
                                Z-way doesn’t do any of this craziness and it is very noticeable that all my locks and sensor battery lives have noticeably extended. I use NiMH rechargeable batteries everywhere I can and have recharged batteries only once in 9 weeks with z-way while I used to have to recharge a few sets a week before 7.30 and then about once every week or two after 7.30 and disabling all the vera bloatware they let us. I have 72 battery operated devices and FLiRS...
                                So much time and money saved from not having to go swap and recharge batteries...
                                This helped with the WAF... 😉 @CatmanV2
                                  I remember your battle to disable and I'm glad something was introduced.
                                  I have no FLiRS devices, only less than 10 battery operated one. I hate batteries and I tried to avoid them as much I could. it's just a couple of door/window sensors and two motion sensors where it was impossible (or I missed) to plan a wired one.
                                    I wish I was that lucky! I practically have no choice for these devices ranging from security door and motion sensors, to locks, HVAC vents etc... Thus the move to rechargeable batteries except for the doorlocks which are high drain and take lithium.
                                      sender
                                      Took the bit and bought it...
                                      Stick plus license... will be here lots of time next week :-)...
                                      Z-Wave. Me USB stick incl. Z-Way Controller software : Amazon.nl: Electronics & Photo
                                        sender
                                        #23
                                        What am I doing wrong here?
                                        EDIT: Nevermind installed ubuntu 18 and works...
                                          sender
                                          Sorry, I know I asked beofre but cannnot find it... got z-way running again but how can I auto start it?
                                          sudo service z-way-server start doesnt work
                                          and start it only one time:
                                          LD_LIBRARY_PATH=./libs ./z-way-server
                                            160.4k
