logrotate for z-way-server
Not too well documented elsewhere if you did not install the z-way-server from a prebuilt image like it is the case for the rPi, this is how to add the z-way-server logs to the linux log rotation process for ubuntu/debian installations:
open the logrotate config file:
sudo nano /etc/logrotate.confinsert the z-way logs to be rotated at the end of the file. In my example below, I keep 9 compressed logs and I rotate daily.
/var/log/z-way-server.log { missingok daily rotate 9 postrotate killall -HUP z-way-server endscript delaycompress } -
No it does not kill the server, it signals to the z-way-server that it needs to start a new log file.
The vera runs an equivalent command with its log rotation by the way.@prophead said in logrotate for z-way-server:
OT, could I use this make automated backups of my openluup user_data file?
Hmm for this I would use a crontab. Can start another thread if you want or need.
These are some examples:
https://tecadmin.net/crontab-in-linux-with-20-examples-of-cron-schedule/ -
I researched this quite a bit as well. The process actually does not reload. The HUP is a signal to restart a process yes, which in this case is the logging. I have used it for quite some time. Unlike a "luup reload" for the vera it doesn't kill the program and reload it. You can see that from the program load date. The vera's log rotate uses the similar function to log rotate as I said, without reloading the memory or the program. It is also what the embedded razberry image does. This all depends on how the binary is programmed.
I had to go and check this. It rather depends on the server it's directed at. Apache will re-read, for example, but not restart. I have no idea what the z-wave-server will do but it should be really easy to tel by running it and seeing the process details in ps
killall -HUP z-way-server, this command will ask the process z-way-server to "reload" and doing that, it will release the "lock" on the log file IF the application if locking the file OR just "appending" data at the end without locking!
The HUP parameter in KILL is not reloading the application ITSELF like a stop/start. The kill signal, is send to the process and ask the application IF he want to reload!
If the program/application/daemon/whatever have NO function on how to "reload", it will do nothing at all, but in case it can handle the reload, it's always like a restarting the process.
If I'm doing a KILL -HUP to a webserver like Apache or nGinx, it will reload the configuration for changes.
All I'm saying, it's that killing -HUP a process for log rotation is not required if the application didn't lock the file. You can try that by doing the command
> logfilenameThis will empty the file, if the filesize is the same even after that, the file is lock at the filesystem level and if the file is back to 0, that mean the file is empty with no lock and you don't need to kill HUP the process!
To illustrate this, I took a screenshot of my VM ps aux: I reloaded openLuup 2 days ago.
I have been doing daily log rotate on z-way-server but have booted it since April 10th, date at which I upgraded to 3.0.6
@DesT, I tried without the kill HUP process... It does not work. The log file is actually "moved" by the logrotate and it just stops logging. This is also well documented by @PoltoS on the zwave.me forum and follows their recommendations there.
Just to say that openLuup has a built-in CGI to accomplish this (files backed up to the cmh-ludl/backups/ folder in LZAP compressed form by default.) These may be used to directly restore an openLuup configuration. You could trigger the backup with a timed scene.
The openLuup console Backup page shows the available backups...
I use the backups manually. I want automated with rotation. Why hack lua to do this if its easy in os?
The openLuup plugin has a
SendToTrashaction which internally uses a file retention manager which can limit the number of files in a folder to:- the most recent N
- files younger than a certain number of days old
- only certain file types
Again, this can be run from a regularly scheduled scene. Files are temporarily moved to the Trash folder but may be permanently deleted by the
EmptyTrashaction of the openLuup plugin.The same procedure can be used to manage image files.
I don't call this 'hacking Lua'
Can't seem to get the SendToTrash action to work either, heres my attempt:
luup.call_action ("openLuup","SendToTrash",{Folder="/etc/cmh-ludl/backup",MaxDays="",MaxFiles="10",FileTypes="lzap"},2)
I really wish you would put examples in your documentation.
the log files showluup_log:2: applying file retention policy... luup_log:2: ...finished applying file retention policy
but the files are still there.
Any help?
