  3. Z-Wave.me
  4. z-way-server - Debian
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
12 Posts 4 Posters 3.3k Views 4 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    For those like me, using Debian. You can use the Ubuntu version.
    Just did the switch this morning from 3.0.0 Debian to 3.0.6 Ubuntu on a Debian VM!
      Great that you can confirm my suspicion. I am not even sure why you would need two different builds unless they were meant for different platforms (I had this problem with arm between the 32 and 64bit versions)
      Almost 4 months now since my migration from vera and I can vouch now that the initial impact is sustainable, digital et permanent. I have had no device failing to actuate. No delayed scenes or automation. No rogue sensors failing to untrip... (I am a bit surprised by this too), no ghost sensor trips, no device suddenly becoming offline, barely ever need to use even Homewave anymore since I have no need for mobile app at all except for occasional status checks, heck I even barely ever have to look at ALTUI/openLuup. Everything z-wave finally working flawlessly and on top of this, I have very significantly decreased the frequency of battery charging/swapping. I think the average battery lifetime increased by 80 to 300% depending on the device. Even my leviton scene controllers which needed a monthly power cycle with the vera before FW 7.30 and a quarterly one after FW 7.30 have not yet failed. Night and day...
      • DesTD DesT
        @DesT said in z-way-server - Debian:
        Hi
        Brand new Buster install here. I'm running into a library requirement for libcrypto.so.1.0.0 in both the Debian and Ubuntu versions.
        That seems to be deprecated part of open ssl
        Any idea how I can resolve it?
        Cheers
        • DesTD Offline
          DesTD Offline
          DesT
          @CatmanV2 I'm still using Debian stretch on my VM as back in time, z-way only supported stretch for their debian version.
          I will need to dig a little bit but pretty sure we can install the old libcrypto from a backports repo for debian!
            Yeah that's what I'm looking at. I can't be doing another install!
              Well installed libcrypto. Now hit the curl4 issue. I thought this had been resolved? Not exactly brimming with joy at this point.
              So somehow I need earlier curl as well
              PerHP 1 Reply Last reply
              • DesTD Offline
                DesTD Offline
                DesT
                @CatmanV2 you can install libssl1.0.0 on Buster using multiarch-support package and then install the package from
                Debian -- Error
                I just test it on buster and I'm not having both libssl installed!
                What's the error about curl4 ?
                • DesTD Offline
                  DesTD Offline
                  DesT
                  @CatmanV2
                  Have a look here
                  https://smarthome.community/topic/120/z-way-server-ubuntu-install
                  You should be able to do something with Debian 10
                    I knew there was another link! Cheers
                    catman@openluup:/opt/z-way-server$ sudo LD_LIBRARY_PATH=./libs ./z-way-server
                    Z-Way version v3.0.0 from 2019-07-18 02:47:11 +0300 (build fabbd8c917ba3564c3cee86f3baca2e04da1892f)
                    Looking for modules in ./modules
                    Failed to load module modhttp.so: /lib/x86_64-linux-gnu/libcurl.so.4: version CURL_OPENSSL_3' not found (required by ./modules/modhttp.so) Module modenocean.so loaded Module modws.so loaded Failed to load module modnotification2ext.so: /lib/x86_64-linux-gnu/libcurl.so.4: version CURL_OPENSSL_3' not found (required by ./modules/modnotification2ext.so)
                    Failed to load module modinstaller.so: libarchive.so.12: cannot open shared object file: No such file or directory
                    Failed to load module modhomekit.so: libdns_sd.so.1: cannot open shared object file: No such file or directory
                    Module modcrypto.so loaded
                    Failed to load module modiconinstaller.so: libarchive.so.12: cannot open shared object file: No such file or directory
                    Failed to load module modskininstaller.so: libarchive.so.12: cannot open shared object file: No such file or directory
                    Module moddhs.so loaded
                    Failed to load module modzwave.so: libarchive.so.12: cannot open shared object file: No such file or directory
                    Module modzbw.so loaded
                    Module modsockets.so loaded
                    Using default configuration file config.xml
                    Error: 'debug-port' number is out of range. Skipping it.
                    cat: /etc/z-way/box_type: No such file or directory
                    Cheers
                      OK it's up!
                      Cheers
                        @CatmanV2 How did you install Libcrypto?
                          OK, so i got libcrypto in finally, heres the info i didn't find in the previous posts:
                          After installing Multiarch support (ref. @DesT):
                          sudo apt-get install multiarch-support
                          download the file from https://packages.debian.org/jessie/amd64/libssl1.0.0/download
                          Then do this:
                          sudo apt install /*download directory*/libssl1.0.0_1.0.1t-1+deb8u12_amd64.deb
                          Now on to the curl f**up.. 🙂
                            164.1k
