  3. Zway Bridge
  4. Renaming device name...
full devices reset
Zway Bridge
Help with Z-Way plugin
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Zway Bridge
Z-way token Expiration
Zway Bridge
Zway Bridge
XMLs & jsons without vera
P
Zway Bridge
Error after device delete
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Child device undo failure
Zway Bridge
K
Zway Bridge
Zway Bridge
z-way with home assistant
Zway Bridge
22 Posts 4 Posters 11.5k Views 4 Watching
    Glad to hear it!
    I just looked at the code again, and indeed there's a NameDevices variable, which currently does absolutely nothing. I know that I looked at this several times and threw my hands up in disbelief at how hard it was going to be... but I can't remember why!
    • DesTD Offline
      DesTD Offline
      DesT
      But for the moment, doing this way, deleting the device from the device table make it easier!
        164.2k
