  2. Hardware
  3. Z-Wave.me
  4. Internet access
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
Internet access
22 Posts 5 Posters 9.0k Views 5 Watching
    Ok this is not an internet access problem but likely a libcurl version issue.
    https://smarthome.community/topic/109/z-way-several-questions/8
    I am testing on my pi which was installed also on a fresh buster and had the same problem previously. I don't seem to be having it since I upgraded to 3.0.6. What version of the server are you running?
    propheadP 1 Reply Last reply
    • propheadP Offline
      propheadP Offline
      prophead
      Started with 3.0.6. Curl is installed and working.
        propheadP Offline
        propheadP Offline
        prophead
        wrote on last edited by prophead
        @rafale77 Tried to do the libcurl3 procedure, but it's not available on apt-get, these are the closest:
        libcurl3-gnutls/stable 7.64.0-4+deb10u1 armhf
        libcurl3-nss/stable 7.64.0-4+deb10u1 armhf
        This is so frustrating.
          yeah z-way-server was not designed to work on buster or ubuntu 18. It does not support curl4. I have asked them to change this apparently since 2018 when I first ran into this problem. I don't seem to have it anymore though but my production unit is running on ubuntu 16.
          • propheadP Offline
            propheadP Offline
            prophead
            Zwave.me specifically says, only supported on stretch and buster. I am so frustrated I'm giving it a timeout.
            • DesTD Offline
              DesTD Offline
              DesT
              I'm having issue with buster, that's why I'm using stretch for z-way!
              • DesTD Offline
                DesTD Offline
                DesT
                I ask @PoltoS to make the 3.0.6 release available for buster!
                • propheadP Offline
                  propheadP Offline
                  prophead
                  • propheadP Offline
                    propheadP Offline
                    prophead
                    is the zwave on zway THAT much better then HomeAssistant?
                      Sorry guys I was having a blast trying to get @sender going with his installation over PMs. Turned out to be an attempt to run the 64bit ubuntu x86_64 version on a 32bit ubuntu VM. Anyway.
                      So yeah the Buster support is actually a full customized OS image for you to install on an SD card. Not ideal but it has liburl3 installed. I am trying to figure out how I got mine to work as I think I actually had a stretch installation which I later upgraded to buster so I am currently not seeing this problem. I also have no problem on ubuntu 16 which natively runs libcurl3. If/When I find out how to get libcurl downgraded reliably on both ubuntu and raspbian, I will post it. It seems the both of you are fighting the same problem.
                      • propheadP prophead
                        @prophead said in Internet access:
                        Yes, at least at the moment. z-way is also not that much harder to install. It is just not as well documented.
                          propheadP Offline
                          propheadP Offline
                          prophead
                          @rafale77 I respectfully disagree. Having lived through the curl3/4 nightmare that is known but not documented and having incorrect installation instructions on their installation page. I am loath to trust my home automation to an outfit (one guy) with such low quality standards. My red lights are flashing.
                            @prophead
                            I understand your experience and the frustration especially for a paid product but if you put things in perspective and if you are also on the Hass forum, you may find a viral thread a few days old in which I also posted, reflecting how difficult it is to maintain a project such as this which has an identity issue swinging between wanting to be "firmware like" (fully embedded OS image whether for a full machine, a VM, or a container) and just a program you can install anywhere. Hass adds the complexity of adding a docker container option which complicates the whole thing more than it simplifies it. I struggled mightily to install and maintain Hass and used that experience when I installed z-way which I found very easy in comparison in spite of the lack of documentation.
                            Remember also that the curl problem only affects a small portion of the program which you may or may not need. The z-way-server was built as a demonstrator GUI for the underlying library and API which is then used by various developers. As a result I never even interact with the standard GUI (smarthomeUI) of z-way-server and use exclusively the expertUI which is by far the most advanced zwave management tool anywhere. And even then I rarely need to toy with it since the system is very stable.
                            Understand also that this demonstrator was initially meant to work on the rPi with Raspbian stretch. The official support for Raspbian buster only comes in the form of the OS image.
                            It isn't a single dev, they actually have a team, @PoltoS just happens to be the (english speaking) face of it. The difficulty is the same as for Hass... there are a lot of issues related to dependencies upgrades breaking things which is why the Hass team wants to move towards a more controlled embedded image solution and stray away support of the "program on any OS" direction. I have had my share of grief with upgrading the OS or Hass on my Hass VM. Far more than with the z-way-server which has much fewer dependencies.
                            This not an excuse for poor documentation and incomplete/incorrect installation instructions. Heck even their upgrade script did not work for me on buster but it isn't a reflection of the quality of the zwave library and API. It is only a "feature" of linux supporting all platforms and distros. I hate to say this but if you want to test the windows version, you will see that it is very easy to install and works just as well.
                            • DesTD Offline
                              DesTD Offline
                              DesT
                              I agree with @rafale77 too, I never use the smarthomeUI, I mainly use the expert mode too and I use openLuup for everything. zway is mainly just the bridge to "talk" zwave.
                                @prophead
                                Yep, I'm on the windows version because I have a mini PC around with windows as base os and then a Linux VM with Ubuntu and openluup. It worked well at first install. I'll eventually move it to a RPI, or not - we'll see.
                                  You can, of course, run openLuup on Windows, (although the recent fix I put in for a problem with the LuaSocket library will need a flag to say don’t do this on Windows.). However, I used to test it regularly on PC, but have not done that recently. There used to be someone in the other place who always ran on a PC.
                                    When I first setup this mini-PC I was lazy and never get rid of Windows, but all the stuff is in my Linux VM. Since I'm running Hyper-V, USB cannot be remapped and the easiest path is to offer ZWay from Windows.
                                    I'll probably change this mini PC, since it doesn't support auto boot on power failure, and go with Windows+WSL2 (Windows Subsystem on Linux) in the future.
                                      156.0k
